Gabe picture isn't working, sorry.
Sent from my X10a using Tapatalk
MagisD
____________________________
Lurker, Dreamer, Planner, Noob
6 Quad rads 1 case Maybe I went a little overboard....Overkill Cube
Thanks Gabe!!!
very interesting...
but will it beat an SR1 @900rpm ?
That's the idea - This line of products complements our existing line-up and intends to compete with either high fin-density, or dual row rads that necessitate high pressure fans, while featuring a thin form factor and/or a lower cost.
For ultra low noise, QP remains king of the bang-for-the-buck. You know that they say, "if it ain't broke.."
CEO Swiftech
Thanks gabe cant wait!
gabe: exactly. QP ain't broken in any way, and might i even say - are even after several years still best rads for smart price/performancy minded builds. You really managed to hit the nail with them back then on initial launch with choosing good compromise between price/thickness/quiet fan optimization.
I'm not too sure about xtreme ones though. There are buyers for high speed fan builds too, but imho ones wishing for silence from LC outnumber those as 10:1 (wild guess), so volumes sold of these rads might be much lower.
People buy those big beefy rads because there is a misconception that size equals performance. I made that mistake myself on my current build. I just ordered a MCR420-QP from Jab for the build I am working on. In all honesty I don't think that there is a good argument out there in favor of a bloated pos's like the fessors of the world.
If I told you that I invented a new type of engine that made as much power as a traditional motor and took up half the space, I doubt there would be much argument as to which was better. I don't know about the rest of you, but space is a major consideration in the build I am working on. I would like to fit everything inside the case this time around. The QPs work as well as anything else out there and do it in much smaller and more economical package. Its not rocket appliance.
Aaron
That graph look great
Intel Core i5 6600K + ASRock Z170 OC Formula + Galax HOF 4000 (8GBx2) + Antec 1200W OC Version
EK SupremeHF + BlackIce GTX360 + Swiftech 655 + XSPC ResTop
Macbook Pro 15" Late 2011 (i7 2760QM + HD 6770M)
Samsung Galaxy Note 10.1 (2014) , Huawei Nexus 6P
[history system]80286 80386 80486 Cyrix K5 Pentium133 Pentium II Duron1G Athlon1G E2180 E3300 E5300 E7200 E8200 E8400 E8500 E8600 Q9550 QX6800 X3-720BE i7-920 i3-530 i5-750 Semp140@x2 955BE X4-B55 Q6600 i5-2500K i7-2600K X4-B60 X6-1055T FX-8120 i7-4790K
Dude, I just bought a whole bunch of slimline Koolance rads because there was no other option for my Kaze 3000's!
I's a little sad now...
PROJECT :: The Xtreme (WET) Dream!!!
PERSONAL H2O BESTS :
E8600 @ 4.8GHz E6750 @ 4GHz QX9650 @ 4.6GHz i7 920 @ 4.6GHz
PERSONAL AIR BESTS :
Sempron140 @ 4Ghz (Stock Cooler) i7 3960x @ 5.4ghz (Air Cooler)
Bex : "Who said girls can't play PC games or overclock!? Do I look like your imagination!?"
Aaron : "TBH, a girl doing all that is a pretty perfect girl!"
Swift_Wraith : "could someone please check bex for a penis?"
gabe: there are also tons of customers that buy 30FPI GTS rads because manufacturer wrote that they are great in in silent builds. "designed for uncompromising performance and stealth silent operation", yeah, right, and then they use sub-1K rpm fans on them. Don't underestimate power of marketing & PR BS. Many buy things based on just what's written(/lied) in product description, without doing homework of checking out independent reviews/tests/comparisons first. Just like it's very common in relation to fan choice from what i've seen in several PC forums. They fanatically cite wonder cfm/db numbers from product descriptions .. and keep buying wrong ones then what they actually would have wished for
@churchy good catch churchy I thought he was talking about those super thick rads : ) and you're right, people will believe anything you print.
CEO Swiftech
Gabe: imho you should rather expand your QP line with 140mm versions and .. make a deal with Nidec Servo to make 140mm Gentle Typhoons
EDIT
BTW, such fans also should make also great addition to 140mm polaris cooler, seeing as most top air coolers these days use one or two ~ 140mm sized fan (thermalright's TY-140 on archon and silver arrow are very wierd sized though with mounting holes of 120mm fan and size of 153x140, Noctua's NF-P14 FLX NH-DH14 also has 120mm mount holes). If scythe is too slow with bringing such product to market, why not some LC vendor?
[CENTER]The post counter is not an intelligence meter!Originally Posted by Massman
MAX11L - "It's like a console...with the suck turned down and the awesome turned up" -tet5uo
Heat Team IRONMODS
