It seems that 2600K will be just another E8600 soon
Try to squeez any little that left on this platform before new cpu becomes available
Prepare for SB-E
Prepare for SB-E
Nice chip Dumo.
It seems like the problem is with my Dominator and MIVE-Z...just like before, when the MIVE P67 first came out, I bought one from the local MC store and that board didn't like my Dominator either. The one I ordered from Newegg worked like a charm. Now, I think this MIVE-Z is acting the same way toward the Dominator. When I have more time, I will change memory and see what will happen. Hopefully it's just that so I don't have to send the board back to Newegg.
Asus Rampage II Gene, Xeon W3550 D0 Mushkin PC3-2000 6GB, BFG 9600GT OC 512MB DDR3
Asus A8N32-SLI Deluxe 1.01G, AMD A64 4000+, 2x1GB Ultra PC-3200, EVGA 7600GT 256MB DDR3
Asus MA378-T with AMD Athlon 64 X2 7850
ECS 945GCT-M/1333 v3.0, Intel Celeron E1400, MSI 8500GT 256MB DDR3
BIOStar P4M900-M7 Rev. 7.0, Intel Celeron 440, 1GB Kingston, 6600LE
Gigabyte M61PME-S2P with AMD Athlon 64 LE-1660, EVGA 8500GT 1GB DDR2
If you plan to stay on SB it would be easier to buy a different kit of memory (NON Hypers) than to RMA non defective boards because your memory doesnt clock the same on this platform as it did on X58 or P55. Thats just the way it works sometimes.
I have 2 kits of Dominators collecting dust because they dont run high mhz on SB.
I have two sets of GSkills. A set of trident 6Gb 1800 (off an x58 board) and ripjaw 2133 4 Gb which work fine on both my Gig P67 UD7 and P67 Mive. I'm not good at tuning memory so I just plugged them in at various benching times with no probs.
Sig always changing .
I switched memory from Dominator DDR3-2000 C9 to Vengeance DDR3-1600 C9 and the PC seems to run without any crash. So, the Dominator really isn't too compatible with this board, it seems. I should try to sell this memory...
I'll buy a 2600k that does 5GHz stable @ 1.40v any day... now where do you find that here in NL
Nice results Dumo...
lol... This forum requires that you wait 70 seconds between posts. Please try again in 8 seconds.
*phone rings*
Friend: Do you have a spare PSU lying around?
Me: No why?
Friend: My PSU just blew up, I think the second 8800GTX might have been too much for it to handle
Me: what PSU was that again?
Friend: Antec 480w
Me:........
Okay, can someone entertain my mind with vcore? My 2600K is running very stable at 4.6Ghz with 1.350v vcore. Now, from that speed to 5Ghz is like 400Mhz increase. Why can't it be stable with 5Ghz at 1.450V (a .100v increase)? Instead, it needs to go all the way to 1.550v to be stable? I bet it won't even be stable at 4.8Ghz with 1.450v either. Haven't tried it yet, but I don't think so. I'm confused on how much vcore each Mhz needs?
jcniest5 every sandy or (most cpu's) are all different in regards to voltage and MHz, some scale better than others, just the way it is in the overclocking world.
If you searched here on XS for sandys @5GHZ you will see that 90% of the voltages differ.
Gigagyte Z68X-UD3P
i7 2600k@4.6/1.35v
GSkill Rippers 2133
MSI 7870@1275/1450
Antec Kuhler 920
try posting all your settings, there is more to it than just adding vcore.
It seems to be stabilized a little now after I enabled Internal PLL Overvoltage, Spectrum to Disabled, Vcore Load-Line Calibration to 100%, Vcore Switching Freq to 350 and Vcore Phase Control to Extreme.
you have to enable CPU PLL overvoltage to get stable at higher frequencies, usually 3-4X multis higher than without.
It seems it doesn't want to be completely stable with only 1.500v + PLL OV (has to be 1.550V+PLL OV) so I'm just going to be run it at stock until I have extreme cooling. It seems the H70 isn't enough to keep it cool.
even the same batch each cpus need different vcore
Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
[history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
