Apogee XT2 Upgrade Detailed Review
Special thanks to Gabe from Swiftech for sponsoring the new Rev2 top. I purchased the Rev1 block, but this is a retest showing Rev1 vs Rev2. This would be my fifth block in my i7 2600K series CPU block testing.
This is not a full review, just an update to the original Rev1 test/review.
Also for comfort, I did some work testing my meters for accuracy. The flow and manometer meters seem to check within specifications. I also retested the CPU-370 and Supreme V1 in the above chart just to be sure relative results were good.
For the collection of data:
And now for the best mount of 5 simplified bar chart. (I like this better than average mount as it seems to have a higher repeatability (With fewer mounts) and more represents the extreme user willing to remount if needed)
You can see in the above test runs between Rev1 and Rev2. The average method of Rev1 would be in a fair amount of error compared to Rev2, yet both runs hit the "Best Of 5" target very well. You could also presume in the Rev1 run that mounting variability was high, yet using the same exact mount and base in Rev2 run gave very different results (I got better and more consistent, not the block). I think there are too many variables to conclude much of anything except "Best of 5" mounts. You would need to do several dozen mounts to create a very repeatable average. At least for my variable hand, I'm all over the place when it comes to the mounting variable and that's on a horizontal MB test bed.
I am adopting this CPU test presentation method:
-Show all 5 mounts (above) to encourage displaying the errors present and lack of significant figures.
-Simplify to best of 5 mounts bar chart below:
Bottom line:
Same great block as the Rev1, same thermal performance, and lower pressure drop
Cheers!
Martin
