Results 1 to 13 of 13
Thread: looking 4 thin & tall & quiet compressor !!!
    Aug 2010
    Question looking 4 thin & tall & quiet compressor !!!
    hello all u OC geniuses
    i'm looking 4 a : thin & tall & very quiet (same as nl11f) compressor !!!
    350w ~
    15cm~ X 15cm~ X 20cm~ height
    possible ?
    r u sure ?
    u gotta help me !!!!
    in other words looking 4 nl11f but shaped more like a rotary slim&tall but must be quiet !!!!!
    there must b somthing outhere don't u giveup on me
    BTW: please don't ask me why lol
    10x
    Aug 2010
    the nl11f is great but take a look again in what i posted DANY tall thin quiet 350w....
    i know i will find it ... lol
    -150c Club Member
    May 2005
    Northeast, USA
    No you really probably won't.
    I have always said you get two of the three.
    Quiet
    Power
    Small
    You want a rotary, but don't want the noise one will bring. With tuning you can quiet one down, but you won't get the performance you want. Not to mention for those specs you will need a fairly noisy or LARGE condenser.
    If you have a cooling question or concern feel free to contact me.
    Dec 2007
    hyperionix= Tetraflourmethan?
    -150c Club Member
    May 2005
    Northeast, USA
    normally we get a larger break between iterations. I don't think so though, he isn't discussing a 4 stage cascade yet O.o
    -150c Club Member
    May 2005
    Northeast, USA
    He's faked being on the low end of the stick before, I think the mods will check that though. Not too worried.
    Xtreme Mentor
    Feb 2007
    Victoria, British Colombia
    Quote Originally Posted by Danfoss View Post
    He is in the UK, this guy is else where
    you can say your from anywhere with a forum account, you can link an account to a different IP...
    I think your best bet is ~ 1/2hp rotary... NOT quiet though
    mentally confused and prone to wandering
    Aug 2010
    need it silent !!!
    -150c Club Member
    May 2005
    Northeast, USA
    For silent you won't get more than a half hp, more like a 1/3.
    Aug 2010
    rotarys are about 50 db , no ?
    i need 20db 300w 15x15x25cm height 8kg max
    i think in 2011 technology it can be done ! don't u ?
    Aug 2010
    Quote Originally Posted by n00b 0f l337 View Post
    How ???
    -150c Club Member
    May 2005
    Northeast, USA
    Instead of running it into vacuum, run it into a higher low side pressure to reduce the ratio of high side pressure to low side pressure, and thus reducing work done on the compressor.
    Aug 2010
    got you 10x
