Results 1 to 5 of 5
Thread: ssd or raid for gaming?
    Apr 2011
    looking for some solid advice here..should i go with ssd? if so which brand,how many gbs and sata 2 or 3?
    if its raid then ill go with seagate 32 mb cache
    also 1 other note i have an asrock extreme 4 p67 and the ssd has issues with the marvel sata ports and im not sure which port to use
    system specs
    i2500k @5ghz
    asrock p67 extreme 4 bios 1.7
    2x4gbs pc 12800 1600 mhz gskill cl8 9-9-9-24 @ 1.6v
    evga gtx 570
    silverstone 1200 watt power unit
    right now i have a seagate 3gbs sata2 drive (250gb)
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    Definitely SSD. As for which to go with, you can't go wrong w/ Intel 320, Crucial M4, or the Crucial C300. Those are my top three choices.
    Apr 2011
    120 gb over 64 i assume as they are faster?...thx btw for the reply
    I am Xtreme
    Oct 2005
    There difference in speed between them is going to be minimal. Just buy whatever you can afford or whatever one you require in terms of space.
    Apr 2011
