Page 1 of 2 12 LastLast
Results 1 to 25 of 36
Thread: Project: ______RESURREKTION______
    Jul 2009
    Mnpctech.com
    This is a resurrection of a personal project I started years ago titled "Psychosis". Half way into it, I decided the P-1 era chassis wouldn't fit my vision. After reviewing CM's 912 basic, I figured I would "resurrect" the project and use the 912 chassis. This is a personal build, not be confused my Bio-Mechanical PC project which is still shelved until I've reached some decisions on it.
    Jul 2009
    Mnpctech.com
    Painting the chassis FLAT BLACK Enamel.
    The HD will be mounted on the bezel. Here is the windowed shell for the HD.
    Mounted the rear vents
    Dec 2008
    Sweden, Linköping
    My god, nice! subscribed!
    SweClockers.com
    CPU: Phenom II X4 955BE
    Clock: 4200MHz 1.4375v
    Memory: Dominator GT 2x2GB 1600MHz 6-6-6-20 1.65v
    Motherboard: ASUS Crosshair IV Formula
    GPU: HD 5770
    Apr 2006
    Wisconsin
    wow... impressive!
    #1
    Evga 680i * Q6600 G0 * 4x2gb g.skill Pi * Evga GTX260 (216) - sli * x-fi fatality * Corsair HX1000
    #2
    Asus Striker II Formula * Q6600 G0 * 4x2gb corsair * Evga 9600gso * corsair hx620
    #3 WIP
    Asrock Z77 Extreme4-M * 3570K * 2x2gb samsung * 60gb SSD
    Nov 2008
    Izmir/Turkey
    holy spaghetti monster! this is going to be awesome, keep up
    Jun 2008
    Somewhere in EU
    I like that HDD idea It's like the old WD raptor:
    Subsribed!!
    Corsair Obsidian 650D - EVGA P67 FTW - Samsung F3 1Tb - 8Gb A-Data cheapest crap DDR3 - Intel Core i5 2500K w/ Corsair H50 - EVGA GTX 295 co-op - Corsair AX650
    Xtreme Enthusiast miptzi's Avatar
    Feb 2008
    Not sure if...
    DAMN, thats hot
    Raidmax ATOMIC - Core i7 3770s + Corsair H70 // Gigabyte H77N WIFI // Corsair Vengeance 2x4GB 2133mhz // EVGA GTX1060 ACX2.0// Kingston SUV400 480Gb // Sharkoon SFX500L
    Nov 2008
    Reminds me of a Doom3 case mod. Nice!
    Apr 2011
    Disgustingly sick in every aspect (in a good way)!
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    Subb'd, epic!
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
    Jul 2009
    Mnpctech.com
    Glad you like it! Thanks everyone
    Planning on p67 sagertooth mb, the "TUF" shell is asking for custom paint
    Jul 2009
    Mnpctech.com
    Removing the TUF shield (The Ultimate Force) on the Asus Sabertooth P67 motherboard. It's fastened on with 8 screws on the back.
    You can install an optional "assistant" 50mm cooling fan that screws into the portal pictured above. The assistant fan is an optional component and doesn't come with the Sabertooth.
    Asus recommends mounting a CPU cooler that will blow airflow downward, toward the CPU socket.
    Using Heat gun to remove the sticker
    Using red Scotch brite pad to scuff surface of the TUF shield
    Applying Flat Black "Flexible" Primer for adhesion coat on plastic, before applying Matte Black Enamel Paint
    Oct 2008
    nice project... but
    but hdd are meant to be used sealed because they are closed to vacuum. because any micro dust disks can already commit ...
    CPU: Q6600 MOBO: Maximus Formula RAM: 4gb VGA: 4850 HDD: C300 64gb TELA: 22" CASE: CM 690II Advanced | PSU: 750z-af
    Steam | Xfire | BFBC2
    www.hallaor.com
    I am Xtreme
    Dec 2002
    Quote Originally Posted by hallaor View Post
    nice project... but
    HDD'S do not operate in a vacuum. if you look at any of your drives you will see a small vent hole.
    you just need to be sure you are extra "clean" when you open one up. a HDD window mod is nothing new. Though this is by far the nicest implementation of one I have ever seen.
