Page 219 of 220 FirstFirst ... 119169209216217218219220 LastLast
Results 5,451 to 5,475 of 5495
Thread: SSD Write Endurance 25nm Vs 34nm
  1. #5451
    Xtreme X.I.P.
    Apr 2008
    Norway
    Kingston SSDNow 40GB (X25-V)
    1517.82TB Host writes 49735977*32)
    Reallocated sectors : 05 769 +1
    Available Reserved Space : E8 86 (86)
    POH 14074
    MD5 OK
    31.76MiB/s on avg (~184 hours)
    Hardware:
  2. #5452
    Mar 2010
    Canada
    This is a fantastic thread! It's about time someone did this sort of testing. AFAIK not even Anand tests their drives to destruction.
    Quote Originally Posted by devsk View Post
    This is troubling, very troubling. None of the SSDs so far have gone into read-only mode upon failure. Not even the latest incarnation as of 2013. This was touted as one of the main features of SSD.
    In fact, the failure mode is hard. There is no way to get the data back and programs hang hard. Nostalgically looking, HDDs were way better in this area. I would gladly buy even a slower and slightly more expensive SSD drive which always fails into a read-only mode, leaving the data accessible.
    I agree wholeheartedly. I want to chime in, though, because I have a relevant story from the early days of SSD. Back in 2008 I bought a 128GB Memoright SSD. This was back when SSD's were pricey and very rough around the edges - the thing cost ~$2000. But the upgrade was the single biggest "you can feel it" improvement to my laptop's performance (not to mention solved my heat problem). After about two months it failed. I'm not sure what was written or what type of failure occurred. But SSD technology was new, and I was curious, so I did some non-scientific investigating. After roughly 10 minutes of use, the system would start freezing up and Windows would start reporting errors. If I rebooted immediately, the BIOS would hang for a while and not detect it. If I left the drive off for a period of time, I found I could plug it in and get about 10 minutes of use, although corruptions would be reported. Writing to the drive caused it to freeze up a lot quicker than reading. Two different computers gave identical results. Eventually I plugged it into a machine set up for recovery, using software (Acronis) that would only read from the drive. Although my read rate was incredibly slow, after many hours it did manage to read all my data off.
    I binary compared large files to what I had in backups, checked on CRC's / PAR files, and it turned out the data that had been dormant all looked good. It only seemed the very recent data had been affected by corruptions.
    Anyway I figured this seemed interesting because, although the failure mode wasn't ideal (in that the drive threw up lots of corrupted data), it did keep most of my data safe and despite being in the throws of death allowed me to read it all off. As far as I'm concerned, it fulfilled a promise here that it seems newer SSD's have all abandoned.
    Granted it could just be that I was lucky and this was a fluke occurrence of this mode of failure.
    Primary workstation (circa 2010 + upgrades):
    + Dell M6600 laptop / 2x PM830 RAID0 / 32GB RAM
    + 24-Bay 80TB whitebox SAN / Norco RPC-4224 / Asus P6T6 / Intel i7-920 / 24GB ECC RAM (for eventual Xeon)
    + Toshiba M7 Tablet PC / 120GB Intel 320 G3 SSD
    + various iPhone & Android gizmos
    + TRS-80
  3. #5453
    Sep 2007
    CA Bay Area
    Oh where oh where has everybody gone?
  4. #5454
    Mar 2010
    Canada
    Not sure.. but this thread may start getting more attention after it was mentioned in SlashDot comments:
    http://tech.slashdot.org/story/13/02...rite-endurance
    Personally, I find the real-world work folks are doing here much more compelling than the theoretical calculations that got Slashdotted. So often other factors (poor engineering, inferior firmware) have a much greater influence on failure than nand spec.
    + TRS-80
  5. #5455
    Xtreme X.I.P.
