You must [not] advance.
Current Rig: i7 4790k @ stock (**** TIM!) , Zotac GTX 1080 WC'd 2214mhz core / 5528mhz Mem, Asus z-97 Deluxe
Heatware
what you needs is just a HD 6450. It indicates 50°c during Blu-ray play back and i still use it for light gaming(NFS carbon or most wanted) all settings at high.
You can play 3D Blu-ray movies and itīs passively cooled. The worst thing that will happen to you in your build is unwanted fan noise when you turn down the volume of the music or movie, unless you have an extremely low db fan which will be had to get in stock vga cards.
MAIN RIG--:
ASUS ROG Strix XG32VQ---:AMD Ryzen 7 5800X--Aquacomputer Cuplex Kryos NEXT--:ASUS Crosshair VIII HERO---
32GB G-Skill AEGIS F4-3000C16S-8GISB --:MSI RADEON RX 6900 XT---:X-Fi Titanium HD modded
Inter-Tech Coba Nitrox Nobility CN-800 NS 800W 80+ Silver--:Cyborg RAT 8--:Creative Sound BlasterX Vanguard K08
I ened up going nVidia after comparing playback and driver stability. AMD/ATI has really rubbed the wrong way. I've had driver issues at work w/ 4000 series cards and couldn't find a better price to beat.
I bought a Galaxy GT 430 for $40 AR. Can't really beat that.
Heatware
It's amazing how little you can get away with in an HTPC.
I've seen people using quad cores, mid range video cards, etc etc....complete waste!
My HTPC has an AMD Sempron, yes single core!
And onboard Radeon HD3200, and it can play HD DVD, Blu Ray, H264 etc etc....and it's super silent.
If I get a 3DTV, I'll need HDMI 1.4 support, but I would go for a 6450 fanless card. Thats more than enough.
Desktop :-AMD Ryzen 1800X | ASUS Crosshair VI Hero | 16Gb Corsair LPX | Asus Strix Fury | Corsair MP500 480Gb (OS/Apps), Samsung 850 Evo 1Tb (Steam), WD Caviar Green 2Tb (Data) | Lian Li PC-09 WRX | Superflower Leadex Platinum 1600W | Win 10 Pro x64
Notebook :-Alienware M17x R4 | Intel i7 3630QM | 8Gb DDR3 | AMD Radeon HD 7970M 2Gb | Crucial M4 512Gb | Win 7 Pro
Media PC :- AMD Sempron LE 1300 | Gigabyte GA-MA78GM-SH2 | 780G chipset/Radeon HD3200 | 2Gb OCZ PC2-6400 | Crucial V4 128Gb | LG GGC-H20L | Win 7 Pro
Storage :- Windows Home Server 2011 | Chenbro ES34069 | Intel DH67CF | Pentium G620 | 4Gb Corsair Vengence LP DDR3 | Sandisk Ultra 120 Gb SSD (OS) | Highpoint RocketRAID 640 + 4 WD Caviar Red 2Tb RAID 5 (Data)
I agree 100%.
I just know I won't get enough for my 760 & itx board to cover the cost of a of say an i3 2100 & itx board (If I want to add features later, I don't want it to bog down).
The sempron set up is a good idea. I just already own hardware and my i5 doesn't support onboard video.
Heatware
Good pick, I use a GT430 in my HTPC also and its been good. Team Green's drivers are usually better and if you ever want to linux that HTPC then you have working drivers available (linux + XBMC = HTPC heaven.)
software renderers can run smoother on a quadcore being more universal still at this point,less setup time is still nice
TRU/i7920@4.0...AsusP6X58D...6G/Gskill(1603)...EvgaGtxTITAN...80GIntelG2...X-FI/680z...CorsairHX1000...thermaltakeXIII...HP LP-3065...8.1pro x64
TRU/i7920@3.6...AsusP6TWSPRO...12G/OCZ...XFX5770...2x64GSamSungSLC/Areca1110 raid0...2.8TB storage...SeasonicX650...CoolerMaster810...HP LP-3065...8.1pro x64
Heatware
I just put this system together for a Bedroom HTPC, 1*4GB Kingston DDR3 1333 PC10600, Asrock 880GMH U3/S3 Micro ATX, Athlon 255, WD Black 1TB SATA III and the HIS 5450 512MB I mentioned.