    Oct 2008
    Quote Originally Posted by Revv23 View Post
    Alright, I'll talk to my teacher he taught me wrong ... ¬ ¬
    www.hallaor.com
    Mar 2008
    Alberta Canada
    sadly enough...it wouldn't be a first time that a teacher was wrong, one of the guys I had went to college with had started the IT program back when CD burners were first starting to come out, and the instructor had insisted that a CD burner was like a printer and had an ink cartridge that needed to be filled/changed
    although- back on topic... amazing work as always Bill
    Current System:
    eVGA 680i SLi "A2" P30 BIOS
    intel Core 2 Quad Q6600 (currently at stock)
    OCZ ReaperX 4GB DDR2 1000 (running at DDR2 800 Speeds with cas4)
    320GB Seagate 7200.10
    XFX 8800GT XXX 512MB (stock clocks)
    auzentech X-Fi Prelude
    PC Power and Cooling Silencer 750 Quad Copper
    Win XP Pro
    Jul 2009
    Mnpctech.com
    Thanks for tuning and commenting guys. I wanted this build to be the 1st with "hand painted" artwork on the TUF shield, that reflects the theme I created on the chassis. So I enlisted my pro mod team member, Brad aka "Dirt" for his custom paint skills. When you deal with the volume of customer builds like I do, you need a team of helpers. When I started out 10 years ago, I did everything myself. Due to demand, it's gotten harder to do that...lol. I've introduced and featured Brad's paint work in the Mod Men web series. In return for this jobber, he asked that I take him out to dinner at Big Bowl with Knob Creek and Cokes, which is fine dining to us backwoods hicks. So, the cover for optional 50mm fan served as nice location for bio-mech skull taken from the front of the chassis. Brad chalked out general idea and location for the artwork. Other than using hand made square ribbon stencil and corsair 600T intake grill as a stencil, everything was painted off the cuff, freehand without stencils. Since ASUS was kind enuf to send me the p67, it's only proper that their logo gets incorporated into the artwork. (since I removed their stickers!) I'm also leaning toward anodizing their Green heatsinks Black...btw" Notice how the mb heatsink matches the Green paper on the table perfectly? coincidence or a warning to not change them?.... btw: You won't see the brown & tan gpu slots
    Don't pay $40 for professional airbrush stencils! Make your own, grab image online, edit in photochop, print it, then cut it yourself with Xacto knife.
    I just happen to have an intake grill from corsair 600T in my car...lol. It served as perfect stencil for airbrushing the mesh grid background. Otherwise Round Modders Mesh would have worked too!
  18. #18
    Jul 2009
    Mnpctech.com
    finished...
  19. #19
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    it needs some leds in eyes and mouth of skull
  20. #20
    Nov 2009
    USA
    Easily the best looking mobo I've ever seen! Yes, maybe some eyes would be good. Nice airbrushing.
    Phenom II 945 (95w)@3.5Ghz
    Geil BlackDragon 1066 2x2GB
    Gigabyte 790X UD4P
    WD 640GB Black
    Gigabyte GTX 470
    Corsair HX620-Hiper Anubis case
    Windows 7 Home 64bit
    Samsung 27" monitor
  21. #21
    Oct 2010
    Super build that is. I want to see more!!
    Case: HAF-X
    CPU: AMD phenom II X6 1090T@4GHz
    Motherboard: Asus CHIV formula
    GPU: 2x 6870
    RAM: Patriot Sector 5 2x4GB
    HDD: Crucial M4 256GB
    Can you? On AIR
    Better? -- On AIR
  22. #22
    Jul 2009
    Mnpctech.com
    Thanks for the comments and suggestions guys! I'll be installing ASUS GeForce GTX 580, DCII/2DIS/1536MD5 product page) and leaning toward AquagraFX water block.
  23. #23
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    Hmm, are these of reference design PCB? i'd double check that.
  24. #24
    Apr 2010
    Any news on this one? I wanna see what happens next
    Excessive and overwhelming tactical response
  25. #25
    Jul 2009
    Mnpctech.com
    This Holiday weekend allowed me to forge forward! HD cover mounted, tried 5mm Green LEDs, but I'm thinking White would be better.
Tags for this Thread