    Apr 2008
    Norway
    1572.29TB Host writes 51520860*32)
    Reallocated sectors : 05 774 +5 (769)
    POH 14799
    MD5 OK
    31.72MiB/s on avg (~334 hours)
    (It idled for about a week)
    Hardware:
  6. #5456
    Feb 2013
    So is there a dummy's guide for doing these SSD writes? What software do you use, size files, etc? I'm going to get one of the Samsung 840 (not Pro) 120GB drives and torture test it. Although one thing I'd like to do is every 500 P/E cycles is do a secure erase and check performance. Thanks.
    edit: Nevermind I found the AnvilBenchmark program.
  7. #5457
    Xtreme X.I.P.
    Apr 2008
    Norway
    1609.47TB Host writes 52738985*32)
    Reallocated sectors : 05 775 +1 (774)
    POH 15138
    MD5 OK
    31.83MiB/s on avg (~338 hours)
    Hardware:
  8. #5458
    Xtreme X.I.P.
    Apr 2008
    Norway
    1638.34TB Host writes 53685046*32)
    Reallocated sectors : 05 777 +2 (775)
    POH 15401
    MD5 OK
    31.83MiB/s on avg (~600 hours)
    Hardware:
  9. #5459
    Feb 2006
    Stuttgart, Germany
    Sandforce came and went away, so it did Samsung and Marvell, yet this poor Intel drive seems it will outlive all of them.
  10. #5460
    Jul 2008
    In the space between...
    The very definition of 'slowly but surely'...lol
    'Best Bang For The Buck' Build - CM Storm Sniper - CM V8 GTS HSF
    2500K @ 4.5GHz 24/7 - Asus P8Z68-V Pro Gen3 - GSkill 2x4GB DDR3-2400 C10
    Sapphire Vapor-X 7770 OC Edition - PC Power & Cooling Silencer MkIII 600W
    Boot: 2x 64GB SuperSSpeed S301 SLC Raid 0 Work: Intel 520 120GB
    Storage: Crucial M500 1TB - Ocz Vertex 4 128GB - 4x 50GB Ocz Vertex 2
    HDDs: 2 x 1TB WD RE4 Raid0 - Ext.Backup: 2 x 1.5TB WD Blacks Raid 1
  11. #5461
    3rase
    Guest
    A test on the 256GB OCZ Vector would be interesting. Unfortunately I have neither the money nor any PC to test it 24/7. Is anyone on the Vector right now?
  12. #5462
    Feb 2012
    Perth, Australia
    Quote Originally Posted by 3rase View Post
    Look at how my vertex 4 tests went ... a vector would behave quite similarly (but not as strongly as the 120gig version of course)
  13. #5463
    Xtreme X.I.P.
    Apr 2008
    Norway
    1696.02TB Host writes 55575099*32)
    Reallocated sectors : 05 788 +11 (777)
    POH 15927
    MD5 OK
    31.69MiB/s on avg (~527 hours)
    Hardware:
  14. #5464
    Xtreme Cruncher
    Jan 2009
    The Hague, Netherlands
    Thank you for keeping updating Anvil!
    I am still amazed this old little Intel SSD keeps on going.
    3770K 4.7Ghz 1.32v / ASUS P8Z77-V PRO / 8GB DDR3 1866 9-9-9-27 /ASUS HD7970 1025MHz / Antec NeoHE 550 / Samsung 830 256GB Crunching
    Cooled by PA120.3, EK-HF, D-tek Fuzion GFX, DDC3.1 XSPC res/top
    i5 2400 Stock / ASUS P8P67 LE / 4GB DDR3 1600 / Seasonic S12II 430W / Intel G2 40GB Crunching
    2600K 4.6Ghz 1.34v / ASUS P8Z68-V PRO / 8GB DDR3 1600 8-8-8-24 / Antec 430W / Intel G2 80GB Crunching
    W3520 4.0Ghz 1.19v / Rampage II Gene / 6GB Kinston Value 1333 / 9800GT / Corsair TX650 / Antec mini P180 / Intel G2 160GB Crunching
    Intel G860 Stock / Gigabyte H67MA-UD2H-B3 / 4GB DDR3 1333 / Antec Earthwatts green 380W / Crucial M4 64GB Crunching
    E6600 3.2Ghz 1.36v - P5B Deluxe / i7 930 4.0Ghz 1.29v - ASUS P6X58D-E / Q9450 3.6Ghz 1.28v - Rampage Formula Retired
  15. #5465
    Apr 2013
    Hvar,Croatia
    Hey people i register just to say some things.
