“Little expense had been spared to create the impression that no expense had been spared.” - Hitchhiker's GuideMondays:It's better to ask dumb questions now, than to look stupid later
I wonder if next res from Koolance will be dual iwaki in 3*5.25 bays
Nah... dont worry....
when i get that bored, i'll setup a long round loop, and see if i can smash water mol. together in like a particle smasher fashion to bend physics, and get really cool lighting effects going at the same time!
single Bay device with 1 ddc for small form factor cases.
so like a sideways cropped 401X meant to fit in a 3.5inch.. and takes only 1 DDC.
Lind: Dual Gainestown 3.07
Its my fault.. and no im not sorry about it either.[12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
You must [not] advance.
Current Rig: i7 4790k @ stock (**** TIM!) , Zotac GTX 1080 WC'd 2214mhz core / 5528mhz Mem, Asus z-97 Deluxe
Heatware
Just seeing a top for an Iwaki would be interesting.
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Desk Build
FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
W/C System
(CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
Single-bay dual-ddc's is awesome for mountain mods owners who only have those spare 3 slots.
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
2600K | GTX 580 SLI | Asus MIV Gene-Z | 16GB @ 1600 | Silverstone Strider 1200W Gold | Crucial C300 64 | Crucial M4 64 | Intel X25-M 160 G2 | OCZ Vertex 60 | Hitachi 2TB | WD 320
When is fugger renaming this forum Xtreme Naekuh?
Or RP-401X2 drive edition, as in - make it longer then current one, so that both DDCs are located further back, tanks themselves half hight above, and below them place for slim cd/dvd/br drive
That drive idea sounds great. I wish they'd do it, but I dunno if it would work in my system.
Stupid bloody giant RAID card.
do you think this will cause a lot of vibration though? the dual bay seems to hold a pretty good amount of water which prevents the unit from vibrating. this seems like it doesnt hold enough water to do that
I want 1... but 2x D5S's.... can't really justify both.... mmm
PROJECT :: The Xtreme (WET) Dream!!!
PERSONAL H2O BESTS :
E8600 @ 4.8GHz E6750 @ 4GHz QX9650 @ 4.6GHz i7 920 @ 4.6GHz
PERSONAL AIR BESTS :
Sempron140 @ 4Ghz (Stock Cooler) i7 3960x @ 5.4ghz (Air Cooler)
Bex : "Who said girls can't play PC games or overclock!? Do I look like your imagination!?"
Aaron : "TBH, a girl doing all that is a pretty perfect girl!"
Swift_Wraith : "could someone please check bex for a penis?"
How long is this including the serial connector pipe in the length? I looked on the website but couldn't find a measurement. I want one, but I'm not sure if I will have enough space in my free drive bay.
Hello Mate,How long is this including the serial connector pipe in the length?
It is 167.7mm (6.6" or approximately 6 5/8" ) including the connection-tube. (accurate to 0.25mm, measured with a vernier-caliper)
Let us know how you go
Never argue with Idiots...they will drag you down to their level and beat you with experience!
i-Prodigy (small APD2 GFX/CPU waterloop) ; HP Blackbird Project Log (dual-Xeon Watercooled) ; Macho Mini Project Log (Sandybridge watercooled mini-ITX)
You're welcome
