I too have the dreaded leak in my bloodrage northbridge block. Is there any way to get a replacement or is there an aftermarket solution?
Unfortunately there's no stock for Foxconn to replace it with .
The Heatkiller NB and SB blocks are direct fit replacements though as you can see here. Performs a little better than the stock block, but 2c nb and 1c pwm really makes no difference. I would guess the Swiftech MCW30 would fit too but it is a tad on the restrictive side.
DESKTOP:
Lian Li V1020B/ ..::FOXCONN BLOODRAGE::..
Core I7 920 D0 @ 21x200 / Corsair 6GB DDR3-1600 / 2x Zotac GTX580 3 GB @SL! / 1x Crucial C300 256 GB / 2x Seagate momentus XT / 1x WD 2000 GB / Enermax Platimax 1200W / Win 7 64
Wakü: Watercool Heatkiller 3.0 / MO-RA 4x180 LT / Watercool Heatkiller GPU-X³ Laing DDC-1Plus @ Aquaero
LAPTOP:
Clevo (Guru) M860TU 15,4"@1680x1050 / intel Q x9200 ES 2,4 GHz / nVidia 260m GTX / 4GB DDR3-1066
