On my benching rig I found a bunch of crud in my Koolance CPU-360 after using DI water + 2 drops of PT Nuke + Homedepot tubing. It was the plasticiser in the tubing that crudded up the diffuser plate.
Have had my system leak testing for the last few nights and everything is looking great!
The Primochill tubing was a bit stiffer than the Tygon 3603 I was used to, so it made installation a bit of a hassle (especially going from the CPU to the 120 XSPC radiator), but overall I'm pleased with how everything looks. Tonight I'll get back to gaming once I get home from work. I'm also glad to be back with the MicroRes. This thing was so easy to setup and a pleasure to bleed. Thanks for the recommendations!
- You may not post replies
- You may not edit your posts
Forum Rules
