+ Reply to Thread
Page 102 of 220 FirstFirst ... 2 52 92 99 100 101 102 103 104 105 112 152 202 ... LastLast
Results 2,526 to 2,550 of 5480
Thread: SSD Write Endurance 25nm Vs 34nm
  1. #2526
    Registered User Hopalong X's Avatar
    Jun 2011
    0
    It is rated at 1 year after hitting MWI-1.
    How far was the M4 past the MWI-1?
    It hit MWI-1 at 178TiB. It was up to around 600TiB of writes if memory serves.
    Way past MWI 1. If it had been stopped at that point it should have held its data as speced.
    After that holding data is questionable to length of time.
    Same as asking how long it will continue to write data.
    You are all making the new specs with the testing.
  2. #2527
    Xtreme Addict bluestang's Avatar
    Nov 2008
    NE Ohio, USA
    102
    Quote Originally Posted by devsk View Post
    May be we should take a break on Vertex Turbo and have it sit idle, powered off for few days to see if it still keeps going! I have a vague memory that bluestang has been powering it off during the day on working days.
    Nope, I don't power it off. It's still connected. I just usually have to boot into XP during the day, except for this past week I've been staying in Win7 to try and catch the M4
    Home PC -- Cruncher #1 WCG ~24/7
    GA-P67A-UD4-B3 BIOS F8 modded, i7-2600k (L051B138) @ 4.5 GHz, 1.260v full load, HT Enabled, Corsair H70 exhausted @ 1600rpm
    Samsung Green 2x4GB @2133 C10, Gigabyte 7950 @1200/1250, Vertex 4 128GB, 2x3TB WD Red, F4EG 2TB, BR Burner, Win7 Ult x64, CM690 w/RPP 550
    Work PC -- Cruncher #2 WCG ~24/7 ... Crucial M225 64GB SSD Donated to Endurance Testing (Died at 968 TB of writes...no that is not a typo!)
    GA-EP45T-UD3LR BIOS F10 modded, Q6600 G0 VID 1.212 (L731B536), 3.6 GHz 9x400 @ 1.312v full load, Zerotherm Zen FZ120
    OCZ 2x2GB DDR3-1600MHz C7, MSI 7770 @1200/1050, Vertex 2 60GB, 2x500GB Hitachi R1, Win7 Ent x64, Centurion 590 w/Coolmax 600w
    Music System
    SB Server->SB Touch w/Android Tablet as a remote->S/PDIF->Kenwood Sovereign VR-4090B->JBL Studio Series Floorstanding Speakers
  3. #2528
    Jun 2011
    Norway
    86
    This was my last result update.
    m4
    768.5687 TiB
    2749 hours
    Avg speed 88.43 MiB/s.
    AD gone from 171 to 169.
    P/E 13330.
    Value 01 (raw read error rate) has changed from 43 to 46.
    MD5 OK.
    Reallocated sectors : 00
    The M4 passed MWI-1 at 170.8 TiB.
    There were no problems before I turned my rig off the 28th oct. It just didn't like 9 days without power.
    1: AMD FX-8150-Sabertooth 990FX-8GB Corsair XMS3-C300 256GB-Gainward GTX 570-HX-750
    2: Phenom II X6 1100T-Asus M4A89TD Pro/usb3-8GB Corsair Dominator-Gainward GTX 460SE/-X25-V 40GB-(Crucial m4 64GB /Intel X25-M G1 80GB/X25-E 64GB/Mtron 7025/Vertex 1 donated to endurance testing)
    3: Asus U31JG - X25-M G2 160GB
  4. #2529
    Feb 2006
    Stuttgart, Germany
    7
    Sad... I was really hoping to see M4 past 1TB. Maybe P/E rating is not conservative at all considering the requirements. I believe it would be better to add a 7-14 days of rest between each 100TB milestone, to check data retention.
  5. #2530
    Moderator Anvil's Avatar
    Apr 2008
    Norway
    32
    It's not like it was expected to fail but we are way beyond the specs
    The spec is 72TB for the Crucial iirc.
    I don't think it matters if the pause was 7 or 9 days, it might fail withing hours of disconnecting but we will never know what really happened to B.A.T's drive. It would have been interesting to know if it was a NAND failure or some other part that caused the failure.
    As a result of this failure I'll be playing it a bit safe on my drives, I'll start off with 12 hours and then increase in 12hour steps up to 4-5 days.
    My drives are turning 500TiB within a few weeks, the Force 3 is not down to MWI 0 yet though, it will be before it hits 500TiB.
    Hardware:
  6. #2531
    Apr 2011
    1
    Too bad to see the M4 die like that. BUT where is the C300. That should be able to do 1 PB I think quite easily. Vapor, where are you LOL ???