It is running most of the video files and formats the wife wants at 720/1080 no problems. All powered by a Silverston 350W psu, very quiet! The MoBo comes with a 4250 card onboard so it can even run without the HIS 5450. But I always like a dedicated graphics card. The HIS is passive and does get hot so make sure there is some airflow into the case. I will make a plastic wind deflector to channel so air from the CPU fan down over the gpu heat sink.
24/7 PC CoolerMaster CM690 + 7 fans(its HOT as HELL in Shanghai) Intel Xeon E3 1230 3.3-3.7Ghz, 2x8GB DDR3 1600 G-Skill, HD GT630 2GB, Scandisk Pro 256SSD 2x2TB Green, 2x 3TB WD Green Data Drives. HTPC Q8400, EP45 UD3L 4x1GB Gskill6400, 1xWD Black 640GB,2x2TB WD Green, 2xWD 1TB Blue(RAID1), Sapphire 4530 512MB,
Computers have enabled people to make more mistakes faster than almost any invention in history, with the possible exception of tequila and hand guns.
Mitch Ratcliffe, U.S. technology journalist and blogger
Sounds good chinaguy.
I wasn't sure if the top fan on the SG07 would push air over the card, so I got a 430 that is reported to be basically silent. I would have gone with a low profile passive otherwise.
Heatware
Well it should keep the wife happy and she will be able to rip DVDs to her Itouch. Its running very quiet especially at night when sleeping. The new WB 1TB replaced an old 150 Raptor that was TOO NOISEY to sleep in the same room.
Need to go to the local Street Market and pick up a $5 HDMI cable, the only ones in the 'Big Shops' are the GOLD Plated version at $100...... Then that should give the 42inch Philips a workout!
What should be the first Movie at 1080........Fifth Element???
How's your sound setup? For just picture quality Deja Vu always impresses, but if your audio setup is up to it the opening sequence in Top Gun will knock anyones socks off
I admit that I've only done a little research on this, but I don't understand why it would be better to run it on Linux. Linux doesn't support hardware acceleration and doesn't do Netflix. XP also doesn't support hardware acceleration and XBMC didn't run well at all on it.
You made a good choice with the 430. I'm an ATI person myself, but the Nvidia cards are great for this.
Edit: I was wrong on the Linux part. It does use HW acceleration
AMD Phenom II 1090T @ 4GHz
MSI 890FXA-GD70
4GB G.Skill PI DDR3 1600 C6
OCZ Agility 2 60GB
Visiontek Radeon 5850
Antec Nine Hundred
Watercooling:
Enzotech Sapphire Rev.A
Swiftech MCW80 + 5850 heatsink
Swiftech MCP655
Swiftech MCR320
Heatware
Maybe its because I came from the old days when PC's sold for more than the Family car. I see NO REASON to skimp on parts or complain that folks have more than they need. I'd rather have too much than not enough considering how cheap most of this stuff is.
Things like XMBC can and will show some of the folks with this just good enough to get by on stuff isn't just good enough. I run Windows Vista 32bit, MCE, XMBC, Songbird, Money Audio and other crap because each has a little some thing I like better than the others. I saw XMBC use up to 70% CPU resources on a i8400 (left over from a i9550 upgrade) that's using 3.2GB of 4GB since its a 32bit OS.
I used to worry about making DVD Backups smaller. Now with folks being able to store TB's of data, I find myself wanting HQ IQ and Hi-Fi better than yester-year crappy compressed stuff.
I wouldn't use a Celeron, Pentium, Duron or any Budget Processor to Trans-code, Parse, Convert and or etc... for my Media sources now. I use only a GT240 video and Auzentech Prelude for ANALOG sound. Built in Blue Ray and even a Separate LG 370 BD Player bought before my HTPC was upgraded.
There's something else over looked here. Network Card. Funny how my DLink USB 2.0 Dongle rated at only 150Mb (yes, bits) runs faster than my cheap Realtek based "N" that was rated for 300Mb. I've also never NEVER had a signal lost and only have slow downs about once a week. Netflix, Hulu, LastFM, Pandora, HQ You Tube Videos and many others means I've been storing less anyway.
I have plenty of other plans meant for this system.
Originally Posted by Movieman
qft!Posted by duploxxx
I am sure JF is relaxed and smiling these days with there intended launch schedule. SNB Xeon servers on the other hand....
Posted by gallag
there yo go bringing intel into a amd thread again lol, if that was someone droping a dig at amd you would be crying like a girl.
