http://www.frozencpu.com/products/12...html?tl=g30c83
Yes I know why a kit? Well I'm on a budget and I have to admit pretty scared to anything like this without an instruction booklet. How does this kit do in terms of price to performance?
I might be wrong, but you can check out also XSPC Rasa 750 kits. IIRC they were a tad cheaper, if you are looking for price/performancy foremost.
I feel you bro,
I went watercooling Kit the first 2 times I watercooled.
Problem was it was a huge mistake both times. I was never satisfied with what I had, I kept having to switch things out.
While I am like that slightly
I Have a 40 year old car with a brand new engine, I like to fix things up and change em around.
But when it comes to a watercooling kit, it's almost always a waste of money.
Back way when I got mine they all had aluminum parts, copper parts, nickel plalted this, gold plated that. and it was all bs.
Now you actually have some kits that aren't complete junk.
CPU only systems like the XSPC Rasa kit. for the money you can't beat a CPU only kit.
cept.. the pump kinda sucks(quiet tho & will do what it's designed to do, cool a cpu).. and the RS isn't made for really quiet fans.. albeit almost the same as a Swiftech MRC 'quiet power'
Will you be disapointed with the EK kit? most likely no. The Heralded Top performer within a fraction of a Degree C, great looking ... everything. Will you wish you had some other parts? possibly.
You need a
Cpu block
enough tubing
strong enough pump ( hard to get a bad one now a days, ddc, d5, whatever ek uses :P all good )
radiator enough to dissipate your heat with the fin count for the speed of fans you want to use. ( loud = high fins per inch, quiet = low fpi + more radiator )
Barbs & Clamps or Compression fittings
reservoirs are always nice
and fans.
and wether you get a kit or not, get a tubing cutter. Screw scissors.
Looking at other companies that offer complete kits, EK's is one of best IMO.
If you calculate overall costs of EK content it gets considerably cheaper when you buy the whole kit.
It has great CPU block, powerfull pump (so you can get system upgraded later),
fairly well performed radiator, nice plated fittings,...
Cmndt. Eric Lassard: What is the most frustrating thing about police work?
Tackleberry: Not being able to carry hand grenades, sir.
It really is a good kit, and the price is good, too. The only thing you may want to change is the fans, but other than that, every component is very solid.
Sounds like almost a done deal. How well would it compare to a high end air cooler?
Some of the EK kits consist of some really good components, some of which are the best parts you CAN get (like the Supreme HF). The pump is more than adequate (DCP 4.0)...actually, it's fairly good value for money.
Don't let the "kit" stigma scare you off. Not all kits are crap
For only $10 more you get the H20-320 Edge kit. (on sale at www.crazypc.com)
Similar rad, and water-block perf wise, but 100% better pump. and 100% easier to install too, with professional install guide, and only 2 parts to actually install.
just my 2 cts.
CEO Swiftech
As far as kits go, it's not bad. I do have to question the fluid though...anyone remember a certain someone canceling their warranty if you used an "aggressive fluid"?
+1
I would have saved you the shameless plug Gabe but my I-net crapped out on me when I was in earlier in the day.
Circles SucQ!
Agree with Gabe and WL....the MCR Edge kits are unbeatable in terms of installation and would be my pick for a first-timer.
It has the best CPU block mounting system, no reservoir or pump to install anywhere, just two tubes to route. EK kit doesn't even compare in that sense (assembling the CPU mounting probably takes just as much time/effort as doing the whole Swiftech kit). Performance is probably even between the Swiftech Edge and the EK HF kits; Edge is definitely ahead of the EK LT kits. I believe the Swiftech pump is a topless MCP35X and therefore PWM controllable as well (via motherboard header), so if you want to quiet down the pump (not that it's loud), that's extremely easy and effective. With the EK systems, you have to undervolt the pump, which isn't nearly as easy or reliable or effective.
Alternatively, an XSPC RSxx0 750 kit would be a much lower cost option (and you could get Gentle Typhoon fans and still be way under cost of the EK/SW options) with roughly the same ease-of-installation and usability as the EK kits. Performance would probably be somewhere between the EK HF and LT kits.
Between the EK HF, Swiftech Edge, and XSPC RSxx0 750 kits, I don't think there's a way to go wrong, but I'd lean toward the Swiftech Edge for a first-timer. I'm not a fan of the EK LT or XSPC RX kits, however. EK LT isn't that much cheaper than the HF kit but there are some pretty noticeable downgrades. Conversely, going to an RX rad from an RS is probably not much of an improvement except at very low fan speeds, but the price is much higher.
