Results 1 to 10 of 10
Thread: XSPC Rasa gpu block
    XIP
    Nov 2004
    NYC
    Question XSPC Rasa gpu block
    Is these good enough for testing/benching GTX 580/590?
    My last gpu H2O was with swiftech MCW 60s and 8800GTXes
    Paired with this...
    Do I need anything else?
    Thank you for help
    Dumo
    Feb 2008
    Canaduh
    i don't think a 2x120 will be sufficient for cpu AND gpu
    Intel i7 980x / 3001B331
    HK3.0+LaingDDCPRO+XSPCRX360+1xMCR220
    EVGA Classified X58+EK FB
    6GB Corsair Dominator GT 1866 7-8-7-20(TR3X6G1866C7GT)
    ASUS GTX580
    Enermax Revolution+85 950w
    Corsair Obsidian
    XIP
    Nov 2004
    NYC
    Thanks for reply
    Its only for gpu/s. I plan to do testing on stock air/H2O/LN2 for new gpus
    I choose universal block rather than full cover, because of non refererence pcb
    Any idea on the other H2O gpu setup?
    Mar 2011
    The kit you posted uses a pretty old rad design and comes with a CPU block, not a GPU block...so I'd say it's not all you need.
    XIP
    Nov 2004
    NYC
    Yep, I don't need the cpu block, but it included with the kit. I start with 2 gpu blocks
    Mar 2011
    You don't need to buy a kit, buy the rad and pump individually, you can get a better pump too.
    XIP
    Nov 2004
    NYC
    Any suggestion?
    Gpu block is ok?
    Never go full retard
    Feb 2008
    Vegas
    Xtreme X.I.P.
    Jun 2007
    Bend, Oregon
    Quote Originally Posted by skinnee View Post
    Ahh...yes!
    Awesome work as usual! Off to reading..
    XIP
    Nov 2004
    NYC
    Thanks for info
