I have been running my Swiftech MCP655 w/speed control for the past year or more with an ApogeeXT, 3x120MM EK rad, and Swiftech res and 1/2"IDx3/4"OD tubing with no issues and great performance.
I recently bought an 800D, matte black BP 7/16"IDx5/8"OD compresssion fittings, matte black BP D5 mod kit, and BP Mod pump top V2 and new LRT white tubing.
I put the loop together outside the case after getting all tubing measurements correct so it is easier to bleed all the air out. I get a fish tank sound or really bad air bubble sound coming from my pump after getting all the air out. The radiator is fully air free and the res is no longer showing bubbling no matter which way I shake, turn, flip each component in the loop.
As an fyi, this Swiftech MCP655 was DEAD SILENT prior to installing the BP mod top and matte black kit. I followed the directions that came with the kit. I even disassembled the loop and took the modded pump apart just to make sure I didn't do something wrong the first time and I saw no problem, and put the pump back together.
I will not be able to use the modded Swiftech pump as it is now WAY TO LOUD if I can't solve this noise problem coming from the pump. To be clear, it is not a grinding sound, it sounds like a huge stuck air bubbling sound or waterfall sound.
Anyone have any experience using the BP D5 mod kits and tops and if they had problems getting air out of the pump or how to get rid of the air bubbles/fishtank sound? Literally sounds like a waterfall.
Thanks in advance
