Two motherboards, same model and same BIOS version, same components everything else, one can OC better than the other one?
Or different versions of Windows, same everything as above, one can OC better than other?
Asus Rampage II Gene, Xeon W3550 D0 Mushkin PC3-2000 6GB, BFG 9600GT OC 512MB DDR3
Asus A8N32-SLI Deluxe 1.01G, AMD A64 4000+, 2x1GB Ultra PC-3200, EVGA 7600GT 256MB DDR3
Asus MA378-T with AMD Athlon 64 X2 7850
ECS 945GCT-M/1333 v3.0, Intel Celeron E1400, MSI 8500GT 256MB DDR3
BIOStar P4M900-M7 Rev. 7.0, Intel Celeron 440, 1GB Kingston, 6600LE
Gigabyte M61PME-S2P with AMD Athlon 64 LE-1660, EVGA 8500GT 1GB DDR2
1. Simple answer, yes. Cpus aren't exactly the same, some are more/less tolerant of voltages and/or temperatures, although certain batches (look for date codes on your CPU) will generally overclock as well as each other. However, you can get very bad ones and very good ones in the same batch. I've been ok and at least got an 'average' one every time, (and quite a gem of a Q9650). Some enthusiasts acquire trays of CPUs to try and find the best ones for those top clocks. Identical motherboards can also vary when pushing them to their limit but it's becoming less common now as the i3/i5/i7 CPUs now control memory leaving less work for the motherboard and leaving it down to CPU and memory. I'm not so familiar with AMD anymore, but their chips have had IMCs in there for a few years longer.
2. Depends on how you go about it, but my gut tells me xp would use less resources and wouldn't take up as many cycles when benching. As for 24/7 overclocked systems I doubt there's much difference, but I can't help feel that W7 is more sensitive. Anyone?
Gigabyte EX58A-UD3R F6 : i7 920 D0 4.4GHz 1.4v : 4Gb G.Skill ECO 6-8-6-24 1.54v
Apogee XT & MCW30 : XSPC Dual 750 w/DDC+18W : RX120 & RX240 : Tygon tubing : Corsair HX 850
2x750Gb 7200.12 RAID0 : 2x500Gb 7200.12 RAID1 : Samsung DVD-RW : LG BD-R
Antec P182 with 5 x Noctua NF-P12 & 1 x Akasa Apache
M-Audio Delta 1010 (Rack) : Behringer Truth B2031A
XFX 5770 + 8600GTS (physx) : 2x Samsung Syncmaster 710n
Lappy: Asus C90s & E7500 @3.17GHz w/ 4Gb RAM & top scoring 8600m GT DDR2
Same CPU, same everything except the motherboard...if my original post wasn't clear enough. I know about CPU batch's different OCability, but I'm talking about motherboard.
Yep it can make a difference as the nb/sb and other chips can also be good or bad chips.
Pro , DLX and M4E beat my Sabretooth sample hands down, clock for clock there's nto much going for it... but maximum speed some boards are limited by features, bios, etc... Some boards are better indeed then others, like with all previous sockets... some S775 do 650FSB, some 600, some AM3's do 400HT other's can't reach 370... chipset quality matters
Question : Why do some overclockers switch into d*ckmode when money is involved
Remark : They call me Pro Asus Saaya yupp, I agree
Yep, agreed, sorry about the confusion
