So my system has been built for a few days now, but I was putting a new desk in my room and setting it up how I wanted before moving my PC over. Since then I've had the PC leak-testing/bleeding and this thing isn't anywhere close to being done! I love the way this reservoir looks, but I'm starting to question it's design. Water (and air-bubbles too!) travel through that little curved tube and straight back into the inlet and cycle their way back into my loop. How the hell am I supposed to bleed this thing?
I did some research and did find a tip that's been working pretty well. I took a piece of tube, cut it in half, and stuff it between the outlet and the inlet like this...
I only had thick tygon tubing so it was a pretty tight fit to get the piece of tubing in there, but it fit, and it worked pretty well. I'm not sure how much flow was restricted, but a lot of the bubbles got out of my loops. Not all, though Any one have any other tips on how to effectively bleed a loop using this res? Gosh had I known it would be this tough I would have gone with something different lol. My loop is in an 800D, and consists of: BayRes+Pump >> 360mm Rad >> Apogee XT >> 120mm Rad >> 5970 EK block >> BayRes+Pump. I'll post a pic later.
