I'm hoping that there are some folks here who have experience with low-power systems that can help me out with a problem that I have coming up. Basically I am building 3 systems for lowish power use and am trying to standardize on a single PSU. Normally I might not mind if I bought a PSU and it turned out to be way too large or too small (I can always find use for a spare PSU), but I don't want to spend incorrectly on 3 PSU's (components will have to be ordered at the same time).
Assuming that for some reason two systems die and their components need to be consolidated into one box, the worst-case specs would look like this:
- CPU: Intel Core i5 2500T (45w part, no OC)
- ODD: 4x DVD-RW
- Mem: 2x 4GB DDR3 sticks (1.25v parts)
- Mobo: Some standard motherboard
- Video: On-CPU video
- HDD: 10x HDD + RAID Card
- Average Utilization: High
I know the ODD's and HDD's are going to increase the draw, but otherwise I'm seeing a large savings on the GPU/CPU and a sip of savings on the RAM. I want to build this system as lean and efficiently as possible. I somewhat suspect a 500w PSU would do the trick, but that's really a complete guess. For all I know I need more wattage or maybe I could get away with a lot less.
Can anyone out there offer a suggestion or educated guess?
Edit: Because we have to take PSU efficiency into account, for the record I'm thinking that for cost reasons I'll go with an 80+ Bronze certified PSU.
