So I aquired this XSPC RS240 rad from my Nephew that bought a XSPC Rasa 750 kit, he could not use the rad so I gave him $30 for it, to put towards the BI GT Stealth 280 he needed.
Anyhoo I decided to mod (solder) a fillport on it so I could use it with a H50 I have in one of my systems.
Paint scraped back and fillport soldered on with a propane torch (on low), and silver bearing solder! I made the fill port out of a brass 1/4 threaded pipe cap (homedepot ~$1.50) and drilled a hole through it.
Masked, prepped, and ready for a fresh coat of gloss black enamel. I like shine, guess I'm old school, so hater's don't hate
EDIT: Make sure you wait for the paint to be dry to the touch first(i.e. when you touch it it should not be sticky)
Now lets bake. 175 fahrenheit for 1 hour. Why? Two reasons, 1). It greatly ruduces paint cure time, and 2). The paint will tighten, and smooth out any wrinkles, and melt down any over spray.
And here she is fresh out of the oven! Paint is fully cured, and very smooth.
More to come soon.