  7. #2532
    SSDabuser Christopher's Avatar
    Aug 2011
    The Rocket City
    63
    So it looks as though even though the M4 had no bad blocks, the NAND just couldn't hold a charge in each cell without power. If that is the case, you'd expect the Vertex Turbo to go much longer while retaining data. I guess at some point these drives just become volatile storage, but I'm more than a little surprised that the M4 never flagged any of these blocks as anything but good.
    I still don't know why Crystal Disk Info keeps emailing me with [601] and [701] BAD messages, nor why Windows thinks the Mushkin is dying too. Perhaps they know something I don't?
  8. #2533
    Nov 2008
    NE Ohio, USA
    102
    Quote Originally Posted by B.A.T View Post
    My raw read error rate has actually been decreasing since the start.
    Quote Originally Posted by Christopher View Post
    Have you looked in your Windows Event Viewer for any errors for that disk?
    Music System
  9. #2534
    Apr 2008
    Norway
    32
    You should be able to disable the emails, the CDI messages are most likely based on SMART, there is no other source of info for the drives.
    (unless there are issues related to the drive that are found in the Event log, as in e.g. timeouts, which is not very likely as it should show in other ways)
    Hardware:
  10. #2535
    Aug 2011
    The Rocket City
    63
    Of course I can disable the emails, but nothing has changed with the Mushkin in weeks, really. Looking at the SMART data, I can't determine why it is that Windows and CDI seem to think there is something wrong.
    The Event Viewer does show a couple of generic SMART based "your drive is going to die" errors. I was just wondering why - if it's based on MWI, then why didn't Windows protest much earlier? It's been at MWI 10 for almost 200TB, and that's the only questionable SMART attribute. I had set up the CDI emails to alert me if anything interesting had happened while I was away, and I'm more curious as to why Windows has a problem now, and not earlier if it's just based on MWI depletion.
  11. #2536
    Apr 2008
    Norway
    32
    Kingston SSDNow 40GB (X25-V)
    455.80TB Host writes
    Reallocated sectors : 12
    MD5 OK
    34.10MiB/s on avg (~47 hours)
    Corsair Force 3 120GB
    01 90/50 (Raw read error rate)
    05 2 (Retired Block count)
    B1 64 (Wear range delta)
    E6 100 (Life curve status)
    E7 16 (SSD Life left)
    E9 317600 (Raw writes)
    F1 422741 (Host writes)
    MD5 OK
    106.85MiB/s on avg (~47 hours)
    power on hours : 1240
    B1 is down from 66 to 64.
    @Christopher
    It would have helped if you posted some screenshots (I know they don't work)
    CDI is not some magical tool, it reports when values are below thresholds, some SMART values are said to predict failures and some are not. If the SMART value is said to be predicting failure it's likely that CDI will generate an event/warning.
    The SMART attributes that predict failure are the following (for a typical SF2xxx series drive)
    1, 5, C4, E6 and E7
    Hardware:
  12. #2537
    Aug 2011
    The Rocket City
    63
    Mushkin Chronos Deluxe 60 Update, Day 46
    3.3.2FW
    05 5
    Retired Block Count
    B1 10
    Wear Range Delta
    F1 453641
    Host Writes
    E9 350000
    NAND Writes
    E6 100
    Life Curve
    E7 10
    Life Left
    Average 132.11MB/s Avg
    Intel RST drivers, Celeron G530 Biostar TH67+
    1066 Hours Work
    Time 1 month 14 days 10 hours
    12 GiB Minimum Free Space
    I feel like I'm really making some progress now. Host writes just hit 350TB, and speed seems to be marginally higher.
    I traded out another drive for my FW0001 M4 64GB drive last weekend, and I've been playing with it. The lack of SMART attribs to capture host writes is irritating though.
  13. #2538
    Apr 2008
    Norway
    32
    457.38TB Host writes
    MD5 OK
    33.79MiB/s on avg (~61 hours)
    01 94/50 (Raw read error rate)
    B1 63 (Wear range delta)
    E7 14 (SSD Life left)
    E9 321580 (Raw writes)
    F1 428041 (Host writes)
    MD5 OK
    106.87MiB/s on avg (~47 hours)
    power on hours : 1255
    B1 is down from 64 to 63.
    Hardware:
  14. #2539
    Nov 2008
    NE Ohio, USA
    102
    M225->Vertex Turbo 64GB Update:
    693.57 TiB (762.58 TB) total
    1816.79 hrs (Torture), 2615 hrs (Power-On)
    13716 Raw Wear
    122.49 MB/s avg for the last 69.19 hours (on W7 x64)
    MD5 OK
    C4-Erase Failure Block Count (Realloc Sectors) from 11 to 12.
