Glad I was proven wrong- one of mine leaked from the threads and after I attempted to tighten it, the tube cracked.
Waterlogged that's exactly what I'm saying. With watercooling being so accessible now you have people who frankly need their hand holding crossing roads trying to watercool PCs after spending 10 mins on google. You would expect some failures - between 1 and 10 in every 1000 units depending on your margins. People posting this on the forum means every monkey that tightens their res like theyre strangling a ginger stepchild and cracks it screams product failure.
With so much of that going on its hard not to justify moving away from a threaded design despite the short term costs. The design itself allows this to happen so it needs changing. Not because its wrong, but because it can be incorrectly assembled and cause failure.
Aside from the "idiot factor" and the use of a thread assembly, what annoys me is the inconsistency of the thread length.
An inconsistent thread length causes the barb outlet/inlet holes of the multioption caps to line up differently when the tube has been adequately tightened. This makes build consistency impossible when using multiple reservoirs per build.
Also to Tiborrr, I'd recommend heatcycling the liquid in your test reservoirs to simulate a hot loop.
motherboard - EVGA Classified e770 EK watercooled
cpu - i7 950 @ 4.420GHz EK watercooled
video - EVGA gtx 580 sli 950/1900/2300 EK watercooled
memory - 3 x 4GB Mushkin Redline (7-8-7-20 1T)
storage - Corsair Force 120GB ssd
power supply - Corsair AX850 (MDPC-X sleeving)
case - Danger Den Torutre Rack
i was just about to recomend doing something like this, until i read it..
lol.. nice one... yeah, you need some heat load to see if the res's can tollerate it.
Personally id take it up to 40C even or higher to simulate extreme conditions.
This way if you dont crack at extreme conditions, you can be sure it wont crack at the standard settings.
I plead the 5th! :X
Oh wait.. i shouldnt admit to this huh?
Nadeshiko: i7 990 12GB DDR3 eVGA Classified *In Testing... Jealous?*
Lind: Dual Gainestown 3.07
Its my fault.. and no im not sorry about it either.[12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
Good to see EK is on top of it![]()
Donate to XS.org
"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety." -Ben Franklin
"Every government degenerates when trusted to the rulers of the people alone. The people themselves, therefore, are its only safe depositories." -Thomas Jefferson
"He that would make his own liberty secure, must guard even his enemy from oppression; for if he violates this duty, he establishes a precedent that will reach to himself."-Thomas Paine
I might be an idiot, I'll ask my wife and see what she says![]()
Thanks for the thumbs up, guys!Yeah, I'll start doing cycles but unfortunately I don't have any heat source, I might as well use a high power hair-dryer or heat gun once a day for 15 minutes to heat up the radiators?
We will be adding the nickel plated waterblocks in each loop as well to check whether any of the water additives can cause nickel plating to come off. Distilled water eventually ionizes itself again and combined with some other metals with different electron potential (don't know if this is the right word in english) it may cause reverse galvanic reaction, effectively removing the nickel from the copper.
We'll try to rule everything out!
Best Regards,
Niko![]()
EK Water Blocks R&D
ekwb.com
Hobby: Rotary SS bench unit (LPG/R-507) | -75°C Auto-cascade (R-600/R-290/R-744) | Plate HX water chiller (1kW cooling power) | My 2nd cascade MP14FB R-507/R-1150 | Mini cascade R-507/R-1150 | GPU single-stage | Mach I restoration mod -> -38°C @ 230W
Milestones: 7.12GHz P4 | 6.84GHz K10.5 | 6.45GHz Ci5 | 3.31GHz K7
3DMark2001SE -> Favourite Game!
http://www.heatware.com/eval.php?id=67041
Case: Silverstone Temjin TJ07B/MurderMod Faceplate/Serpentin Acrylic top.
PSU: Antec TPQ-1200w
Mobo: EVGA X58 SLI LE/EK-FB Block
CPU: Intel LGA 920 DO@4.1Ghz/EK Supreme block/Thermochill pa 120.4 Rad./EK 250 res/swiftech 350pmp
Ram: Corsair CMT6GX3M3A 1600C7 6gig
VGA: EVGA GTX 580/EK Block
HD: Western Digital 500gig
Sound: Creaive X-FI Titanium Fatal1ty Champion series
tiborrr: from cases i recall reading @XS about damaged nickel plating, most of them were because of too strongly acidic solution usage for cleaning (eg. stronger types of vinegar and for too long time) - so maybe it's not worth to bother, as normal usage with normal distilled+silver or distilled+(not overdosed)PHN shouldn't cause any problems. Hmm .. but then again .. remembering WL's brought up "idiot factor" - you can test overdosed PHN-Cu, and for RMA cases ask user - how much he put in biocide.
@churchy: We're testing every possible scenario, including the overdose of PT Nuke (sadly not the PHN version as It's impossible to obtain one). We would like to get to the bottom of things once and for all. We're doing everything we can to stop the ... (see pic below) ... of the EK brand
EK Water Blocks R&D
ekwb.com
Mine cracked after leaving the top off of it for an extended period of time, while the base was still threaded onto the pump. I've actually got 2 that are like this.![]()
I certainly do not have a negative view of EK. Too the contrary.
Personally, I find it hard to trust any acrylic res of any type, from any manufacture. Just over time, I've seen/ heard so many stories of cracking.
Donate to XS.org
Tiborr - you could pop the rads over that wall radiator in the background of your test bench pic. Switching that on a few times a day should give you a nice heat cycle.
I have nothing negative to say either, for my part it just seems to be bad luck. And a huge positive thing is that both res did not leak even if there where a lot of cracks in them.
Xrim: even if they didn't leak back then, i wouldn't keep running/using them, as cracks may widen until said leaks appear, no trust in such any more.
tiborr: btw, i still think that there is SOMETHING wrong/different with X2 reservoirs. I cannot remember almost any post where someone complained about 50mm EK reservoirs, but even taking into accounts that there might be bigger numbers of less competent users @LC field these days then few years ago, somehow relatively big number of reported cracks for X2 rises a bit suspicion. You should check every possible bit that might differ between res lines. Starting from shipping packaging (if it changed, maybe new one is less protecting brittle things), till thread cutting machinery (maybe some slight inaccuracies/slight mismatching, that might add extra stress when bolted together/tightening down), maybe material as some suspected, or whatever else even slightest difference. If material used is same .. maybe something in tooling or in process of making/cutting/threading is not well fit for bigger diameter reservoirs.
The only time I toss EK on the spit is when it's truly EK's screwup (usually a design flaw, and there have been more than a few of those over the years).
btw, get a different shade of blue for your test bench. Every time I see it, I can't help but jump to the conclusion your running that God awful Gigabyte Liquid cooling system.![]()
Circles SucQ!
You might (if you have not) try dual pumps. There is such a thing as too much flow :p Aeration and foaming liquid is a direct result of excess flow.
You claim to be a deity, yet your user title says you're still chasing after becoming one. Make up your mind.
“Little expense had been spared to create the impression that no expense had been spared.” - Hitchhiker's GuideMondays:It's better to ask dumb questions now, than to look stupid later
