Page 1 of 2 12 LastLast
Results 1 to 25 of 47
Thread: [Skinnee Labs] CPU Block Thread, 2011 Edition
    Admin
    Feb 2005
    Ann Arbor, MI
    Intro
    This is the full collection of the results in the 2011 CPU Block Roundup and when new results go up, this post will be updated. In this compilation post, the overall performance overview will be slightly simpler, with the full in-depth look available in the individual reviews. Things like installation procedures, block photographs, and the full write-ups will also be in the individual reviews.
    This post will be used as a single stop to get caught up on all the blocks tested and the core test results. You'll see charts with all the latest data. You'll see a quick written summary of each block. You'll see the upcoming schedule of blocks. You'll find links to all the individual reviews and supplements conducted.
    To read the how/what/why of our testing, please read any of the reviews. To get our full impressions of any specific block, please read the review for that specific block.
    The quick version of how I test: 7 mounts with Arctic Cooling MX-2, 7 mounts with AquaTuning Silver Grease, 7 mounts with stock TIM, 2 Indigo Xtreme mounts (each with 9 pump settings tested). Each run/mount is 2.5 hours long, first 30min are warmup, last two hours are averaged to get the final value. All probe temperatures are logged every second (4 CPU sensors, 12 water probes, 12 air probes). CPU sensors are linearized to the 24 Dallas One-Wire probes (hugely important); all 24 DOW probes are calibrated to each other. Water temperature = average of block inlet and outlet temperatures. OCCT3.1 Small Data Set used for loading. i7 930 @ 3800MHz with 1.52v (BIOS setting), consistently 179W output (measured via flowrate * (block out - block in) * specific heat of H2O).
    Individual Reviews
    Koolance CPU-370 (also tested: Enzotech Stealth, Koolance CPU-360r1.1)
    EK Supreme HF Full-Nickel rev2 and rev3 (rev3 = Easy Mount and MX-4)
    Aqua Computer cuplex kryos HF
    Swiftech Apogee XT rev2
    Watercool Heatkiller 3.0b Ni-Bl (in progress)
    Swiftech Apogee XTL (next)
    XSPC Rasa (upcoming)
    Supplements
    CPU Block Fitting Compatibility
    Thermal Performance
    It's important to note that all flowrate/pump setting/hydraulic power spectrum tests are done with Indigo Xtreme (has zero performance change over time, unlike any thermal paste) and then justified to the blocks' MX-2 performance.
    (*) TIM likely has a cure that might induce error in these results and will also likely have these results overestimating final performance.
    Pressure Drop, Flowrate, and Restriction
    Of note, "Restrictiveness" is a unitless metric measuring restriction and is effectively, not literally, an inverse of measured flowrate--lower means less restrictive. It's a sum of pressure drop readings at the eight lowest pump settings we test.
    TIM Dependence, Mounting Variation, and Flow Responsiveness
    Mounting System Comparison
    Quick Takes
    • Overall great performing block
    • Medium-high restriction (appropriate and acceptable)
    • Mounting system's initial installation is not easy or straightforward
    • Mounting system's thumbscrews rough on the fingers, not compatible with any tools
    • Mounting system has set stops for even pressure at all corners
    • Block assembly isn't dead easy--mounting plates do not rest in their final position
    • Intel or AMD mounting brackets included, not both
    • Decent fitting compatibility
    • Comes with a great TIM, Prolimatech PK-1; little reason to buy any other TIM
    • Noticeably expensive, ~$99
    EK Supreme HF Full-Nickel rev3
    • Low restriction
    • Excels with premium TIM (Indigo Xtreme, PK-1, etc.)
