Only if BD is superior in performance...but that is true right??
http://translate.google.es/translate...cio%2F&act=url
If only that would be true![]()
Question : Why do some overclockers switch into d*ckmode when money is involved
Remark : They call me Pro AsusSaaya yupp, I agree
They could raise prices also haha
lol when has amd ever held up? they will let us down like always.
Super Crunchy NAS
Lian Li PC-A77FB - Noctua NF-S12A | 3x SuperMicro CSE-M35T-1B - 3x Noctua NF-B9 | Asus KFSN5-D/IST | 2x AMD Opteron - 2419 @ 1.8Ghz | 4x1GB WINTEC DDR2 | SeaSonic 660XP | ASUS BC-12B1ST | ASUS DRW-24B1ST
Soon? - 2x Noctua NH-U9DO A3 | 2x Western Digital Green 320GB | 4x Western Digital Red 2TB | LSI MegaRAID - 84016E | 2x Noctua NF-A14
Dedicated Crunch
SuperMicro H8DMi-2 | 2x AMD Opteron - 2419 @ 1.8Ghz | 2x ArcticCooling Freezer 7
Soon? - SeaSonic SS-400FL2
ONLINE | OFLINE
It doesn't take a genius to figure this out.
The Cardboard Master Crunch with us, the XS WCG team
And put that GPU to work too! Fold for XS
Main PC: Intel Core-i7 2600k @ 4.5GHz, 8GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 7 Pro x64, water - ONLINE
Office PC: Intel C2D e8400 @ 3.0GHz, 4GB DDR2-800, GeForce GTS 250, Win 7 Pro x64, air - ONLINE
Dedicated: DP Intel Xeon LV Sossaman @ 2GHz, 4GB DDR2-400 ECC, Win XP Pro, air - ONLINE
Family PC: Intel C2D e8500 @ 3.2GHz, 3GB DDR2-667, Radeon X1300, Win 7 Home x64, air - ONLINE
apparently NKrader doesnt recall amd64's and the x2's that wherestomping amd until c2d.
Ah yes, the A64 generation. A mistake Intel will likely never forget and will likely never repeat.
Unfortunately, AMD is known for being UNABLE to repeat their feats from that timeframe for the simple fact that they are literally a generation behind Intel. The bugs with the first Phenom processors and the constant delays with BD mean they will continue competing against Intel's outgoing processors unless a miracle occurs. Let's hope it does occur since this market is due for a shakeup, whether it comes from AMD or ARM...
I keep seeing this chatter about "bulldozer delays" but then I keep seeing others saying no it isn't delayed. What's up with that?
so this is intel saying they wont cut prices.
Only couple weeks to find out. Not holding my breath though.
Athlon was better clock per clock than Pentium III (and for less price at same performance, also 1st 1Ghz x86 cpu), Athlon XP more of the same against P4. So it's not only Athlon 64, it seems people have bad memory. Athlon 64 was just the exclamation point.
With Athlon 64 the difference was so big than even biased sites/magazines couldn't put enough make-up to the P4.
Obviuosly:
In Athlon era AMD had trouble with mobo manufacturers, even more OEM blackmails from intel, less production capacity, etc.
Athlon II X4 620 2.6Ghz @1.1125v | Foxconn A7DA-S (790GX) | 2x2GB OCZ Platinum DDR2 1066
| Gigabyte HD4770 | Seagate 7200.12 3x1TB | Samsung F4 HD204UI 2x2TB | LG H10N | OCZ StealthXStream 500w| Coolermaster Hyper 212+ | Compaq MV740 17"
Stock HSF: 18°C idle / 37°C load (15°C ambient)
Hyper 212+: 16°C idle / 29°C load (15°C ambient)
Why AMD Radeon rumors/leaks "are not always accurate"
Reality check
amd was fine until conroe showed up. hopefully bulldozer is good.
we going shh around the corner
Absolutely Incorrect. I do a lot of professional programming and during this time based on my test Athlon was up to ~35% slower than PIII in almost every aspect (this of course being my own real world experience) , however I cannot vouch for gaming as I did not do any gaming in this era. Some of my colleagues said Athlon was better at gaming.
No doubt P4(i.e. netburst) was a fail, AMD Athlon 64 stomped all over Intel during this time, however this was the first time since the AM386dx 40mhz days.
Actually P4 was faster at times provided prefetching instructions were used (and used properly), but of course intel was really arrogant in thinking dev's would optimize (or reprogram) their code for the deep pipeline (i.e. netburst) the P4 had. This actually was why hyperthreading was created, so they could attempt to have multiple threads feed the pipeline automatically, since they figured out dev's were not going to do it explicitly.
Sandy Bridge 2500k @ 4.5ghz 1.28v | MSI p67a-gd65 B3 Mobo | Samsung ddr3 8gb |
Swiftech apogee drive II | Coolgate 120| GTX660ti w/heat killer gpu x| Seasonic x650 PSU
QX9650 @ 4ghz | P5K-E/WIFI-AP Mobo | Hyperx ddr2 1066 4gb | EVGA GTX560ti 448 core FTW @ 900mhz | OCZ 700w Modular PSU |
DD MC-TDX CPU block | DD Maze5 GPU block | Black Ice Xtreme II 240 Rad | Laing D5 Pump
i loved my pentium 4s, never touched AMD back then even though that was the smart thing to do.
