Dang. And I got today parcel with 75ohm resistors
I just ordered a 5830 to add to my farm. I thought I would ask you guys opinion on how I should add this in. I have 1 system with a 6950 and a 2nd system with a 5850.
I would like to add the 5830 to the 2nd system with the 5850. Do I have to crossfire them? How do I setup GUIminer; do I create a separate worker for each gpu? Do I run a separate miner for each gpu?
Main Rig
Gigabyte z78x-OC Bios F5n
i7-4770k batch L310B492 Malay @ 4.5ghz with HT 1.2v
Samsung Green 8GB 2x4GB MV-3V4G3D/US DDR3 1.3v 30nn
HiS ATI HD 6950
Corsair Force GT 120 GB Sata3 SSD (boot drive) on Intel sata3 controller port0
Samsung 320GB HD322GJ 7200 RPM 16M cache on Intel sata3 controller port1
Sony Optiarc DVD-RW AD-7240S on Intel sata3 controller port4
CORSAIR CMPSU-850TX PSU
Swiftech MCP655-B Pump
EK Suppreme HF Cpu Block
Swiftech Mcres Micro Rev 2 Reservoir
Black Ice GTX Xtreme 360 Radiator
Server
HAF 932
Gigabyte z77x-UD3H F13
i7-3770S batch 3212B621 supports VT-D and low power
32GB 4x8gb Muskin Enhanced Blackline 10-10-10-27@1.65v
Vmware vSphere ESXi 5.0u1
4x500GB Hitachi Deskstar 7K1000.D Raid 10 on a IBM M1015 <- DataStore
Sapphire HD 5850
I use BTguild; so you would have to create a new worker; then create new miner on guiminer for ea card. you do not have to run in x-fire and I thought x-fire hurt production, but I may be mistaken
it should be that simple. I also do not think it matter what system you put it on; it should run fine either way
Main Rig
HiS ATI HD 6950
Server
HAF 932
Sapphire HD 5850
Work/Game System - ~24/7 WCG
ASUS P8P67 PRO / i7 2600k @ 4.1Ghz / Gigabyte Radeon HD5870 / 4x4GB Corsair Vengeance @ 1600Mhz 9-9-9
HTPC -~24/7 WCG
Gigabyte GA-Z68AP-D3 / i7 2600k @ 4.0Ghz / Sapphire Radeon HD5830 / 2x2GB Mushkin Enhanced Essentials @ 1333Mhz 9-9-9
XS WCG Team Forum - http://www.worldcommunitygrid.org/
hmm that's interesting you bring that up. I was running a pair of 5870's in two separate rigs for a while. i have recently dropped them in the same system under crossfire with out any dummy plugs and the like and there is absolutely zero difference. if anything each card get an extra 1-2mhash under CFX. I guess it really depends on the system.
CPU: Intel Core i7 3930K @ 4.5GHz
Mobo: Asus Rampage IV Extreme
RAM: 32GB (8x4GB) Patriot Viper EX @ 1866mhz
GPU: EVGA GTX Titan (1087Boost/6700Mem)
Physx: Evga GTX 560 2GB
Sound: Creative XFI Titanium
Case: Modded 700D
PSU: Corsair 1200AX (Fully Sleeved)
Storage: 2x120GB OCZ Vertex 3's in RAID 0 + WD 600GB V-Raptor + Seagate 1TB
Cooling: XSPC Raystorm, 2x MCP 655's, FrozenQ Warp Drive, EX360+MCR240+EX120 Rad's
+1 on this....I didn't notice any increase (or decrease) from x-firing the cards to running them separately.
HTPC -~24/7 WCG
Case: Modded 700D
I can probably shed some light here. I built a second rig today with 2 5850s and there did seem to be a big drop in hashes in X-fire mode. Running the separately they're now about 300m/h each
hmmm. what is the CPU load scenario for you guys seeing a drop in mhash when using CFX? I know that if I fully load my CPU it makes a huge difference on my output but if it leave even one core/thread open normally it is fine.
Case: Modded 700D
HTPC -~24/7 WCG
wowwwww
super ghetto style...
Running two 5870's @ 1025/1200 and a stock 6870. Output is about 1200Mh/s on average and 1475Mh/s peak. 5870's are wc with cf enabled.
Sent from my HTC Sensation 4G using Tapatalk
Current: AMD Threadripper 1950X @ 4.2GHz / EK Supremacy/ 360 EK Rad, EK-DBAY D5 PWM, 32GB G.Skill 3000MHz DDR4, AMD Vega 64 Wave, Samsung nVME SSDs
Prior Build: Core i7 7700K @ 4.9GHz / Apogee XT/120.2 Magicool rad, 16GB G.Skill 3000MHz DDR4, AMD Saphire rx580 8GB, Samsung 850 Pro SSD
Intel 4.5GHz LinX Stable Club
Let me redeem the Cosmos 1000 case. 2x 5850 @ 400 mhash/s each and 1x 5770 @ 200 mhash with a total system draw of 570 watt.
wowza...
my power draw from the wall.
Try my multi-threaded prime benchmark!
If you like it and want to see more - bitcoin me!!
1MrPonziaM4QT2S7SdPEKQH88BGa4LRHJU
1HaxXoRZhMLxMJwJ52VfAqanSuLuh8CCki
1ZomGoxrBqyVdBvHwPLEERsGGQAtc3jHp
1L33thAxKo1GqRWRYP5ZCK4EjTMUTHFsc8
I cant find pics of my farm (too busy already to making new ones)
Electrical installation on flat has 20A cut off - voltage is 220-225V so I can load about 4,5kW max - so not all cards from this pic working
Only 5xpc for now
5x s140
4x 790fx-gd70 + 1x k9a2 platinium
5x 1kW ocz psu
12x 5870
2x 5850
6x 5830
all working on about 50 days
POWER BILL CALCULATION:
4122kWh total @ 50 days
3,48kWh avg per day
1kWh cost 0,56PLN (0,2$) total = ~825$
dunno, for example my friend live 200meters (METERS!) from me and he is paying 0,62
Some of my Mining rigs parked at BitClockers Mining Pool
Mostly consist of 3 and 4 card rigs with 1200W PSU's
Majority of GPU's are 5870's, I do have some 5970's 5850's 5830's and NVIDIA cards mining
Im paying $0.063per kWh my power bill is around $700 a month with a peak of 15 GHash
"If It Doesn't Overclock Its Broken"
"NexGen Overclocking"
"Overclocking, its a life style"
who heard about polish exchange market fail ?
I lost 120BTC on it
aaaaaaaaaaaaaaaaaa two months of bitcoin miner working for nothing and i have bill for pay