    • Mounting system (Easy Mount) initial installation is not easy or straightforward
    • Mounting system's thumbscrews are easy on the fingers but not compatible with any tools
    • Mounting system repeated use is easy
    • Mounting system doesn't provide much mounting pressure; performance losses compared to rev2 mounting
    • Block assembly isn't dead easy--major o-ring held in place by two separate objects and can fall out; injection plate has no 'home' on the top
    • Intel and AMD mounting brackets included
    • Great fitting compatibility
    • Comes with a good TIM, Arctic Cooling MX-4
    • Expensive, ~$90
    Enzotech Stealth
    • Overall very good performing block
    • Scales with TIM--using a really good TIM is recommended
    • Mounting system's thumbscrews are not very easy on the fingers and not compatible with any tools
    • Mounting system does not have set stops for even pressure at all corners
    • Mounting system repeated use is somewhat easy
    • Mounting system is fragile--broke two LGA1366 adapter kits in three mounts.
    • Mounting bracket is a floating bracket and causes a lot of inconsistency
    • Block assembly is pretty easy; 2mm hex screws do strip too easily, however
    • LGA775 mounting as stock, comes with LGA1366 adapter; AMD and LGA115x adapters sold separately
    • Comes with a mediocre TIM, Arctic Silver Ceramique
    • Moderately priced, ~$75
    • Overall good performing block; can't reconcile why this CPU-360r1.1 did not perform as well in this roundup as the old block and roundup
    • Low restriction
    • Mounting system's initial installation is easy; nothing installed onto the motherboard
    • Mounting system's thumbscrews are very easy on the fingers but not compatible with any tools
    • Mounting system has set stops for even pressure at all corners; tightening to the stops may provide too much mounting pressure
    • EOL
    Koolance CPU-370
    • Medium-low restriction
    • Makes tremendous contact; performance not very dependent on TIM
    • Block assembly is pretty easy; Torx screws will not strip
    • Fairly expensive, ~$85
    • Medium-high restriction with inlet plate in the stock position
    • High restriction with inlet plate in the compatibility position
    • Makes great contact without excessive mounting pressure
    • Mounting system has no initial installation
    • Mounting system’s thumbscrews are easy on the fingers and compatible with Phillips screwdrivers
    • Mounting system has set stops for even and ideal pressure at all corners
    • Intel LGA775/115x/1366 mounting bracket and backplates included; AMD bracket optional, uses inferior mounting system
    • Great fitting compatibility but requires use of alternate inlet (slight bump in restriction which lowers flowrate which hurts temperatures a tiny bit)
    • $80 MSRP (can usually be found for $70 or less, however)
    This post was last updated May 20, 2011
    Dec 2008
    EU
    nicely done as usual. lots of charts, etc...
    little bit surprised over some results and ranking, but keep up the good work.
    Cmndt. Eric Lassard: What is the most frustrating thing about police work?
    Tackleberry: Not being able to carry hand grenades, sir.
    Dec 2004
    Novi Sad, Serbia
    Thank you for the nice comparison.
    One question, though - what do you mean when you say "motherboard is not required for installation"?
    Admin
    Feb 2005
    Ann Arbor, MI
    Quote Originally Posted by jumper2high View Post
    Reworded, thanks....it means that the initial setup/installation is not installed onto the motherboard.
    With the AC/EK/Enzo systems, you install stuff to the motherboard then install the block to that. With the KL system, you assemble the backplate/post assembly and slide it onto the motherboard and install the block with that. With the Swiftech system, you just place the backplate onto the back of the motherboard and install the block with that.
    Sep 2010
    Barcelona
    Thanks for that nice review. I wiil be changing my wblock to a new Kryos HF, ( in a 775) in the next week. Should see what happens with the mounting process....as i read in your comments it,s not the best.
    I am Xtreme
    Mar 2007
    Sugar Land, TX
    Quote Originally Posted by ea3ot View Post
    Thanks for that nice review. I wiil be changing my wblock to a new Kryos HF, in the next week. Should see what happens with the mounting process....as i read in your comments it,s not the best.
    The Kryos mount is a bit of a Pain, but the block is sexy, IMO. It does work very well.
