Page 1 of 3 123 LastLast
Results 1 to 25 of 55
Thread: Top Radiator .. Intake or Exhaust?
    Dec 2008
    Portugal
    So i'm building my new case and i have some doubts on what to do on the top radiator ...
    Basically i'm using a 420 and a 280 BlackIce GTX radiator with push-pull 140mm fan configuration...
    But i'm having some problems on how to do the air flow...
    So i have these 2 options ( blue rectangles are intake fans, red are exhaust ) :
    My inicial thoughts were to just leave the rear fan as an exhaust and use both rads as intakes ... this way they would get fresher air improving the performance.
    The front fan is a 180mm Silverstone Air Penetrator that will have a clear path for the air flow, so it will be able to intake the cold air to the end of the case... "pushing" the hot air for the rear exhaust fan and case openings...
    What do you think it's the best option? The left drawing or the right drawing?
    Here's actual photos of the case...
    Components to be cooled
    - CPU
    - Chipset
    - The VGA will be cooled as soon as the water block for it is launched...
    Thank you for your help.
    ( I already asked Martin for some help but i don't want to take him much time with private messages, so i'm putting this as a topic here )
    Oh...your ass is grass and I've got the weed-whacker.
    I am Xtreme
    Dec 2008
    France
    The way I see it 1 will result in somewhat cooler air going through the top rad but will increase the air temp inside of your case. 2 will have slightly warmer air going through the second rad, but the air temp inside the case should be a lot better. I'd go with #2.
    Donate to XS forums
    Oct 2006
    England, UK
    im doing a somewhat similar thing to yours in my new build. I have a top rad and a front rad.
    The front rad im using as an intake and then having a quad in the roof as an exhaust along with the 120mm fan on the back also.
    Id say go with #2
    Jan 2007
    Using a rad as an exhaust is a loss in performance and a waste IMO. Option #1 for best performance.
    Intel I7 920 D0 @ 4.2g------------EK Supreme HF
    EVGA X58 SLI LE------------------EK-FB EVGA X58 LE
    nVidia GTX 580----------------------EK-FC580 GTX
    6g Corsair DDR3----------------DDC 3.2 w/ Petra's top
    OCZ 120g Vertex SSD------------------PA120.4
    WD 150g Raptor
    WD 500g
    ASUS Xonar DS
    HX1000 psu
    Silverstone TJ07 case
    May 2010
    Germany
    I would go with the right drawing, this is the better choice for air flow, maybe you must consider also the air flow of power unit.
    Jun 2010
    Oregon, USA
    I have a HAF 932 with a 120.3 up top and had to decide. My logic was the same as zalbard. I chose the option on the right.
    I think it depends on whether you have enough rad to cool your blocks. If you have low load temps, then the option on the right may cool your case/RAM/mobo better. But if your load temps in your water-block components are too high, then using cooler ambient will improve block performance. Good luck.
    [SIGPIC][/SIGPIC]
    Cooler Master HAF 932 case; Corsair 850 tx psu; Dell 27" monitor
    XSPC rx rads; Apogee xt2; gtx680+Heatkiller fc; mcp655's in EK-D5 top
    distilled water + silver in MasterKleer 7/16" ID on 1/2" barbs & compressions
    I am Xtreme
    Dec 2007
    i would do something a little different
    go with picture 1, but swap the front fan to be exhaust in addition to the back one. hopefully you can rotate that fan. then you still have the coldest air for both rads, and your more balanced for intakes and exhausts.
    2500k @ 4900mhz - Asus Maxiums IV Gene Z - Swiftech Apogee LP
    GTX 680 @ +170 (1267mhz) / +300 (3305mhz) - EK 680 FC EN/Acteal
    Swiftech MCR320 Drive @ 1300rpms - 3x GT 1850s @ 1150rpms
    XS Build Log for: My Latest Custom Case
    Oct 2006
    England, UK
    Quote Originally Posted by Sideroxylon View Post
    If he goes with #1 then there will be too much internal air pressure of which it will be warm air. This would then warm all of the components up that he is trying to cool taking away all of the benefits.
    Technician
    Jun 2002
    Merseyside, UK
    Both rads and the rear fan as exhaust should give you best temps overall. Any air you blow into your case through a rad will raise case temp. Setting every rad as exhaust should in most cases give you best overall loop temps.
    I am Xtreme
    Jan 2011
    Quote Originally Posted by PiLsY View Post
    I would have to disagree here, since you are pulling warm air through the rad as opposed to intake through the rads, which in most cases (if ambient is lower than internal temp) would be pulling cooler air through the rad.
    John
    Jan 2007
    Quote Originally Posted by Scubar View Post
    You make it sound like our cases are air tight. That's not the case.There's more than enough places his fans will exhaust to. Anything he's air cooling in his case won't be affected by the slightly warmer air from his rads. It's not like they'll be blowing 80c air into the case. At most, with that setup, his rads will be blowing 5-10c aver ambient into his case. Anything he's water cooling won't be affected at all.
    What?!?! Why would blowing heated case air through a rad give you best temps? This is a ridiculous statement and goes against the basic principles on how rads work.
    WD 150g Raptor
    WD 500g
    ASUS Xonar DS
    HX1000 psu
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    LOLOLOL... i want to read the comments people write and see there thinking....
    so you really think him pulling air though the rads and out at the top will lower temps?
