Indeed the last difficulty increase step of 57% was a bummer :/
New estimated diffuculty will be 1534711 (+11%) in 6 days, 14 hours
Most likely will be higher as this predictions started at +4% when the difficulty changed last time. The closer to target block count, the higher % increase will be.
It's obvious it will be higher, but there won't be 57% increase this time I hope. I've got pretty strong miners and paying lamost nothing for electricity, so I don't care that much, but it's ridiculous I got 2-3 BTC per day with such a high hashrate and the price of BTC is not increasing :S
I feel your pain. Few days ago I bought 12BTC, just for fun, with hope of any even tiny profit. Still waiting to have 100% of my money back...
And how about this comparison:
Previous Difficulty Steps / no. of BTC / day
with 1Ghash/sec
25997 - 38.69 BTC
34171 - 29.43 BTC
36459 - 27.59 BTC
47618 - 21.12 BTC
55589 - 18.09 BTC
68838 - 14.61 BTC
76193 - 13.20 BTC
75394 - 13.34 BTC
68979 - 14.58 BTC
71019 - 14.16 BTC
82347 - 12.21 BTC
89086 - 11.29 BTC
92348 - 10.89 BTC
107677 - 9.34 BTC
109670 - 9.17 BTC
115063 - 8.74 BTC
157426 - 6.39 BTC
164364 - 6.12 BTC
244139 - 4.12 BTC
286349 - 3.51 BTC
434877 - 2.31 BTC
499567 - 2.01 BTC
567358 - 1.77 BTC
699398 - 1.44 BTC
876954 - 1.15 BTC
1379223 - 0.79 BTC
what happens when the difficulty get so high; that its hard for anyone to produce? Then everyone gives up; or does it reset or something. I would like to at least be able to pay off my cards, but the difficulty change is making it really hard to do. I am nowhere near what I originally hoped for and its taking a lot longer to make a coin now
The difficulty can change in both directions, it's more of a throttle mechanism attempting to make it average around 10 minutes for a new block to be solved by the entire bitcoin network. If people start leaving it could go back down.
Not to be confused with the reward for a block, which will eventually drop to 25 from 50 once enough coins exist. That trend will always go down. I think that one is at least a year in the future though.
Work/Game System - ~24/7 WCG
ASUS P8P67 PRO / i7 2600k @ 4.1Ghz / Gigabyte Radeon HD5870 / 4x4GB Corsair Vengeance @ 1600Mhz 9-9-9
HTPC -~24/7 WCG
Gigabyte GA-Z68AP-D3 / i7 2600k @ 4.0Ghz / Sapphire Radeon HD5830 / 2x2GB Mushkin Enhanced Essentials @ 1333Mhz 9-9-9
XS WCG Team Forum - http://www.worldcommunitygrid.org/
Look at difficulty numbers again and you will notice that there was already a decrease (75394 -> 68979). So it's possible.
As Tom128 wrote: the network will adjust the difficulty to maintain ~300 coins / hour production. Pity that increase of difficulty does not equal increase of the price. Bitcoin needs to get much more popular - unfortunately after recent attacks it will be harder than we thought.
Hmm, installed it and got it working.
However, but obvious, puts my HD5870 to 100% with 66°c Core and 96°c memory.
Where the energy-meter also goes wild.
And in CCC, I can't set my memory lower then the default 1200MHz.
With the current balance of energy/Bitcoins and the amount of people participating, is it still worth running on a single GPU system, on for 12/24 a day?
Also cuts in the GPU's life, those high temps, not? Normally runs on 35°c Core / 45°c memory, where I like to keep it for 3-4 years :P (GPU: water / MEM: Heatsink).
Plus not the lowest energy prices here in The Netherlands. =(
Asus Sabertooth TUF Z87 - Intel Core I7-4770S - GEIL EVO Veloce 2x8GB 1866MHz - MSI R9 280X OC
Nanoxia Deep Silence 1 - Corsair AX760 - Samsung 830-128GB - Auzentech Forte 7.1
WaterKEG Extreme III - BitsPower modded MCP655 - Swiftech Apogee XT v2 - Swiftech MCW82 - Custom 280X heatsink
Dell Studio 1555: 15" Full HD screen -Intel P8600 - HD4570
2x4GB 1600MHz - Samsung 830 128GB - Backlit keyboard mod
Microsoft Surface 2 32GB - Surface Touch Cover 2
Denon AVR1713 - Denon DCD1015 - Philips BDP3380/12 | Bowers & Wilkins VM1 - Boston Acoustics ASW250
If your card is a reference design, install MSI Afterburner and you can reduce the memory clock.
Bitcoin mining profitability has plummeted since the initial frenzy here 6 weeks ago. It's a common question "Is it worth mining with a small farm?" but the reduced profitability means it's less intrusive. No need to stress about your bitcoin mining every day, just play with it weekly or something. You can also mine and hold and hope the market value of BTC increases. Then you never have to think about it until you catch word that they've got a street value of $30 or $40!
don_xvi helps find cures for cancer, AIDS and West Nile, among other research !