    Sep 2010
    Barcelona
    Quote Originally Posted by theseeker View Post
    Im still using a 775 socket. I guess the mounting will be also not easy like the 1366. I hope to get this Kryos on Friday., but understanding the bad mounting system we see on your pictures, may be and I say only "may be" will be possible adapt or mod an Easy Mount from de EK to run okay wthis this block,. The black plate must have the same lengts on both cases beacouse they are only depending of the 4 holes in the mb. What probably needed be modified will be the screws and lenghts probably. Soon I get the block I will post if Im able to make a mod perhaps with the EK Easy Mount Kit and forget about the original idiotic system adopted by factory.
    Admin
    Feb 2005
    Ann Arbor, MI
    Updated with the new Swiftech Apogee XT rev2 Review data, link, and info
    Dec 2009
    New York City
    Which pump did you use for the pressure drop chart Vapor?
    Intel i5-2500K @4.2GHZ
    Gigabyte Z68-UD4-B3
    Custom Loop
    Case Labs TH10
    GTX 260 Black Edition
    G. Skill DDR3-1600
    Admin
    Feb 2005
    Ann Arbor, MI
    This chart? Pump has nothing to do with it
    But fwiw, I used all four pumps for one data point, three pumps for another, two for another, then one pump at different RPMs for the other six data points.
    Dec 2009
    New York City
    Yes, Vapor I was referring to that chart. So, the pressure drop is measured with the instrument is not depended to the pump's pressure at all?
    Gigabyte Z68-UD4-B3
    Custom Loop
    Case Labs TH10
    G. Skill DDR3-1600
    Admin
    Feb 2005
    Ann Arbor, MI
    Yeah, pump has nothing to do with it...skinnee pressure drop tests his stuff connected to city water actually and uses a gate valve to control flow. I use pumps to control flow.
    At every flowrate, a component will have a pressure differential between the inlet and outlet. That's what measured: the pressure drop across the block at various flowrates. How you get that flowrate doesn't change the results.
    Where the pump comes into play is that it has its own pressure differential curve (although it's not a pressure drop curve until you go above the pump's max flowrate) intersecting the pump's pressure differential curve with the sum of the components' curves will result in actual loop flowrate.
    Note that my charted results are just the blocks' pressure drop curves, tubing/fittings/etc. is not included.
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    Can't wait to see the XTL added so that I can see the difference between the Rev 1 XT and the Rev 2. Even the Rev 2 XT is a flow killer.
    Dec 2009
    New York City
    Thanks for the explanation Vapor, always learning something new in this forum =).
    Gigabyte Z68-UD4-B3
    Custom Loop
    Case Labs TH10
    G. Skill DDR3-1600
    I am Xtreme
    Dec 2008
    France
    Quote Originally Posted by lowfat View Post
    Wasn't XT rev2 supposed to be pretty close to EK Supreme HF when it comes to restriction? I seem to remember seeing a graph about that...
    Donate to XS forums
    I am Xtreme
    Oct 2005
    Quote Originally Posted by zalbard View Post
    I remember seeing something that showed a substantial improvement. But the rev 2 is still looking like one of the most restrictive blocks available still.
    Jul 2005
    Nice review, I would have liked to see a comparison Vs the Rev 1.
    I blindly upgraded my R1 -> R2 using the upgrade kit, it would have been nice to see the comparisons before purchasing.
    PC Specifications
    CPU - i7 920 D0 4.2 GHz 24/7 RAM - OCZ Animal 6GB PC 1600 Motherboard - EVGA Classified 760 Videocard - EVGA GTX 580 (Vanilla) 972MHz Core Tower - Obsidian 800D PSU - Corsair AX850
    Cooling Specifications
    Radiators - TFC X-Changer 360, EK 140 Video Card - EK FC580+ (R2) CPU - Apogee XT R2 Motherboard - EK-FB EVGA X58 Pumps - Swiftech MCP655-B X 2 Reservoir - Koolance (RP-452x2) Fan Controller - Aquaero Pro Liquid Cooled.
    Member of 4.5GHz Linx Club
  18. #18
    Nerdy Powerlifter
    Jul 2007
    Down in the Bayou
    Thanks for the results. This helped me choose a block.
