+ Reply to Thread
Page 75 of 220 FirstFirst ... 25 65 72 73 74 75 76 77 78 85 125 175 ... LastLast
Results 1,851 to 1,875 of 5480
Thread: SSD Write Endurance 25nm Vs 34nm
  1. #1851
    Apr 2011
    1
    Too bad the Intel X25-V is such a slow writer. We might have to wait a long time till it dies
  2. #1852
    May 2009
    1
    Quote Originally Posted by bulanula View Post
    I think this was the goal Intel set out from beginning. I am pretty sure they can write faster but don't, for exactly this reason.
  3. #1853
    Moderator Anvil's Avatar
    Apr 2008
    Norway
    32
    It's not an issue at all imho, it's a low capacity SSD, one does not do much sequential writes at all and for random writes they do very well.
    I've got 3x (1x Kingston and 2x Intel) running as boot drives, the one thing I do notice is that 40GB is on the small side and so I might have to replace one or two of them with a 60-64GB drive.
    Hardware:
  4. #1854
    SSDabuser Christopher's Avatar
    Aug 2011
    The Rocket City
    63
    I moved the Mushkin last night to a SATA II notebook. I didn't have a Win7 image for it, so I had to install Win7 from a flash drive.
    It took two attemps. The drive disconnected/became unresponsive half way through file expansion the first time. I gave it the benefit of the doubt and just assumed that it could have been something else (but not likely).
    It's been running nonstop since, but at a greatly reduced speed -- 26MBs+ less average.
    Anvil, I have seen the wear range delta go down with the Mushkin, but infrequently.
    You'd have to pry my X25-V's out of my cold, dead hands. I love those things. They are perfectly capable of giving you the random performance and read performance to make a great boot drive, and are nifty when RAIDed. I tried to buy two more at an auction, but got out bid. I think they're a better boot drive than any Indilinx was at the time.
  5. #1855
    Apr 2008
    Norway
    32
    Kingston SSDNow 40GB (X25-V)
    351.99TB Host writes
    Reallocated sectors : 8
    MD5 OK
    34.91MiB/s on avg (~25 hours)
    Corsair Force 3 120GB
    01 90/50 (Raw read error rate)
    05 2 (Retired Block count)
    B1 38 (Wear range delta)
    E6 100 (Life curve status)
    E7 84 (SSD Life left)
    E9 71321 (Raw writes)
    F1 95054 (Host writes)
    106.29MiB/s on avg (~25 hours)
    power on hours : 271.
    @Christopher
    I've checked where/when it stops in the loop and it is not any particular part, it does look to occur mostly during deleting files or within a few 1000 files after a new loop is started.
    I've seen it happen at the end of the loop as well so it is not related to any fixed part, it's just looks to be more likely to happen when the drive is stressed.
    If/when it disconnects again have a look in the TEST folder, there will be remains of the previous session.
    (you'll know where it was by looking at the number of files and the file names)
    Hardware:
  6. #1856
    Aug 2011
    The Rocket City
    63
    Anvil,
    Also you can tell just by the available free space.
    The first three crashes did occur at the end of the loop during deleting, but after that the crashes were different as I've explained before. I've moved the Mushkin from the laptop back to the main rig, so we'll see...
    Also, I initially tried using the Mushkin on one of the SATA II ports on my P67 motherboard and speeds were only a few MBs less. On a Core 2 Duo's SATA II ports, you lose >20%.
    I have a good feeling about the drive's prospects from now on.
  7. #1857
    Jun 2011
    Norway
    86
    Update
    m4:
    553.9945 TiB
    2049 hours
    Avg speed 91.17 MiB/s.
    AD gone from 38 to 34.
    P/E 9696.
    MD5 OK.
    Still no reallocated sectors
    Name:  M4-CT064 M4SSD2 SATA Disk Device_64GB_1GB-20110928-2318-3.png
Size:  35.1 KBName:  M4-CT064 M4SSD2 SATA Disk Device_64GB_1GB-20110928-2318-2.png
    Kingston V+100
    77.1746 TiB
    ? hours
    Avg speed 73.26 MiB/s.
    AD gone from 129 to ?.
    P/E ?.
    MD5 OK.
    Anyone got a tip how I can extract the smartinfo when the Kingston runs from the Jmicron controller?
    1: AMD FX-8150-Sabertooth 990FX-8GB Corsair XMS3-C300 256GB-Gainward GTX 570-HX-750
    2: Phenom II X6 1100T-Asus M4A89TD Pro/usb3-8GB Corsair Dominator-Gainward GTX 460SE/-X25-V 40GB-(Crucial m4 64GB /Intel X25-M G1 80GB/X25-E 64GB/Mtron 7025/Vertex 1 donated to endurance testing)
    3: Asus U31JG - X25-M G2 160GB
  8. #1858
    Aug 2011
    The Rocket City
    63
    Mushkin Chronos Deluxe 60 Update
    05 0
    Retired Block Count
    B1 18 (Down from 19)
    Wear Range Delta
    F1 67092
    Host Writes
    E9 51710
    NAND Writes
    E6 100
    Life Curve
    E7 75
    Life Left
    Average 123.44MBs.