Donald A. Perlick helps find cures for Alzheimer's, cancer, and Parkinson's, among other research !
use this calculator the estimate your profit.
http://www.kaptain.me/btc_calc.php
312 Xeon Threads + GTX 1080 + GTX 1070 + BFL Monarch 700
Thought I'd give this a try, I am currently getting ~80+ Mhash/s, how is that for a stock HD 5770? Also getting extreme slowdown on my system, it feels very sluggish even as I am typing right now.
EDIT: 97% GPU usage according to MSI Afterburner so it's working but if my system will be this sluggish I don't think I can do this
SweClockers.com
CPU: Phenom II X4 955BE
Clock: 4200MHz 1.4375v
Memory: Dominator GT 2x2GB 1600MHz 6-6-6-20 1.65v
Motherboard: ASUS Crosshair IV Formula
GPU: HD 5770
that 5770 should be getting you 150-200mh/s. do you know what flags you are using?
Try my multi-threaded prime benchmark!
If you like it and want to see more - bitcoin me!!
1MrPonziaM4QT2S7SdPEKQH88BGa4LRHJU
1HaxXoRZhMLxMJwJ52VfAqanSuLuh8CCki
1ZomGoxrBqyVdBvHwPLEERsGGQAtc3jHp
1L33thAxKo1GqRWRYP5ZCK4EjTMUTHFsc8
SweClockers.com
GPU: HD 5770
https://en.bitcoin.it/wiki/Mining_hardware_comparison is a list of people's cards which shows some of the different miners and settings used. I am not sure which miner you use but the better outputs seem to be with phoenix
My Biggest Fear Is When I die, My Wife Sells All My Stuff For What I Told Her I Paid For It.79 SB threads and 32 IB Threads across 4 rigs 111 threads Crunching!!
SweClockers.com
GPU: HD 5770
download and install these drivers. http://forums.guru3d.com/showthread.php?t=348465. The newer version the the SDK will allow the system view flash enabled web pages and watch video while still mining. Watching videos while mining is not suggested but the gpu will not crash the system if you do and will throttle down your mining.
Main Rig
Gigabyte z78x-OC Bios F5n
i7-4770k batch L310B492 Malay @ 4.5ghz with HT 1.2v
Samsung Green 8GB 2x4GB MV-3V4G3D/US DDR3 1.3v 30nn
HiS ATI HD 6950
Corsair Force GT 120 GB Sata3 SSD (boot drive) on Intel sata3 controller port0
Samsung 320GB HD322GJ 7200 RPM 16M cache on Intel sata3 controller port1
Sony Optiarc DVD-RW AD-7240S on Intel sata3 controller port4
CORSAIR CMPSU-850TX PSU
Swiftech MCP655-B Pump
EK Suppreme HF Cpu Block
Swiftech Mcres Micro Rev 2 Reservoir
Black Ice GTX Xtreme 360 Radiator
Server
HAF 932
Gigabyte z77x-UD3H F13
i7-3770S batch 3212B621 supports VT-D and low power
32GB 4x8gb Muskin Enhanced Blackline 10-10-10-27@1.65v
Vmware vSphere ESXi 5.0u1
4x500GB Hitachi Deskstar 7K1000.D Raid 10 on a IBM M1015 <- DataStore
Sapphire HD 5850
In phoenix you can adjust the AGGRESSION figure to help with your problem. I expect you can with others too but I am not sure how
guys do you need the run both the bitcoin client (?) and guiminer at the same time? Do I need to link them for any reason?
Only if you are "solo mining"
Otherwise the bitcoin client just is a network client managing your digital wallet which is a separate activity from the actual mining. No direct link between them if you are in a mining pool.
Sometimes a good slap in the face is all you need
Bios my arss.....
I can fix this problem with a hardware mod.... Hipro5
"Overclock till death. Overclocking is life." Hipro5
Time for some multi-qouting but I thought it might be of help to others
I noticed yesterday that when I closed all my tabs (and windows) on Firefox my Mhash/s went up from 80-90 to 197 sometimes touching 200. So I tested popping up Firefox again but this time closing my youtube windows which solved the problems so it was indeed video playback which caused not only my slow MHash/s but also my system "feeling sluggish and unresponsive". The new drivers might solve this but that's something I will have to try out later before I can comment on it
A BIG BUT, I don't get the same video watching a video with Internet Explorer 9, only Firefox.
SweClockers.com
GPU: HD 5770
I see where Th no longer accepts dwolla, what are guys doing now to transfer funds? Mt. Gox? PayPal? What's Th best alternative?
Cruncher #1: EVGA Z68 FTW | i7-2600k @ 4.5 | 6GB Ram
Cruncher #2: Supermicro Dual-Socket | 2 x 6-core Opterons | 4GB Ram
Cruncher #3: 8-core Xserve 1,1
T400 for non-crunching
"But don't think you'll run me over - It's, ah, planting season here in Texas... and the farm is growing..." -Otis11 on crunching WCG
Main Rig
HiS ATI HD 6950
Server
HAF 932
Sapphire HD 5850
Alright cool I'll check them out. I see Mt. Gox still uses Dwolla too
