...after a restart and now my latest dump from BTC Guild has disappeared into nothingness. Are the coins gone?
Xtreme SUPERCOMPUTER
Nov 1 - Nov 8 Join Now!
Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
when you go up into the menus one of the option is something along the lines of manage wallet or address. A window should pop up of hashes, I am under the impression that each of the hashes shown there work as functioning addresses, but just in case you might want to select the one you sent your last transaction to.
Main-- i7-980x @ 4.5GHZ | Asus P6X58D-E | HD5850 @ 950core 1250mem | 2x160GB intel x25-m G2's |
Wife-- i7-860 @ 3.5GHz | Gigabyte P55M-UD4 | HD5770 | 80GB Intel x25-m |
HTPC1-- Q9450 | Asus P5E-VM | HD3450 | 1TB storage
HTPC2-- QX9750 | Asus P5E-VM | 1TB storage |
Car-- T7400 | Kontron mini-ITX board | 80GB Intel x25-m | Azunetech X-meridian for sound |
Yeah i think it's ok. The address changes in order to encourage you to use a new one for every transaction. I don't know how use old addresses properly but i think Blauhung is on to something.
Cruncher #1: EVGA Z68 FTW | i7-2600k @ 4.5 | 6GB Ram
Cruncher #2: Supermicro Dual-Socket | 2 x 6-core Opterons | 4GB Ram
Cruncher #3: 8-core Xserve 1,1
T400 for non-crunching
"But don't think you'll run me over - It's, ah, planting season here in Texas... and the farm is growing..." -Otis11 on crunching WCG
All of your hashes in the Settings tab should function to your wallet.
If you didnt recieve a payment, it wasn't because your address changed. You can use any of your listed addresses and they should work. It changes for security purposes AFAIK.
Smile
And the old addresses still work, you can have different sources deposit into different addresses and know where the deposit came from.
Did it eventually show up?
don_xvi helps find cures for cancer, AIDS and West Nile, among other research !
Donald A. Perlick helps find cures for Alzheimer's, cancer, and Parkinson's, among other research !
