anyone install them yet? what are your opinions???
http://forums.guru3d.com/showthread.php?t=344093
Nothing anymore
I installed them right over the 11.4 WHQL's, haven't gamed on them yet but will report if any problems.
Intel i5 3570k || Sapphire HD 7870 OC CrossFireX || Asrock Z77 Extreme4 || 8GB DDR3 G.SKILL || Seasonic X750
Intel Core2Duo E8400 || PowerColor HD 5450 || Gigabyte P35-DS3L || 4GB DDR2 G.SKILL || Enermax 431W
Mouse lag issue is still not fixed.
AMD SteadyVideo is greyed out for me for whatever reason (2x 6970).
Changelog
- Includes performance optimizations and resolves various quality issues for the upcoming release of BrinkTM
- Resolves various transcoding video lagging issues seem when converting multiple H.264 clips to MPEG2 Blu-ray video
- Resolves the intermittent mouse cursor lag issue seen by some users
- Resolves intermittent flickering issues seen in the following applications in a system using an AMD RadeonTM HD 6600 series graphics card with DDR3 memory and running in DirectX® 9 mode:
Civilization 5
Dead Rising 2
Fallout 3
Mafia 2
NBA 2010
ShenGuiChuanQi
Starcraft 2
Warcraft III
World of Warcraft
Asus Crosshair IV | AMD 1090t @ 4.0ghz | 2x2gb G-Skill Trident 1800mhz cl7 |XFX AMD 6970 2gb | 128gb Crucial m4 | Corsiar AX850
Silverstone SST-FT02B-WRI Fortress | Yamaha A-S500 | Monitor Audio BX2 | ASUS Xonar Essence STX
any1 run any performance tests yet????
Nothing anymore
People have said enabling/disabling mouse cursor shadow has fixed the lag for them. Havent tested the drivers myself yet.
The cursor lag disappeared in games for me with the 11.5a hotfix. But it is still apparent when I'm not gaming, for example when I'm browsing the web or doing other such tasks in Windows. Which seems strange!
^^ This is the common problem - in 2d cursor lag - games is less usual
E8400 TRUE120@Asus Maximus Formula@2x2GB Geil Evo One 800MHz 4-4-4@Corsair HX 620W
Sapphire HD6850 1GB@Samsung 830 128GB@Casetek 1022-5@LG 19" 1970HQ
Creative Inspire 5.1 5100@Samsung SH-S203B SA@CM Quickfire Pro Red@Logitech G-600
Crap...Both the official 11.5 and the 11.5a hotfix version overrides my settings in Trixx. I make an adjustment in Trixx and after a 2-3 secounds CCC takes it all back....Annoying
W7 Home Edition 64-bit SP1
24/7 setup:
Motherboard: Asus Maximus IV Extreme B3
Bios: 1303
Cpu: Intel 2600k 3,4@4,7Ghz stabile with Aquaduct 360 eco+
Gpu: 2x HD5870 1024Mb CF
Ram: 2x4Gb G-Skill Ripjaws 1600Mhz CL7
Hdd: 1TB and 80gb SSD
Psu: NZXT 1000W
Cabinet: NZXT Phantom white
Screen: Samsung Synchmaster P2450 24"
Mouse: Logitech G9x
Mousemath: Icemat.com
Keyboard: Logitech G19
3DMark with 24/7 settings:
3DMark06: P34038
3DMark Vantage: P32440
3DMark11: P8159
5.0Ghz :
3DMark11: P9159
5.2Ghz settings and CrossFire:
3DMark06: P36917
3DMark Vantage: P36015
3DMark11: P9080
Why do people insist on using software to OC their hardware? So n00bish it makes me cry
"Prowler"
X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
Cooling:
6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
Modded X570 Aorus UEFIs
Yeah, so all the top WW overclockers using SmartDoctor and AB are noobs... Yeah, right...
On a more positive and useful note, here's AMD 11.5 CAP1 (thanks to asder00). No release notes that I know of.
Yes, software OCing is n00bish. Doesn't get any more simplistic than Software OCing. It doesn't matter how somebody cools something to OC, at the end of the day give something enough cold and volts anybody can be considered a "great" OCer, its not difficult Things just seem more impressive because WR holders are usually sponsored and usually have cherry picked hardware. A touch of class, or as some may call it the gentlemans approach such as with vBIOS mods goes a long way.
"Prowler"
Cooling:
So complicated = cool?
Why reboot and flash 20 times when you can just get absolutely the same result in Windows A LOT faster?
It's just a time sink... And keying in things in RBE or Nibitor takes no skill. Oh, and BIOS = software (well, firmware, technically)... Just saying.
Not to mention that
imma jackass my apologies
so again..what do you do thats so pro ? jump some circuitry ? solder on some capacitors? resistors? ...do you actually mod the card itself? any pics of your 460 with these hard ware mods ?...cause if its not something like that then its not hardware..your still going about it with software...
