Results 1 to 4 of 4
Thread: i920 Oc@3.8 are settings ok?
    Mar 2010
    Hi.everyone just overclocked Gigabyte x58a-ud5 rev 1 @ 3.8ghz.Everything is stable. G skill @1520mhz 7-7-7-20 1T @1.6v
    Running Noctua NH-U12P SE2 performance push/pull config.Temp seem ok.
    Memory/ram -G.skill Trident F3-12800CL6T-6GBTD/1600 6-7-6-18 1.6v.Case-coolmaster 690 - 3x120mm rear/front/Side.
    Power supply-Thermaltake toughpower Qfan 850watt active.
    Graphics card-gigabyte HD5770 128-bit gddr5_850/4800 mhz.
    I cannot find spread spectrum in bios settings,Has it a different name?
    I have load line level set to enabled,Is level 1 any better and I have set unicore@16x is it ok or set it to auto.
    Can i impove on voltages and settings.Happy with current 3.8ghz don't wont
    to go higher as yet.See attached settings.The only thing I have changed is CPU EIST to
    enabled( re-enabled it).didn't like it running high 3.8 ghz on idle.
    Thanks Hoton
Name:	bios settings.jpg
ID:	113483   Click image for larger version.
ID:	113484   Click image for larger version.
ID:	113485   Click image for larger version.
ID:	113486   Click image for larger version.
ID:	113488   Click image for larger version.
    Mar 2010
    I forgot to add this attachment.Sorry!
Name:	graphics and ram.jpg
    Xtreme Cruncher
    Jan 2009
    The Hague, Netherlands
    He, welcome to XS!
    It looks all fine to me. I can't answer your specific questions as I don't have a Gigabyte mobo, but if it is all stable leave it like this.
    With the voltages you are using you will never run into any problems degradation wise. Temperatures are also fine.
    3770K 4.7Ghz 1.32v / ASUS P8Z77-V PRO / 8GB DDR3 1866 9-9-9-27 /ASUS HD7970 1025MHz / Antec NeoHE 550 / Samsung 830 256GB Crunching
    Cooled by PA120.3, EK-HF, D-tek Fuzion GFX, DDC3.1 XSPC res/top
    i5 2400 Stock / ASUS P8P67 LE / 4GB DDR3 1600 / Seasonic S12II 430W / Intel G2 40GB Crunching
    2600K 4.6Ghz 1.34v / ASUS P8Z68-V PRO / 8GB DDR3 1600 8-8-8-24 / Antec 430W / Intel G2 80GB Crunching
    W3520 4.0Ghz 1.19v / Rampage II Gene / 6GB Kinston Value 1333 / 9800GT / Corsair TX650 / Antec mini P180 / Intel G2 160GB Crunching
    Intel G860 Stock / Gigabyte H67MA-UD2H-B3 / 4GB DDR3 1333 / Antec Earthwatts green 380W / Crucial M4 64GB Crunching
    E6600 3.2Ghz 1.36v - P5B Deluxe / i7 930 4.0Ghz 1.29v - ASUS P6X58D-E / Q9450 3.6Ghz 1.28v - Rampage Formula Retired
    Mar 2010
    Quote Originally Posted by Conquistador SW View Post
    He, welcome to XS!
    I was thinking of turning of cpu EIAST(power saving)is that a goo idea.
    and use clock ratio @x21 and BLK191
    And seyload line callibration @ level 2?
    And also set timming @ 1520mhz 6-6-6-18 1T 1.64v.
    Whats you ropinion .Thanks Hoton.
