Page 6 of 6 FirstFirst ... 3456
Results 126 to 143 of 143
Thread: [build log] Water & Wood
  1. #126
    May 2004
    AB. Canada
    voted for ya
    "Great spirits have always encountered violent opposition from mediocre minds" - (Einstein)
  2. #127
    World Champion - IRONMODS
    Sep 2007
    Northern Japan
    I've been having a bit of fun with the new DCS A-10C Warthog game
    http://www.youtube.com/watch?v=_2GrHcZUO0o
    Quote Originally Posted by Massman
    My definition of 'efficient' is 'it does not suck monkeyballs'. Yes, I set bars low.
    [CENTER]The post counter is not an intelligence meter!
    MAX11L - "It's like a console...with the suck turned down and the awesome turned up" -tet5uo
    Heat Team IRONMODS
  3. #128
  4. #129
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    miahallen: with using Thrustmaster HOTAS Warthog joystick per chance?
    I have to admit, that head tracking gadget seems really cool must have device in flight sims.
  5. #130
    Sep 2007
    Northern Japan
    No...I've got a Saitek "Cyborg EVO Force"...their cheapest FFB stick. Not bad, but nothing special.
    The headtracking is awesome...but it would be tough to dogfight with guns....I tried it with "Birds of Prey" and it was pretty difficult to line stuff up with the crosshairs and fire accurately....but I didn't mess much with the curves in that game. Maybe I could improve it with some effort A-10C works fine since its mostly air to ground fighting with bombs and guided missles.
    Heat Team IRONMODS
  6. #131
    Sep 2007
    Northern Japan
    So, a bit earlier I mentioned that I was working on a frame to surround the fan wall. I finally got a chance to finish it up today. I started by putting the frame together.
    Notice the small burn mark. When you use a router, you have to ensure the bearing is loose so the guide will lead you without spinning. The bit I was using was a bit older, and the guide got stuck and was spinning, which burned the entire length of the board. I sanded most of it off. But this spot got a bit deeper.....thank goodness one of the edges has to face the rear :p
    A quick test fit shows my measurements were just about right.
    Now the hard part. You may recall near the beginning of this project, I cut the holes on the fans extra wide to allow the screws to pass through the outer opening and mount the fans from the inner part of the frame. No big deal at the time, but then I received these beautiful dust filters from Team ColdZero, and they would normally mount to the fans with said holes. So now I needed to come up with a solution, when I mounted them the first time, it was a bit of a rushed job with zip ties. But I wanted something a bit more flush and secure.
    Then I came up with an idea. I'd glue a washer to the back side of the holes, then use rivets to secure the filters into place. Here are the washers glued into place (this was a major PITA).
    Next, I got to rivetin'....after I was finished I realized I had forgotten to put the frame back on before riveting. Which has to be done first :banghead:
    So, I'll fast forward a bit to after drilling out all the original rivets...recovering all my washers...gluing the washers back into place (AGAIN!)...and then re-riveting all 48 spots.
    Next I removed the protective film from the inner grill for the filter.
    Next I removed the protective film for the outer filter grill...
    ...and got the filters all remounted.
    Here are some semi-final shots. The rig is 99% finished at this point. I'm still toying with the idea of swapping the PSU with an AX1200. But this thing seems to be holding up to the heavy load. I'm just not sure if pushing it this hard is a good idea for the long run. I'm regularly seeing 1300-1500W draw on my kill-o-watt while gaming.
    I'll also replace the Koolance QDC fittings when I get my replacements from RMA. Until then, I'm calling this finished I'll get my blog written up soon. I'd like to say thank you once again to Swiftech for their support, and to Team ColdZero for these beautiful additions....and I'd also like to thank the community as a whole for watching, commenting, and supporting me through this build.
    I've already started work on my next project (MAX11Lv3), please make sure you check it out
    Heat Team IRONMODS
  7. #132
    Jan 2009
    I love it! Nice work on that frame!
  8. #133
    Dec 2008
    La Plata, Argetina
    :O Awesome work!!! Congrats
    G-machine
    1090T BE + H50 / GA-MA790XT-UD5P / 2X500gb F3 + 250gb Samsung / Reaper 2x2Gb 1600 8-8-8-18 / Audigy SE + Creative SBS 4.1 450 Gmod + Philips SHP 2500 Gmod / 9800GTX+ / P&C S750W / Lancool PC-K60W RED / 2343NWX + 732NPlus / Microsoft wireless desktop 2000 Gmod
    Nokia 5800 XpressMusic Hacked @ C6
  9. #134
    Sep 2007
    Northern Japan
    Well, I knew this was coming sooner or later. I broke the rig down today to install my new Koolance QDCs I got back from RMA. And I figured I'd use the opportunity to check the nickle plating on my EK water blocks. Sure enough, it's RMA time
    Heat Team IRONMODS
  10. #135
    Jun 2011
    Not to discount the ugliness, but there was one guy i saw that had that build up, and it just wiped off more or less. But, one thing ive noticed on your GPU's, looks like you could use something to hold the back end up as they are clearly sagging from the weight of the wires.
  11. #136
    Sep 2007
    Northern Japan
    Quote Originally Posted by Furball Zen View Post
    I saw that thread as well, and took the advice and attempted to clean them (after the photos were taken), a lot of it cleaned off....but other parts are clearly missing nickle, but thanks for the suggestion
    The GPUs are suprizingly level, I'm not sure which picture is leading you to believe they are sagging, but they do not
    Heat Team IRONMODS
  12. #137
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    mia: your blocks were old plated or EN plated ones?
  13. #138
    Sep 2007
    Northern Japan
    Old....I bought them about a month before the big EK thread here....so I knew this was coming :-/
    Heat Team IRONMODS
  14. #139
    Sep 2007
    Northern Japan
    Well, I finally got around to putting things back together after getting GPU blocks, Koolance QDCs, and the mobo replaced:
    This is how it should have been from the beginning.
    Heat Team IRONMODS
  15. #140
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    Looks neat. Imho heatspreaders on mosfets / on ram and gpu backplates play well together here
    I'd paint black that white-grey-ish external connector/cable above top gpu though, for all to look uniform.
  16. #141
    Sep 2007
    Northern Japan
    Good call churchy
    Heat Team IRONMODS
  17. #142
    Feb 2009
    Carson City, NV
    That's hot right there. In the sexy way, not in the melty sort of way.
    i7 2600k, 8GB 1866Mhz DDR3, GTX560 Ti, Gigabyte Z68XP-UD4, CM Cosmos 1000 Case, and some green crap everywhere.
    Quote Originally Posted by Alexandr0s View Post
    So you're saying I could use my own pee as coolant?
  18. #143
    Jan 2009
    Whoohoo! New HW! I like the choice you've made. Gratz!