    Does the stock kryos HF come w/ that fat ring? I can't get any info about that.
    I'd spend time taking it apart to get more performance.
    You must [not] advance.
    Current Rig: i7 4790k @ stock (**** TIM!) , Zotac GTX 1080 WC'd 2214mhz core / 5528mhz Mem, Asus z-97 Deluxe
    Heatware
  19. #19
    Admin
    Feb 2005
    Ann Arbor, MI
    Quote Originally Posted by Paradoxxx View Post
    XTr1 will be partially tested (MX-2 tests and pressure drop testing) when I test the XTL.
    I have a few XTs: original batch XTr1, a new XTr1, a new XTr2, and a new XTL....will be playing around with them (swapping bases, notably). I don't remember the original XTr1 being so restrictive (i.e., double the restriction of the XTr2), I wonder if restriction has crept up over time (and maybe thermals have improved? XTr2 did do better than I expected).
    Can say with certainty that the XTr2 is more sensitive to flowrate than the XTr1, though.
    Quote Originally Posted by [XC] Synthetickiller View Post
    All cuplex kryos blocks come with two o-rings. The one in the bag with the mounting hardware and TIM is the "thick o-ring."
    If you're using a great TIM (PK-1, X23-7783D, or better), there's no need to switch to the thick o-ring. Though I still maintain it should be installed as stock.
  20. #20
    Nerdy Powerlifter
    Jul 2007
    Down in the Bayou
    Quote Originally Posted by Vapor View Post
    Can say with certainty that the XTr2 is more sensitive to flowrate than the XTr1, though.All cuplex kryos blocks come with two o-rings. The one in the bag with the mounting hardware and TIM is the "thick o-ring."
    Thanks again.
    I'll be sure to install the thick o-ring.
    Heatware
  21. #21
    Admin
    Feb 2005
    Ann Arbor, MI
    So there's two Heatkiller 3.0 revisions in the wild....what should I call them? 3.0 and 3.1? 3.0 and 3.0b? 3.0 and 3.0.1? 3.0a and 3.0b?
    Old:
    New:
    I'm testing both for this review...well, fully testing a Ni-Bl 3.0-new and partially testing a Cu 3.0-old.
  22. #22
    I am Xtreme
    Dec 2008
    France
    Rev1 and Rev2.
    Donate to XS forums
  23. #23
    Admin
    Feb 2005
    Ann Arbor, MI
    Heatkiller [Version] 3.0 Rev2 sounds weird
  24. #24
    Feb 2009
    Carson City, NV
    I'd say an a/b or a v1/v2 would suffice
    i7 2600k, 8GB 1866Mhz DDR3, GTX560 Ti, Gigabyte Z68XP-UD4, CM Cosmos 1000 Case, and some green crap everywhere.
    Quote Originally Posted by Alexandr0s View Post
    So you're saying I could use my own pee as coolant?
  25. #25
    Xtreme Mentor
    Mar 2006
    Evje, Norway
    I wonder how much of an impact that gap between the block and the fitting plate is impacting flow when mounted in normal position? Im hoping someone will make an insert so it will be a smooth flow down from the fitting to the base, and test it.
    Quote Originally Posted by iddqd View Post
    Not to be outdone by rival ATi, nVidia's going to offer its own drivers on EA Download Manager.
    X2 555 @ B55 @ 4050 1.4v, NB @ 2700 1.35v Fuzion V1
    Gigabyte 890gpa-ud3h v2.1
    HD6950 2GB swiftech MCW60 @ 1000mhz, 1.168v 1515mhz memory
    Corsair Vengeance 2x4GB 1866 cas 9 @ 1800 8.9.8.27.41 1T 110ns 1.605v
    C300 64GB, 2X Seagate barracuda green LP 2TB, Essence STX, Zalman ZM750-HP
    DDC 3.2/petras, PA120.3 ek-res400, Stackers STC-01,
    Dell U2412m, G110, G9x, Razer Scarab