    171 Hours Work Time
    12GiB Minimum Free Space, 0 crashes today
    SSDlife expects 19 days to 0 MWI
    Name:  Mushkin Day 7.JPG
  9. #1859
    Uber Raid King Computurd's Avatar
    Aug 2009
    Wichita, Ks
    122
    one thing that would be a tiny bit helpful (if someone has the inclination to do so) would be a list of who is running which SSD, as i am getting lost on a few of them.
    "Lurking" Since 1977
    Jesus Saves, God Backs-Up
    *I come to the news section to ban people, not read complaints.*-[XC]Gomeler
    Don't believe Squish, his hardware does control him!
  10. #1860
    Aug 2011
    The Rocket City
    63
    Quote Originally Posted by Computurd View Post
    We need a chart!
    A chart for the chart.
    With the multiple entries, it could be useful. For instance, before Vapor's chart update, I didn't realize how many drives were actually running.
    Anvil
    Force 3 120GB
    X25-V 40GB (Kingston flavored)
    One Hertz
    Intel 320 40GB
    B.A.T.
    M4 64GB
    Kingston 100+ 64GB
    Bluestang
    M225 -> Vertex Turbo 64GB
    Vapor
    C300 64GB
    SF-1200 nLTT 64GB
    SymbiosVyse
    Corsair Force F40-A 40GB
    Christopher
    Mushkin Chronos Deluxe 64GB
    -- Retired --
    johnw
    Samsung 470 64GB
    Those are the currently running drives, and owners, that I can think of off the top of my head.
    SymbiosVyse doesn't ever put the name of the drive or an SSDLife/CDinfo shot, so I can never remember what he's running.
    The Samsung's not running anymore, on account of being dead and all.
    CT, Does that help?
    Vapor, could you please label the charts some where with this info?
  11. #1861
    SLC One_Hertz's Avatar
    Oct 2004
    Ottawa, Canada
    14
    459.8TB. 4145 reallocated sectors. Erase failure at 96. Reserve space at 26.
  12. #1862
    Aug 2011
    The Rocket City
    63
    I had another disconnect. Since it's a secondary drive there was no hang and I was just able to unplug the drive's power and plug it back in.
    Is it possible turning off hot-swapping for Intel RST would be able to alleviate some of my problems?
    I've heard it mentioned as a "fix" but not in a way that gives me confidence -- and at least now I can fix it without a reboot.
  13. #1863
    Jun 2011
    Norway
    86
    Quote Originally Posted by Christopher View Post
    We need a chart!
    --snip--
    You missed johnw with the Samsung 470.
  14. #1864
    Aug 2009
    Wichita, Ks
    122
    There is also some LPM stuff...dont know as i dont have any SF. but there is a long detailed process you might try over at OCZ.
  15. #1865
    Aug 2011
    The Rocket City
    63
    Quote Originally Posted by B.A.T View Post
    We need a chart!
    CT, Does that help?
    I'll add it.
  16. #1866
    Aug 2011
    The Rocket City
    63
    I did look at the OCZ forums... I kinda ranted about it the other day.
    I've seen it mentioned in the Mushkin and OCZ forum -- I think there's a BIOS setting for it, so next time I restart the machine I'll try disabling it.
    EDIT
    My Intel DP67BG doesn't have bios options. Disabling hot plug stops the drives from being treated as external drives according to OCZ. Furthermore, they claim Intel's chipset 'madness' is to blame, saying that not all P67 chipset 6gbps are the same, and that they don't manage power properly.
    Sounds fishy as hell, but maybe there is something to it. What kind of power management do the drivers try to do besides turn the drive on or off? It does kinda act like an external drive at times. I'll see if I can disable hot plug through regedit.
    Looks like the Intel BIOS just enables it by default -- which is good because OCZ says to enable hotplug. All my LPM stuff is fixed anyway in the registry... so that doesn't really leave much. It crashes more with the msahci drivers so that doesn't leave much that I can do besides try a different motherboard, or get a Marvel controlled PCIe adapter to put the drive in.
  17. #1867
    Apr 2011
    1
    What is the next SSD victim ?
  18. #1868
    Apr 2008
    Norway
    32
    353.66TB Host writes
    MD5 OK
    This time it lasted for ~33 hours.
    It disconnected again last night 07:01 CET, so about 6 hours ago and again while deleting files, this time all files were deleted.
    I'll move it to another rig this weekend just to see what happens. (another Z68)
    01 120/50 (Raw read error rate)
    B1 40 (Wear range delta)
    E7 83 (SSD Life left)
    E9 73936 (Raw writes)
    F1 98538 (Host writes)
    power on hours : 281.
