STARSCREAM
3570k @ 4.6 GHz | Asus P8Z77-V LK | G.Skill F3-12800CL8D-8GBXM | ASUS GeForce GTX550 Ti
Corsair Neutron GTX 240GB | Corsair Force GT 120GB | SK hynix 128GB | Samsung 830 64GB
WD Black 640GB (3) | Seagate 7200rpm 1TB | Dell Perc H310 xflashed to LSI 9211-8i
Corsair AX750 | CoolerMaster Hyper 212 | Antec P280 | Dell Ultrasharp U2410 | BenQ XL2420T
ROCCAT Savu | Filco Majestouch-2 TKL w/Cherry MX Reds
MEGATRON
3770k @ 4.5GHz | Asus Sabertooth Z77 | G.Skill F3-12800CL8D-8GBXM
SK hynix 128GB | Mushkin Enhanced Chronos 60GB | WD Red 3TB (4) | Seagate 7200rpm 3TB (2)
WD Green 2TB (3) | Seagate 7200rpm 1TB | Dell Perc H310 xflashed to LSI 9211-8i (2)
Corsair AX650 | Corsair H80i
I look at it this way:
Higher resolution - NO
- Pixel per pixel, its identical
Better colors - NO
- No sensor or film gets colors 100% right, interpolation is just as close as 3-layer blending, cause in the end, its still an average on either sensor.
3D Look - NO
- All images are 2D, its a fanboy myth, Canon users think they get 3D, Nikon users think they get 3D
Better Pixel sharpness - NO
- A pixel is only a dot, and that cannot define sharpness
Captures more detail - NO
- Same resolution, same dynamic range, same color depth, and same lens = same detail, just different colors
Also, check this out if you haven't yet. Its Foveon for Bayer sensors and still has 4 times the "theoretical" resolution of the SD1.
The H4D-200MS camera uses a 50Mpix sensor mounted onto our patented symmetrical multi-shot frame, which can accurately position the sensor with accuracy, using piezo-electrical actuators. The camera then captures 6 shots, by moving the sensor 1 and ˝ pixel at the time, to create a 200Mpix capture. This process eliminates the issues which single-shot interpolation can sometimes introduce, such as moiré and color rendering issues, thereby capturing the red, green and blue information in each individual pixel point and then combining these captures into one amazing file.
2600K + Sabertooth + 560Ti
Only thing that can you give slight 3D look is good lens, not much to do with sensor, cause even BW image can look bit 3D-ish.
i7 930 D0 - 4,2 GHz + Megashadow
3x4GB Crucial 1600MHz CL8
Foxconn Bloodrage rev. 1.1 - P09
MSI HAWK N760
Crucial M500 240GB SSD
SeaGate ES.2 1TB + 1TB External SeaGate
Corsair HX 850W (its GOLD man!)
ASUS STX + Sennheiser HD 555 (tape mod)
Old-new camera so some new pics will be there.. My Flickr My 500px.com My Tumblr