    I follow this thread about one year now and this is something amazing that you do here.You crash your SSDs so SSD manufacturers cant lie to us,consumers,about their endurance.
    Man,a lot of people must thank you.
    THANK YOU
    I want to say one more important thing.It seems that this thread is cooling down and this is something we can not allow!
    I believe,a lot of people will like to know Vector,840 PRO and Corsair Neutron endurance.
    So i suggest that you open thread(or in this) where you(moderator)will select 5 latest drives and everyone will be able to participate with at least 1$ to buying process,of SSD they want to see in endurance test.
    I would be the first person that will participate with 10$ for testing Samsung 840 PRO 128GB.
  16. #5466
    Xtreme Legend
    Mar 2008
    Plymouth (UK)
    Wrong place to ask I know..... but given a worst case scenario running 24/7 of 6144GB of writes daily, let's assume non-compressible, choose a drive:
    Samsung 840pro or Intel 520? Here, they cost a similar amount for a 128/120
    Much as I have followed this thread for ages I feel I still want some of you specialists to comment on this
    Back to topic: I too would chip in for purchase of drives to be endurance tested
    My Biggest Fear Is When I die, My Wife Sells All My Stuff For What I Told Her I Paid For It.
    79 SB threads and 32 IB Threads across 4 rigs 111 threads Crunching!!
  17. #5467
    Jul 2008
    non-compressible is 520's (SandForce's) worst enemy. Sammy 840 Pro is the winner easy.
  18. #5468
    Dec 2005
    NYC
    When will we be seeing petabytes in this count? (1 billion gigabytes)
  19. #5469
    Oct 2012
    Asuncion, Paraguay
    Quote Originally Posted by pH(x) View Post
    Just one page behind is the chart with the petabytes..
  20. #5470
    Xtreme X.I.P.
    Apr 2008
    Norway
    1759.1TB Host writes 57642046*32)
    Reallocated sectors : 05 799 +11 (788)
    POH 16528
    MD5 OK
    31.83MiB/s on avg (~515 hours)
    8 more days, and it's been 2 years!
    Hardware:
  21. #5471
    Jul 2008
    2 years indeed....chuggin' on....slowly but very surly, lol
  22. #5472
    Feb 2006
    Stuttgart, Germany
    What happened with this thread? As far as I see, with some small exceptions, it's almost dead from the end of January 2013.
  23. #5473
    Aug 2010
    Bump, keep the challenge going!
  24. #5474
    Nov 2005
    We should start doing bounties to test drives, lol. I'm wondering how the new Samsung 840 EVO's will perform.
    -Cpu:Opteron 170 LCBQE 0722RPBW(2.87ghz @ 1.300v)
    (retired)Opteron 146 (939) CAB2E 0540
    -Heatsink: Thermalright XP-90
    -Fan:120mm Yate Loon 1650 RPM @ 12V, 70.5 CFM, 33dB
    -Motherboard: DFI Lanparty nF4 UT Ultra-D
    -Ram: Mushkin High Performance blue, 2gigs(2X1gig kit) PC3200 991434
    -Hard drive: Seagate 400GB Barracuda SATA HD 7200.10(AS noisey model)
    -Video card: evga 6800GS @520/1170
    -Case: P180
    -PSU:Enermax 535Watt EG565P-VE FMA (24P)
  25. #5475
    Nov 2009
    Fantastic thread! Thank you for all the hard work you've done. Really, thank you.
    I'd love to chip in with some $$ for a 840 EVO SSD purchase for it to be tested. Going to get one of them myself as well.
Tags for this Thread