    (1=Bnk 6/Blk 2406; 2=Bnk 3/Blk 3925; 3=Bnk 0/Blk 1766; 4=Bnk 0/Blk 829; 5=Bnk 4/Blk 3191; 6=Bnk 7/Blk 937; 7=Bnk 7/Blk 1980; 8=Bnk 7/Blk 442; 9=Bnk 7/Blk 700; 10=Bnk 2/Blk 1066; 11=Bnk 7/Blck 85; 12=Bnk 4/Blk 3192)
    I have no plans on doing a power-off state on the M225 until I reach 1 PB
    P.S. -- Any mods reading this thread want to get the darn attachments fixed already!
    Music System
  15. #2540
    May 2009
    1
    Quote Originally Posted by bluestang View Post
    That's a good plan... I want to see it hit 1PB as well.
  16. #2541
    Xtreme Mentor Ao1's Avatar
    Feb 2009
    35
    You guys all missed a key milestone. This thread has passed ½ million views
  17. #2542
    Feb 2009
    35
    Agreed.
    This data retention issue does however bring an element of frustration to the testing. Is a year unreasonable? How much of an impact does that requirement have on how the MWI is calculated? At what point should you stop writing and for how long should you then wait?
    On one hand a year sounds way to long, but on the other hand I’ve got loads of HDD’s that have been sitting around for years with data backups on them. I’d be pretty hacked if I plugged one of them in to find out it had lost the data. Guess HDD’s will be around for a bit yet, even if they end up only being used for archives.
  18. #2543
    Apr 2008
    Norway
    32
    Data retention would have shown it's ugly face somewhere down the road anyways.
    I'd say it was about time we had to acknowledge that it is a real issue, it is not an issue for normal wear though.
    It leaves a lot of questions though.
    And now for something completely different
    The Samsung 830 series does carry a Host Write attribute.
    F1 shows host writes in sectors. (512 byte sectors)
    Could be that there are more interesting attributes but F1 and BE are the ones that have changed during testing.
    Hardware:
  19. #2544
    Jun 2011
    Norway
    86
    Todays update:
    Kingston V+100
    196.4984 TiB
    776 hours
    Avg speed 75.40 MiB/s
    AD gone from 4 to 1.
    P/E?
    MD5 OK.
    Intel X25-M G1 80GB
    20,8113 TiB Host writes
    18739 hours
    MWI=75 to 65
    MD5 OK
    45.11 MiB/s on avg
  20. #2545
    Apr 2008
    Norway
    32
    I'm already missing the m4
    Hardware:
  21. #2546
    Apr 2008
    Norway
    32
    458.60TB Host writes
    MD5 OK
    33.63MiB/s on avg (~72 hours)
    01 86/50 (Raw read error rate)
    B1 62 (Wear range delta)
    E9 324624 (Raw writes)
    F1 432090 (Host writes)
    MD5 OK
    106.89MiB/s on avg (~72 hours)
    power on hours : 1265
    B1 is down from 63 to 62.
    Hardware:
  22. #2547
    Apr 2011
    1
    Strange thing no reallocated sectors were reported before it just died. Anyone else thinking controller failure and NAND is still OK. Too bad we don't have the equipment to confirm that the NAND is fine etc.
  23. #2548
    Aug 2011
    The Rocket City
    63
    Maybe something kept the M4 controller from reinitializing on power on? I find it hard to believe that the M4 just quit working after being powered off for a few days. But the drive can't be seen by the bios at all, so its pretty much dead.
    That's not satisfying at all.
  24. #2549
    Banned
    Jan 2010
    Las Vegas
    16
    Quote Originally Posted by Anvil View Post
    I'm thinking that a good way to test in the future is a one-week-on, one-week-off sort of thing (or maybe two or three on, one off). It is interesting to know how much can be written if the SSD is kept powered on all the time, but I think a more useful thing to know is how much can be written while still maintaining a one-week power-off data-retention time. Of course, it would be better to know the value for something like a 3-month power-off data-retention time, but that would take too long to measure if you had to stop writing for 3 months after every 25TiB (or whatever accuracy you want for the measurement).
  25. #2550
    Banned
    Jan 2010
    Las Vegas
    16
    I think it is obvious what happened. Same as happened to the Samsung 470. Once the unpowered data-retention time gets down to a few days, powering off the SSD for several days causes most of the flash to lose its charge. Since the SSD stores critical metadata on the flash, the SSD cannot operate once most of the flash has lost its charge.
+ Reply to Thread
Tags for this Thread
