Venomous X with TY-140 fan mounting
Does anyone know how to mount these fans securely using the supplied mounting clips, Ive resorted to using cable ties to achieve a push pull configuration.
A picture will help immensely.
Also with the fans being so close to the back of the case, is it really worth having an exhaust fan especially when I only have a 120mm opening. The case is a lian-li PC-A20, will be posting some pictures tonight.
- You may not post replies
- You may not edit your posts
Forum Rules
