swiftech MCR drive question
is the MCR driver series B-stock(without pump) only compatible with swiftech MCP35x(unique top) pump or it can use with MCP355(the one without top inlet)?
it should be compatable with any DDC since they have the same footprint and mounting.
thats what i thought but looking at the explode diagram from swiftech it look like it need the a specific top from swiftech for the ddc. i wasn't sure if that top come with the rad or i have to buy separately or i have to get the swiftech ddc which came with that top
I'm not 100% sure, but it should work with any DDC, the previous generation (the drive series) did. Hopefully someone here knows for sure
Installation manual here : http://www.swiftech.com/dual120mmrad...andpump-2.aspx, clearly states that MCR-x20 Drive-B is compatible with MCP350 and MCP355. You need to remove what ever top you have on pump to install it to the radiator.
- You may not post replies
- You may not edit your posts
Forum Rules
