Yeah, it's actually a lot on the expensive side.
This setup puts the cost into FC range.
Here's what I was thinking.
Blue fitting (
Link) You may also need this one (
Link) to supplement the length depending on the distance to the edge of the card.
Orange fitting (
Link)
Green fitting (
Link)
Red fitting (
Link) Yes, you'll need 6 of these...my bad, I thought they came in paired sets.
Plugs (
Link) You'll need 2 of these to plug up the ends of the T's that don't have fittings on them. Likewise, you could substitute 2 elbows (
Link) for 2 of the T's and not get the plugs.
While digging around for the links above, I came across something that is probably a bit more functional and definitely cheaper. Get a pair of these (
Link) and you can use regular barbs/comps on the block/manifold and connect the block to the manifolds with tubing. Just make sure the tubing lengths to each block are fairly equal, otherwise you'll get a difference in flow rates through each block.
