Dear users of XtremeSystems,
this is my custom waterblock. Block is made the conventional milling and No CNC and NO program !!!
Block has been made many problems... phew..
For example soldering in one place
Block material is copper(nickelplated),TOP is 10mm polycarbonate.
Next is a description and pictures..
Final product
Block for videocard
Other side videocard
Backplate for GPU
Preparing for mount waterblock
GPU and memory is use thermal grease,for VRM and other is use thermal pad.
Green- original 1mm thermal pads, Pink - 0,5mm thermal pads by Alphacool.
Making Of
Start was channel for the "O" Ring. Semi-finished is copper 120x10.
Centering points is highly important for milling diameter and radius for rotary table.
Chanel and O ring
Channel miling for active area for waterblock
Radius and diameter miling
Almost finished front side waterblock
Base for the block
Almost finished...
Last pics before nickleplated
Block was acid(contamination cooking oil(threads) and flux for soldering )
Nicklelplated block
Block,O ring,TOP
Conclusion and temperature tests
Block is fully functional and my GTX 480 is icy
For testing used Watercool MORA 2 Radiator and last version Furmark.
Fully passive operation
Using fans
Special thanks
grand master Gorelord for by Aquacool.cz - support
Wroom and liquidtech (Nickelplated)
A few words in conclusion,TOP is only BETA version. It will be another...
To be continued, soon ....
