did the LTX worth the extra money?
what do you think?
what do you think?
[SIGPIC][/SIGPIC]
EVGA SR-2 , 2X Intel Xeon 5620, 12X2GB Corsair Domminator 1600 MHZ CL7
3X GTX580, Corsair AX1200, Lian Li PC-Z70
3X Dell U2311H, Liliput 7" touchscreen monitor
Supreme HF should perform better although I don't think there are any reviews that have tested the LTX. The LTX is the "Light Extreme" version...not sure why they are priced higher than the HF in some places, they are supposed to be the economy model HF from what I understand which isn't much...
LTX uses the same base as the HF (or at least I've heard), but the HF uses a much better injector. HF is definitely the better performer.
motherboard - EVGA Classified e770 EK watercooled
cpu - i7 950 @ 4.420GHz EK watercooled
video - EVGA gtx 580 sli 950/1900/2300 EK watercooled
memory - 3 x 4GB Mushkin Redline (7-8-7-20 1T)
storage - Corsair Force 120GB ssd
power supply - Corsair AX850 (MDPC-X sleeving)
case - Danger Den Torutre Rack
