Results 1 to 24 of 24
Thread: Mosfet waterblocks for Sabertooth?
    Mar 2005
    Finland
    Is there any eta for mosfet block for this board? would love to get those power phases little cooler
    Asus Rampage IV Formula X79 | EK-MOSFET ASUS RF4 - Acetal Copper
    Core i7-3630K@4.5GHz 1.4V | EK-Supreme HF - Full Copper
    G.Skill 16GB Quad Kit Ripjaws Z (4x4GB), DDR3 1600MHz, CL 9
    EVGA GTX TITAN SC | EK-FC Titan SE Copper - Plexi Full Cover | EK-FC Titan SE Backplate
    Corsair AX1200i
    Samsung 256gb 830
    Intel SSD 160GB X25-M G2
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    have you tried to see if any of koolance's universal will line up?
    http://www.koolance.com/water-coolin...p?cPath=29_108
    If one does line up, all you need is the associated block.
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
    Mar 2005
    Finland
    Quote Originally Posted by NaeKuh View Post
    Good info, only thing is that i cannot remove those heatsinks to take measurement as the rig is 24/7 use
    Corsair AX1200i
    Samsung 256gb 830
    Mar 2011
    Quote Originally Posted by Mobsters View Post
    Measure from the pegs on the back (or can you not access that either?)
    Apr 2011
    North Queensland Australia
    Quote Originally Posted by m0r7if3r View Post
    This is something I've been wondering myself as I cannot find any pictures of the Sabertooth's backside.
    -PB
    -Project Sakura-
    Intel i7 860 @ 4.0Ghz, Asus Maximus III Formula, 8GB G-Skill Ripjaws X F3 (@ 1600Mhz), 2x GTX 295 Quad SLI
    2x 120GB OCZ Vertex 2 RAID 0, OCZ ZX 1000W, NZXT Phantom (Pink), Dell SX2210T Touch Screen, Windows 8.1 Pro
    Koolance RP-401X2 1.1 (w/ Swiftech MCP35X), XSPC EX420, XSPC X-Flow 240, DT Sniper, EK-FC 295s (w/ RAM Blocks), Enzotech M3F Mosfet+NB/SB
    Mar 2011
    http://www.newegg.com/Product/ImageG...%20Motherboard
    there's no reference for size though...maybe if you get some REALLY precise measurements of the socket or something, but then you still need a board to measure on
    Mar 2005
    Finland
    No access to that either as MB is in case and no holes in motherboard tray
    Corsair AX1200i
    Samsung 256gb 830
    Jul 2007
    Ontario
    Lucky I haven't put mine in yet! 90mm and 105mm from hole to hole. They are not directly in line with the centre of the heatsink though. Not sure if the blocks are all built like that or not though. Might not even be worth watercooling the mosfets because you will need air blowing on the board anyways with the armour.
    Mar 2005
    Finland
    Quote Originally Posted by 421rgt View Post
    http://www.koolance.com/product_wizard/mvr_help.php
    True, if you use air cooler on cpu, but if you use water...no air blowing mosfets as that tiny 50x50x10 fan wont reach there
    Corsair AX1200i
    Samsung 256gb 830
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    Mobsters: maybe directly not blowing, yes, but in average LC sys with internally mounted rads there often is enough cross case airflow anyway. Who cares if that airflow passes LC rads, not air coolers? I'd say that in several LC builds such airflow might be even more then in average air cooling build ..
    Mar 2005
    Finland
    Quote Originally Posted by churchy View Post
    Also true, but still there is systems with radbox, extrenal mounted rads etc systems that wont get any gain from that extra airflow. And my system just happens to be like that(bad airflow inside case)
    Corsair AX1200i
    Samsung 256gb 830
    Chasing After Diety
    Jan 2007
    what i cant hear you over my san aces roaring in the background..
    but yeah churchy is right... typical LC systems have way more fans then a normal air system.
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    And BTW, in this particular board i'd leave that small cooler in place anyway, or would remove that armor thingy. From the pics it seems that cross case airflow will cool heatsinks on mosfets just fine, but i have my doubts for mirriad of other small elements hidden behind that blingy looking but imho doing more bad then good "armor".
    Oct 2010
    Case airflow from the rad fans should be sufficient to cool the VRMs. So long as you don't have a case that separates the rads from the rest of the case (a la TJ-07). And even then, the rear (or top on a TJ-07) exhaust on your case will be fine.
    Water
    Air
    WC: EK Supreme HF | EK FC-6970 | 2x DDC 3.25 | EK DDC Dual V2 | EK Res X2 250 | TFC X-Changer 480
    -100c Club
    Jun 2005
    Slovenia, Europe
    EK is working on a MOSFET waterblock prototype for ASUS Sabertooth P67. Anyone interested?
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    tiborrr: i wonder - why not make some waterblock line-up consisting of big variety of mosfet waterblocks of different length (with length step eg. at 5mm).
    - so no redesign/custom design needed for when whatever subsequent new motherboard will be released, just database of compatibility as to which blocks for which motherboard. With share of luck some of old mosfet waterblocks might work on new/other motherboard later on as well.
    Some of such waterblocks maybe can be used for cooling gpu's mosfets too together with universal gpu wb.
  18. #18
    Banned
    May 2010
    France
  19. #19
    Jul 2005
    Bilbao (Spain)
    Quote Originally Posted by tiborrr View Post
    Me, i asked mosfets waterblocks through the cooling configurator two days ago...
  20. #20
    Xtreme Mentor
    Feb 2009
    Bangkok,Thailand (DamHot)
    Z68 now come
    problem for water cooling again
    Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
    EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
    Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
    Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
    [history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
  21. #21
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    kroks: yup, same idea.
  22. #22
    -100c Club
    Jun 2005
    Slovenia, Europe
    Don't worry about Z68 chipset. I'm pretty sure ASUS will come out with Z68 version of this motherboard. The same story as with Maximus IV Extreme-Z which is physically the same as Maximus IV Extreme, therefore can adopt EK-FB ASUS Max4 Extreme water block.
    EK-MOSFET Sabertooth P67 waterblock is available for order through our webshop as of tomorrow, 16th June 2011.
    Available in all four flavors - Copper Plexi (53.95€), Copper Acetal (56.95€), Nickel Plexi (56.95€), Nickel Acetal (59.95€).
    Check recently added products: http://www.ekwaterblocks.com/shop/recently-added
    Kind OC regards,
    Niko
  23. #23
    May 2009
    UK
    Do u do a set for the Asus Sabertooth X58 i really would like one. i could cook a full English on mine atm.
    Mayhems Lastest News -> https://www.facebook.com/Mayhems2009
    If you need to direct contact me its michael at mayhems dot co dot uk.
  24. #24
    -100c Club
    Jun 2005
    Slovenia, Europe
    Quote Originally Posted by mlwood37 View Post
    Unfortunatelly not: http://coolingconfigurator.com/step1...ist?mb_mbs=303