Super Crunchy NAS
Dedicated Crunch
ONLINE | OFLINE
The thing is that Intel has 3-4 projections and these are based on ES performance and data collection along with educated guess work. Now in 2-3 of the scenarios SNB/SNB E wins but in 1 it does not.
I would imagine they take comparisons based on die size but am not sure...
Coming Soon
It wont happen again because Intel wont be caught idling without a projected new tech for the foreseeable future again as it happened in the Netburst era.
The original plan was to extend Netburst until like 2010 or some crazy BS like that.
Ever since A64 Intel learned their lesson and have been keeping a tick-tock schedule.
Intel fanboys that love to bash AMD should be thankful instead, given how AMD made Intel move their lazy netbursty butt.
First Athlon WAS overally faster than PIII, mainly in FPU tasks, that was a surprise for everyone.(After K6-2 which had VERY weak fpu)
Then AMD was first to the 1ghz race (Intel in a rush have put out chips pretty much factory overclocked which had stability problems)
Then Intel introduced P4 wiliamette, which was utter failure of grand magnitude paired with very pricey RAMBUS ram.Athlon XP was faster while being cheaper (plus platform was cheaper),even PIII was faster in most of the tasks.
With the northwood Intel gained ground,AMD responded with A64 which again stomped Intel, then Intel released prescott (or presshot for some) AMD had first X2`s .
So yes.Intel is always faster blah blah blah ;-).After conroe AMD didnt REALLY do anything substantial,it was rehash again and again of the same, thats why they cant enter high end again, hector ruiz ,destroyer of motorola before it, almost did the same to amd, and there was some insider trading, shady things going on with AMD.
TAMGc5: PhII X4 945, Gigabyte GA-MA790X-UD3P, 2x Kingston PC2-6400 HyperX CL4 2GB, 2x ASUS HD 5770 CUcore Xfire, Razer Barracuda AC1, Win8 Pro x64 (Current)
TAMGc6: AMD FX, Gigabyte GA-xxxx-UDx, 8GB/16GB DDR3, Nvidia 680 GTX, ASUS Xonar, 2x 120/160GB SSD, 1x WD Caviar Black 1TB SATA 6Gb/s, Win8 Pro x64 (Planned)
AMD will come that generation back, in future they will release cpu that will crush intel.
Im not shure if BD can be that magical cpu but wait few generations forward, something is in development![]()
::: Desktop's - Intel *** Intel 2
2 x Xeon E5-2687W *** Intel i7 3930k
EVGA SR-X *** Asus Rampage IV Extreme
96Gb (12x8Gb) G.Skill Trident X DDR3-2400MHz 10-12-12-2N *** 32Gb (8x4Gb) G.Skill Trident X DDR3-2666 10-12-12-2N
3 x Zotac GTX 680 4Gb + EK-FC680 GTX Acetal *** 3 x Radeon HD7970 3Gb + EK-FC7970 Nickel Acetal
OCZ RevoDrive 3 x4 960Gb *** 4 x Samsung 840 Pro 512Gb
Avermedia LiveGamer HD capture card
Caselabs TX10-D
14 x 4 TB WD RE4 in RAID10+2Spare
4 x Corsair AX1200
::: Basement DataCenter :::
[*] Fibreoptic connection from operators core network
[*] Dell PowerConnect 2848 Ethernet Switch [*] Network Security Devices by Cisco
[*] Dell EqualLogic PS6500E 96Tb iSCSI SAN (40 2Tb Drives + 8 Spare Drives, Raid10+Spare Configuration, 40Tb fail safe storage)
[*] Additional SAN machines with FusionIO ioDrive Octal's (4 total Octals).
[*] 10 x Dual Xeon X5680, 12Gb DDR3, 2x100Gb Vertex 2 Pro Raid1 [*] 4 x Quad Xeon E7-4870, 96Gb DDR3, 2x100Gb Vertex 2 Pro Raid1
[*] Monster UPS unit incase power grid failure backed up by diesel powered generator.
Really hope that Bulldozer can actually perform, I want one. Hope AMD does get it right this time.
PC 1: Intel Core i7 3930K | 32GB DDR3 G.Skill Ripjaws X 2133Mhz | Gigabyte GTX 670 SLI | Corsair AX1200 watt Power Supply | 20x LG SATA DVD+/- RW | LG BluRay/HD DVD Combo Drive| Logitech Z-5500 5.1 speakers | 42" Toshiba 42XL700a at 1920x1080 1080p | Gigabyte GA-X79S-UP5 | Aerocool Strike-X ST Black | 1x OCZ Vertex 3 240GB SSD | 1x 1TB Western Digital Hard Drive | 1x 2TB Western Digital Hard Drive | Windows 7 x64 Ultimate RTM
P.S.
Sorry my english may be broken
__________________________
main: 486@66Mhz12meg cache no oc
mem OCZ_4gb_1600@1333 ddr3 6-6-6-14 T1
, NvGtx560Ti, abaut 3.1tb hard drives, X-Fi. =tower with 6 fans
My x-fi mod -140dB up to 130dB and ... THD 0.0000% !
http://www.xtremesystems.org/forums/...xtreme-%29-%29
GoingUp^^ with..<-Ruby
Game called BattleZone 2 And we are playing ON line!![]()
