Victory May Be Fleeting, But Obscurity Lasts Forever!
Last Project http://www.xtremesystems.org/forums/...d.php?t=213829
Canceled Project http://www.xtremesystems.org/forums/...d.php?t=265292
New Project http://www.xtremesystems.org/forums/...d.php?t=269440
"Thing is, I no longer consider you a member but, rather a parasite...one that should be expunged."
Im new to liquid cooling. That is why I ask.
Because I do want the best advice, when you joke like that, I do not understand, because obviously I am a noob. So if I get more confused, I do not know when to believe or not, when things that I do not know are joked about.
EVGA X58 3x-SLI Classified [with EK Full cover block]
Sapphire Radeon 5870 [with EK-FC5870]
Corsair Dominator 1600Mhz (3x2GB)
Corsair HX 1000W
Intel I-7 920 with [EK- HF Supreme]
2x 250Gb Seagate Barracudas
XSPC RX360 Raidator
XSPC Single bay reservoir
6x Scythe Gentle typhoon 1850s.
1/2" ID, 3/4" OD Tygon tubing.
People will tell you it's a joke. Calm down meg!
multiple people told you don't worry about db, he's got... special needs. Like making jokes.
Look, he was kidding, nothing more. Back to OP, get the case without powder coating and windows and have that down locally so you can see how it will turn out, get it the way you want and not add extra time to the process.
CPUID http://valid.canardpc.com/show_oc.php?id=484051
http://valid.canardpc.com/show_oc.php?id=554982
New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
Desk Build
FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
W/C System
(CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
another option (if price were an issue) would be to buy acrylic side panels, then mask and paint them once you know exactly where you want windows and where you do not. you could do some cool effects this way as well
There was a cool trick I thought up., never seen it done. But seen similar.
Once you get your panels, pick a design, have it cut out of the panel, behind that and sandwich a full sheet of acrylic, extra long screws, internal light source and one sweet effect.
Thought of it while looking at some of charles murder mods.
Just a suggestion. But thats from somebody weird build been stalled
For 6 months.
Sent from my X10a using Tapatalk
MagisD
____________________________
Lurker, Dreamer, Planner, Noob
6 Quad rads 1 case Maybe I went a little overboard....Overkill Cube
