Results 1 to 12 of 12
Thread: 970
    Dec 2008
    970
    Does the Bloodrage support the Intel I7 970 CPU? I have searched but really can not find anything on someone actually running a 970 on this board. Although it looks like one of the later bios updates says that it added support for Gulftown cpus but I'd just like to confirm before I purchase one. Any feedback would be much appreciated. Thanks.
    Aug 2010
    "This board" means which Foxconn Quantum Force X58 board? Today the crystal ball is somewhat weak .
    ASRock 990FX Extreme4|AMD FX-8320 w/water|OCZ3RPR1866C9LV4GK|XFX HD5850|WD6000HLHX|PC P&C Silencer 910W
    Foxconn BloodRAGE X58|Intel Core i7 920|G.Skill F3-16000CL9T-6GBTD|XFX HD5770|WD6000HLHX|PC P&C Silencer 750W
    Dec 2008
    Sorry I guess I got a little ahead of myself. I meant the Bloodrage. I edited the OP to include the name of the board.
    Jul 2008
    works with the last few bios
    so get the p11 bios and you be fine
    Aug 2010
    Quote Originally Posted by scutzi128 View Post
    If I remember correctly, since G33/P10 bios BloodRAGE/BloodRAGE GTI has Gulftown support. So, any newer bios should be fine .
    Technician
    Jun 2002
    Merseyside, UK
    970 needed a microcode update. Any bios supporting 990x will support 970, so I think you're limited to P11. G44 *may* work.
    Mar 2009
    Sunny South Florida
    Quote Originally Posted by PiLsY View Post
    G44 will work for 990x. P11 works better for 990x... I would start with P11 for the 970.
    Intel System
    CPU: Intel i7 990x ES @ 4.2GHz 24/7 still kicking!
    Mobo: Foxconn BloodRage X58 P11 Bios
    Ram: Corsair Dominator 12GB DDR3
    Water Cooling: Apogee XT, MCP655-B pump, MCR220 radiator, XSPC 5.25" Bay reservoir
    Videocard: EVGA Nvidia FTW+ GTX 1060 6GB
    OS HDD: Samsung 950 Pro 512 MB M.2
    Strorage HDD: W.D. VelociRaptor 300GB
    Storage HDD: W.D. 500GB
    PSU: Enermax Evo Galaxy 1250 Watt
    Case: Cooler Master Cosmos S
    Roms: Lite On DVD Burner
    Roms: Asus Bluray Burner
    OS: Windows 7 Ultimate 64-bit
    Dec 2008
    Thanks for the all info guys.
    Dec 2008
    Just to update both p11 and g44 work. Is there a general consensus on which bios is better?
    Mar 2009
    Sunny South Florida
    P11 allows the multi to go past 26x with turbo on with the 990x. Voltages match from bios to cpuz which didnt on G44. Not sure about effects on 970.
    Intel System
    Dec 2008
    Loving this board so far. Got my 970 to 4.5ghz and with the included water block I can keep my mosfets nice and cool compared to the 90* C + I was getting on my EVGA board. Is there any way to actually monitor the mosfet temperature on this board just for the sake of curiosity?
    May 2009
    P011 is a crap BIOS, be warned.
    Have you tried reverting to an different BIOS yet? Are your HDD working correctly?
    Is the OS reporting the CPU correctly?
    Core i7 W3570 @ 4.86Ghz (on air)
    Foxconn Blood Rage
    6Gb Gskill Perfect Storm @ 1666 Mhz
    Twin 580 GTX in Sli mode (if ever the BIOS is fixed correctly)
    Samsung 37" LCD
    Twin 1 T/B WD Black in raid- striped, Single WD As a B/U.
    Antec 1200 watt PSU
    Antec 900 series case
    Sony BD Player
    LG BD/DVD burner
    Logitech Bluetooth M/KB
    Cambridge THX Gigaworks 7.1 Sound
