+ Reply to Thread
Results 1 to 9 of 9
Thread: Upgraded and completed my old cascade.
    -100C Club Member Dualist's Avatar
    Jul 2005
    Somewhere off topic
    0
    Long story this one.
    Over a year and a half ago I decided to find out why my cascade started to fail at holding loads so I had the plan of upgrading the condensor, txv, compressors and have a look at the evap.
    Her she is in her original state a year and a half ago at Evocarlos's, as Patrick would say "Tapey"
    First thing was to remove the first stage comp, condensor and change the orifice in the txv.
    Pressure tested and vac'd down we proceeded to charge..
    Hit -50c with no load but struck up the second stage and added a load to that in order to tune the txv. After putting it under load with the original NL11F on the second stage it did ok. With 200watts load the first stage was hitting about -35~40C and second stage was hitting -88C(ish) but was mega stable.
    So out came the second stage comp...
    Left it under pressure test over night and it didn't budge so spent the rest of the afternoon in deep vacuum.
    Well after changing that little lot, it turned out there was far too much oil in the second stage oil seperator so it was constantly open so the stage wouldn't pull down very well at all and also I found out that even though I changed the end-cap on the evap with a pukka refridgeration grade copper piece it leaked like a sieve After this I had other peoples work to do so this got stuffed in a corner until last week.
    I found an evap that I threw across my workshop car park a couple of months ago as it was blocked. So I heated the whole thing up with my oxy-acetleyne torch to bright orange and it just fell to bits, scraped all he old silver solder off it and cleaned it up in my lathe. Re-assembled it and it looked pretty good and stuck it on my suction line, added captube and then pressure tested it....
    No leaks, yay..!!!
    After messing about a bit more trying to find a blockage (in a small condensor no less, brought 2nd hand and I can see why :@ ), I vacced it down and gave it a burst of gas....
    Yay frost..!!
    So Today I lagged it all up and stuck it to my load tester.
    Temps not great but you sacrifice low temps for load holding so wasn't too pissed off but wanted to see the magic -100C, temp probe is on the side of evap (as always with me).
    Static pressures on second stage startup is too bad and no shock either, static is 150psi then just goes up to about 178-180psi, rather dull but nice and safe
    Little vid
    http://www.youtube.com/watch?v=KIw7Dh1fB1c
    Here's a pick of temp 6" from accumulator for messing with superheat.
    But here's the money shot, took the load up every 20mins or so from 150, 200 then 300. Left it at 300 watts for over half an hour and it didn't budge lower than this, well feckin happy..!!
    Temp meter on the left for superheat, temp meter on right for evap (though for working out superheat it should be on the tube exiting the evap). Will add this when I get some more temp probes but I happy as it is.
    Basic Specs...
    First stage..
    2kw condensor
    24cc comp
    TXV with 01 orifice.
    Plate heat exchanger.
    Second stage..
    14cc comp
    Bartx evap
    4ft custom suction line
    0.9mm captube 2.5-2.6mtrs.
    And yes I still have the wiring to tidy up, it's the next job on the list
    Well I took the evap off the heatloader and finished the insulation.
    Took the low side guage off and found a small amount of oil came out so I know I haven't taken too much out of the oil sep and I'm still getting oil circulating, phew
    Then I struck it up just for the hell of it and I got my -103C..!! Yay..!!
    Gonna use it just on GPU's I think now when I get a SandyBridge rig and kick out some old gpu scores, enjoy
    Quote Originally Posted by jimmyz View Post
    sorry to hear about the dead cards, but.. If stuff ain't dieing, you aren't trying.
    נְפִילִים
    -150c Club Member n00b 0f l337's Avatar
    May 2005
    NJ
    11
    Good stuff mate, I'm assuming it's an R407C rotary or something? Else you woulda had to do an oil switch right?
    Looks awesome though.
    Quote Originally Posted by Movieman
    Thanks for the compliment but unlike that bartender you mentioned I'm not sleeping with you no matter what you say!
    Admin runmc's Avatar
    Mar 2003
    North Texas
    10
    Good show buddy This is right up there with the Royal wedding.
    I like pulling up old projects myself.
    Jesus is the remedy
    Jul 2005
    Somewhere off topic
    0
    Quote Originally Posted by n00b 0f l337 View Post
    Thanks Adam, yep it's a R407C comp on the 2nd stage. Got a job lot of them a while back, but I did double check to make sure before I installed it. Emkarate RL32M
    Quote Originally Posted by runmc View Post
    He he, cheers Ron, I had to sort other stuff first before my own. But so glad my baby is running strong and sweeter now.
    נְפִילִים
    Xtreme Member Patrickclouds's Avatar
    Jan 2005
    Germany
    0
    clean work.
    well done
    Jul 2005
    Somewhere off topic
    0
    Thank you very much Patrick.
    The original build was part done with SoddemFX about 4-5 years ago as he taught me, so I just wanted to keep to his high standards on the upgrade.
    נְפִילִים
    -100c Club Member bazx's Avatar
    Jul 2005
    England
    2
    good to see you back working on cascade systems again Dave
    will you have this one @ carl's summer meet
    1. The first rule of Bench Club is, you do not talk about Bench Club
    2. The second rule of Bench Club is, you do not talk about Bench Club
    3. If someone says stop, goes limp, taps out, the the benching is over
    4. No bummers in the batcave, apart from unkie dave
    5. One Bench at a time
    6. No air, no water
    7. Benching will go on as long as they have to
    8. If this is your first night at Bench Club, you have to Bench
    Xtreme Member kitfit1's Avatar
    Sep 2005
    UK
    0
    Quote Originally Posted by bazx View Post
    Never mind the summer meet Baz, will you have it at the spring LN2 meet Dave ?
    Nice one Dave........................i see me and you are going to have to have a chat next month at Carl's. I'm thinking of putting those 2 Highly's to good use lol
    DFI LP UT P35-T2R/E8600 @ 5.1ghz/Modded Mach2 GT
    EVGA Classified/i975 @ 5.04ghz/Custom built SS
    3x2gig G-Skill Perfect Storm
    Asus 5970
    2x150gig Velociraptors/250gig Caviar
    PCP&P Turbocool 1KW
    Jul 2005
    Somewhere off topic
    0
    Thanks Baz and yeah I'll bring it along to the meet Starting to like building again now.
    Looking forward to the beer and the chat too Graham
    נְפִילִים
+ Reply to Thread