    Do you not see those mosfets hanging right below the top rad?
    Do you know how hot those guys can get and how much they can change ambients?
    Wouldnt you rather have air being blown on them from the top, then have to pull air from them?
    Quote Originally Posted by jcrouse View Post
    John
    Well from the looks of things... it doesnt look like he's a pack rat.
    I dont see no spider webs with fan headers, or even him trying to spell his name in cursive using the power cables..
    Do you honestly think there is going to be more then 1-2C delta different @ intake on his rad?
    Bingo! Ding ding ding!
    This guy deserves a cookie.
    Its true, at most the rad will absorb 60-75% of air.
    Then spits the rest out.... what does that mean?
    If the air going in and out of the rad is more then 2C, then by gosh, you have one hell of an efficient radiator.
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
    Oct 2006
    England, UK
    If your blowing warm air into the case you will be heating up not only all the other components but also the waterblocks themselves which will then be transferring the heat from the blocks aswell as the warm air inside the case which. Ive felt the warm air my Rads pump out when everything is under full load i wouldnt want that pumped back into my case.
    I am Xtreme
    Jan 2011
    Quote Originally Posted by NaeKuh View Post
    Well ... I am new, but according to my readings, most of the water is stabalized at at approximately the same temperature throughout the loop, so this is a somewhat bogus statement.
    Following your logic, I must ask, why even use a rad if the water exiting is within 2 degrees of what enters? I am guessing, but logic tells me, the more rad (all other things even) the lower the temps, hence the rad cools things down, even though the entry and exit temps are similar.
    John
    I am Xtreme
    Mar 2007
    Sugar Land, TX
    Option 2 would be my choice.
    Jan 2007
    You're seriously confused if you think the air blowing over a waterblock will overcome the effects from the watercooling itself. It's why we watercool in the first place. We take air's effect on the thing we're cooling out of the equation. Only thing air has to do with it is how cool of air we're feeding to our rads. That's what effects our temps to the things we watercool, not the air blowing on the block.
    WD 150g Raptor
    WD 500g
    ASUS Xonar DS
    HX1000 psu
    Sep 2006
    North East UK
    Hey i read all the comments from the water wizards who cant seem to decide which set-up would be best, why not the OP try it both ways as it wouldn’t take much testing given the current situation and let us all know the outcome???
    I'd rather test it myself than rely on hearsay and that way you're sure to get it right
  18. #18
    May 2008
    Honestly I think you will be fine with either. Really with the loop you have the only thing putting off heat inside the case will be the ram and harddrives. The top just seems to be a natural exhaust. I have two 360 rads internal in the same case currently, with intakes in the front and bottom and exhausts at the rear and top. My cpu stays in the 50s during games, and my gpu stays under 40.
  19. #19
    Chasing After Diety
    Jan 2007
    John
    yeah but look at saturation.
    as i said a MCR320 does about 60% at best your going to get 75% saturation.
    So that means 25% of the air is unused and gets passed along.
    So out of the 75% saturation, do you really think the delta of air going in and out is going to be that big?
  20. #20
    Sep 2009
    Broken Arrow, OK
    I have tried both ways and sucking in cold air from the top always wins. Try it yourself and see.
  21. #21
    May 2008
    Quote Originally Posted by BrokenArrow View Post
    How big of change in temps do you see? Also what parts are you watercooling? If you aren't cooling your video card I could see it making a difference, but if you are I don't think it really matters.
  22. #22
    Oct 2009
    I'd say it depends on what you're water cooling.
    If you're water cooling all the major heat sources (power regulation on the motherboard, VGA, CPU etc...) then the air temperature inside the case isn't going to be significantly higher than the outside temperature.
    If you have the top radiator as an intake, a lot of the heat picked up from the components you're watercooling is gonna be dissipated by the radiator, and dumped straight back into the case. It would then be picked up by the rear radiator. So some of the thermal energy from the water cooled components would just keep getting recycled back into the loop. If you don't have any major heat sources left being cooled by air, then this effect will probably outweigh the effect of pulling the very slightly warmer air in the case through the radiator.
    EDIT: Never mind, I'm an idiot. I see that you have only a fan and not a radiator on the rear panel. In your case then, I would recommend just having the radiator fans as intake.
  23. #23
    Sep 2006
    North East UK
    Quote Originally Posted by Odai View Post
    Oh man, this is the sort of misinformation i'm talking about
    Way way to many variables to drill it down to that sort of recommendations for sure and the post above suggesting his CPU's run at 50s during gaming is laughable without even knowing what CPU's he's running let along ambient etc etc etc.
    Come on guys
  24. #24
    May 2008
    I'm sorry, I'm used to it being in my sig. i7 930@ 4ghz. Ambient temp: 22c. My GPU and CPU are both watercooled. The difference between using the top as an exhaust and intake was insignificant.
  25. #25
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    I'm running a radiator in the top, and a front and a rear fan. Front and rear fans are intake, radiator is exhaust.
    My temps suck lol. I can drop CPU temps alone by several degrees just by opening the side panel of my case I need to redesign but I'm still not liking the idea of intaking from the top since that goes against my brain waves of "heat rises"
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
