I have researched this for hours and haven't found a definitive answer regarding this particular board
I hear the REGULAR P8p67-m suks because no vcore adjustment
therefore based on a review or two i read i'm guessing the next one up
the P8P67-M-PRO is doable for 4.0+-4.5ghz when used with a Intel S.B. 2500K??
correct????
- been doing this long enough to figure it out - just concerned whether the two things left with are available on this new EFI thingy??? - (specifically this model??)
mainly vcore adjust and ratio adjust???
personally i think this is b.s. - they should have slight or major oc-ing available across all cpu's and all boards - entry or pro...but hey
they gotta sell you the p67 line right??? - i get it....
not to mention that fsb/bclk - a major player is essentially DEAD
but enough of the bad news
there is A MAJOR bright side
i noticed i can buy a 2500k sandy cpu for 220.00 Canadian which should smoke the old QX9770 at stock performance WHICH STILL RETAILS ON EBAY FOR 2000.00!!!!!!! ((L.O.L.)
I mean 3.3ghz quad core for 200!!!!beautiful!!!
i'm not expecting 4.5 guaranteed or 4.8 like some people get with this especially after that dreaded i3 550 incident last year
i just need some confirmation on this board
(as to whether the vcore is adjustable and the ratio/multi)
THANKS