    Hardware:
  19. #1869
    Aug 2011
    The Rocket City
    63
    I've lost about 18 hours in the past week to disconnects... It disconnected again again last night about an hour after I went to bed. The worst time that it can happen.
    This weekend I'm going to swap out motherboards for an H67 and just hope that helps.
  20. #1870
    Apr 2008
    Norway
    32
    I might try one of the other (non SB/PCH) ports on the current rig, not sure what it is but it's one of the typical add-on controllers.
    If that doesn't work out I'll try the lsi 9211, if SMART still works that is.
    It's annoying alright but I'm not giving up on the drive.
    Hardware:
  21. #1871
    Aug 2011
    The Rocket City
    63
    Quote Originally Posted by Anvil View Post
    No, I won't be giving up either, but that doesn't mean I'm at all pleased with some of the nonsensical explanations and voodoo magic solutions. I think this is how many of the Vertex 3 owners felt after the products' launch, and part of me just wonders if the some of the SF 2281 controllers are just faulty. If worse comes to worse, I'll swap it out under warranty and try with another... But that's the worst case scenario.
    Until I switch to another motherboard, I've switched to a SATA II port, so we'll see if it helps. I tried it last week, but just to see what kind of speeds I'd achieve.
    With the P67's 6gbps port I was getting 122 - 124 MBs avg.
    With the P67's 3gbps port I'm getting 117 - 119 MBs avg.
    With a C2D ICH8m SATA II laptop I was getting about 94 - 96 MBs.
    I can live with 118MBs if it means I can make it through the night, but I'm not sure that Sata II ports are any less prone.
  22. #1872
    Feb 2006
    Stuttgart, Germany
    7
    I would be interested to know if the issues are more hardware related or there's a combination of hardware-software (drivers with issues that occur under certain conditions). For ruling out software, you could install a Linux distribution and run any program that would generate continuous writes, as SMART parameters are already tracking everything. I know this might be a too far suggestion but it might worth trying.
  23. #1873
    Jun 2011
    Norway
    86
    Update
    m4:
    561.2012 TiB
    2073 hours
    Avg speed 88.88 MiB/s.
    AD gone from 34 to 30.
    P/E 9818.
    MD5 OK.
    Name:  M4-CT064 M4SSD2 SATA Disk Device_64GB_1GB-20110929-2319-3.png
Size:  36.4 KBName:  M4-CT064 M4SSD2 SATA Disk Device_64GB_1GB-20110929-2319-2.png
    Kingston V+100
    80.6501 TiB
    323 hours
    Avg speed 79.01 MiB/s.
    AD gone from 129 to 116.
    P/E ?.
    MD5 OK.
    Name:  KINGSTON  SVP100S264G SATA Disk Device_64GB_1GB-20110929-2340-3.png
Size:  40.7 KBName:  KINGSTON  SVP100S264G SATA Disk Device_64GB_1GB-20110929-2340-2.png
    While I was at work ASU reported errors and froze. I could open folders and files on the SSD but ASU had no response. I shut it down and tried to open it again. Now the startscreen came up but the program froze while trying to load information. I powered down the rig and tried a restart. Next problem now was that the JMicron optionrom couldn't find the Kingston so I disconected it and took a new restart.
    I moved the Kingston til SB850 and got help for Anvil to restore the log and now all runs normal again. The MD5 check showed no errors so I don't know what caused all of this.
    Here is a screenshot of ASU with the error message.
  24. #1874
    Apr 2008
    Norway
    32
    355.18TB Host writes
    MD5 OK
    36.97MiB/s on avg (~12 hours)
    B1 42 (Wear range delta)
    E7 82 (SSD Life left)
    E9 77332 (Raw writes)
    F1 103064 (Host writes)
    107.48MiB/s on avg (~12 hours)
    power on hours : 293
    @sergiu
    Not very likely, it would be the last thing I'd try, if there is something to the SF/SB platform mix that stinks I'll make sure to test on other SB computers and then go down the X58 route as well before trying another OS/platform.
    Hardware:
  25. #1875
    Aug 2011
    The Rocket City
    63
    05 0
    Retired Block Count
    B1 19 (Up from 18)
    Wear Range Delta
    F1 74681
    Host Writes
    E9 57563
    NAND Writes
    E6 100
    Life Curve
    E7 72
    Life Left
    Average 116.41MBs. P67 SATA II
    119 Hours Work Time
    SSDlife expects 18 days to 0 MWI
    Name:  Mushkin day 8.JPG
    I've lost a lot of time with the issues I've had. I'm running it on SATA II until it crashes again, then I'm switching motherboards to see if it helps.
    EDIT
    I've heard that the Marvel controlled SATA III ports have problems too, but instead of switching to another 1155 board, I think I'll get a PCIe SATA III controller. If that doesn't work, I'll buy some kind of HBA. If that doesn't work, I'm flying to Sandforce HQ to yell at someone.
+ Reply to Thread
Tags for this Thread
