+ Reply to Thread
Results 1 to 4 of 4
Thread: Whats the best LED 140MM case fan?
    Xtreme Addict Demo's Avatar
    Jun 2006
    1
    Im thinking of changing the 140mm intake fan from the Lian Li PC-P80 what LED 140mm fan can you guys recommend? The color does not matter since im gonna replace it with white anyway.
    Xtreme CCIE Serra's Avatar
    Dec 2004
    St. Louis, MO
    0
    Define "best". Quiet? High Airflow? Is the fan being used against something restrictive?
    Also: LED? Does "LED" mean "clear plastic" to you? What about colored plastic? UV-reactive?
    Dual CCIE (Route\Switch and Security) at your disposal. Have a Cisco-related or other network question? My PM box is always open.
    Xtreme Network:
    - Cisco 3560X-24P PoE Switch
    - Cisco ASA 5505 Firewall
    - Cisco 4402 Wireless LAN Controller
    - Cisco 3502i Access Point
    Oct 2009
    0
    Quote Originally Posted by Demo View Post
    I have two 140mm xigmatek xlf-f1254 fans that I love. Great airflow and low noise. Plus they already have white LEDs. The fan blade also come in orange or blue, both with white LEDs.
    Jun 2006
    1
    Quote Originally Posted by Serra View Post
    Best airflow to noise ratio, LED color plastic does not matter as long as it lights up and can be easily modded to white. Non UV-reactive please.
    EDIT:
    The coolermaster R4 seems reasonable, would anyone know the type of LED used on them if its the regular large diodes that can be easily replaced?
+ Reply to Thread
