Comments? A friend who is working on a Tron mod had this made
"Thing is, I no longer consider you a member but, rather a parasite...one that should be expunged."
That's friggin awesome. I think it would be nice if there were a few options for non-square/rectangle rads available, like one that would take the place of a 200mm fan on the side of a case. Anyway, tell your friend awesome job on the Tron mod.
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Desk Build
FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
W/C System
(CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
Nice, I like it!!
This is not one of DB's mods (its someone else on the PDXLAN site), but it definitely outstanding ingenuity.
- Autobot -
Intel Q9400 (3.6Ghz) / Asus P5Q Deluxe / 8GB Corsair XMS2 DDR2-800
MSI R6970 Afterburner 2GB / Asus Xonar DX
Crucial M4 128GB SSD / Seagate 640GB SATA2 / Lite-On DVD/RW Litescribe SATA
XFX XXX-Edition modular 650W PSU
Enzotech / Swiftech / Koolance
That mod is jaw dropping...
Yeah but is it efficient?
That is one amazing mod.
Watercooled Murdermod Silverstone TJ07
Asus P8P67 Deluxe B3
Intel Core i7 2600K
8GB G.Skill DDR3 1600Mhz
eVGA 480 GTX SLI
8.5TB (1x Seagate 1TB 7200.12, 2x Hitachi 3TB, 1x Seagate 1.5TB 7200.11)
Corsair AX1200 PSU All Custom Cables
Westinghouse 24" 1920x1200
Windows 7
When mere mortals think about a Tron inspired mod they make some openings on yout average off-the-mill case, put a lot of blue lighting, slap one of those Razer mice/matts on top and presto!
This is above and beyond that by several orders of magnitude...
One of those things that either inspires you or makes you wish you never touched a computer case with a drill in your life and took gardening instead...
It should be painted ROYGBIV!
Geniously done. Loved the movie, adore the mod.
Will your friend be posting worklog somewhere around here?
Cmndt. Eric Lassard: What is the most frustrating thing about police work?
Tackleberry: Not being able to carry hand grenades, sir.
It looks really neat, heck the whole lightcycle looks really neat.
But how do you get any airflow through it?
Those fans (at least I assume those are fans) are perpendicular to the actual radiator surface.
EDIT: and BTW, I am so jealous of extreme modders. I wish I had a fraction of the skills
and creativity exhibited by some of these people. {and no 0 doesn't count as a fraction }
That would kick ass with a squirrel cage. I've been designing a squirrel cage mod for standard radiators, not only are the more quiet, but they move much more air (higher pressure).
Looking good DB! Looks like you are rubbing off on your friends
Current: AMD Threadripper 1950X @ 4.2GHz / EK Supremacy/ 360 EK Rad, EK-DBAY D5 PWM, 32GB G.Skill 3000MHz DDR4, AMD Vega 64 Wave, Samsung nVME SSDs
Prior Build: Core i7 7700K @ 4.9GHz / Apogee XT/120.2 Magicool rad, 16GB G.Skill 3000MHz DDR4, AMD Saphire rx580 8GB, Samsung 850 Pro SSD
Intel 4.5GHz LinX Stable Club
He has been at it longer than I and clearly has more skills in the modding area
Here is his worklog
http://www.pdxlan.net/forums/viewtopic.php?t=11963
http://www.bods-mods.com/