All this talk of liquid cooling, I almost forgot that I need a big case for a 120mmx3 rad....any suggestions?
800D. For 3x120 no moding required.
The Swiftech kit includes a "rad box" that will allow you to install it externally on most cases. Take a look at Swiftech's website to see how it works.
I really thought that forums are places to discuss topics with arguments. I guess I was wrong. And I'm disappointed of those people who seem to be a "water cooling professionals".
Regarding Gabe's claims that their pump is 100% better then EKWB's, I would like to take this opportunity and ask him to elaborate his claims. You can see independent comparative test here
http://martinsliquidlab.i4memory.com...mp-Review.html
Just the end quote:
I'm really impressed with this pump for several reasons. The smaller sibling (CPX-1) has a strong reputation for being one of the quietest pumps around, and it's nice to see this larger and more powerful big brother pump follow suit. It's very similar in pumping power to that of the Laing DDC 3.2, but it does so with less power consumption/heat dump and it also already comes with G1/4 barbs. The DDCs and D5 are also excellent pumps, and now we have another one to choose from with similar excellent performance. This is an excellent all around pump for most water cooling systems. Danger Den tells me this pump will retail for around $54.95, so it's at an extremely competetive price point and would cost less than both the Laing D5 and the Laing DDC 3.2. Good news for us!! And that how other feedbacks look like.
Regarding instalation I would say that products are for different groups of PC users. One who likes technical project, design and sophistication will probably choose EKWB. And manual to that is, by our users comments, very decent.
And finally, regarding performance, I would say that both systems performance, from EKWB and Swiftech are on comparable levels.
Now, I would really like to see arguments to claims
Originally Posted by creidiki
Eddy, I am sorry to read that you are "disappointed", and frankly I have neither the time nor the inclination to research all the posts throughout these forums, where you have plugged your own company or products, but I am pretty sure it is dozens of them, and I distinctly recall this to also include some posts that had Swiftech products as a topic by the way. So please tune down on the posturing. [Edit: Crazy PC is closing due to personal reasons - helping him to sell his inventory by pointing out the deals available is help to a long time friend, as well a good advice to a consummer on a tight budget]
As to quoting pumps reviews, I would also refer you to Martin's last review of the MCP35X here: http://martinsliquidlab.org/2011/02/...35x-reservoir/ or that of Skinnee there: http://skinneelabs.com/swiftech-mcp35x/ - [Edit, as well as: http://www.xtremesystems.org/forums/...d.php?t=262536] - end Edit]
CEO Swiftech
Donīt forget mine -> linked in signature
BTW: Package arrived, everything ok !
Worklog 1: ★★★ Project: Icebreaker ★★★
Bundymania @Facebook: Come and join me now
Triple (360) Radiator Roundup with 22 Rads !
Swiftech MCP35X Pump Review /// Roundup -> Bay Reservoirs & Laing Tops !
Review: 22 CPU Waterblocks // Review: 4x Tecnofront Reservoirs !
Quad Radiator Roundup - 11 Rads tested
Update: Mora 2 / Mora 3 / Phobya 1080 Xtreme & Supernova 1260
Tubing Comparison: 3/8" & 5/8" from Masterkleer, Primochill, Tygon, Kooolance, Nalgene
oh yea the mcp 35x is really cheap in comparison to ek's pump isn't it?
In the end the kits have a similar level of performance.
The ek kit, has the added benefit of compression fittings, and yes it will probably be more difficult to install.
And although the mcp35x is a better performing pump, if you adjust both pumps to have similar levels of noise, I doubt the difference would prove significant on what are now both low flow blocks (due to swiftech redesign).
I wish that a kit like this was available when I first started water cooling close to a decade ago, and it's a significant step up from the corsair h50/60/70.
Think about how simple watercooling has become, there are plenty of cases that come from the factory with the ability to mount a triple radiator.
Throw in a pair of universal gpu blocks, uni-sink if necessary, and you have some impressive gear for not very much money.
It's a good time to get into this hobby thanks to companies like swiftech, ek, and xspc.
For 150 the rasa 360 kit is a great deal.
Thanks for the un-baited trollery. The kits are $10 dollars different and comes with the better pump. Yes, it's just a sale, but that's all gabe was trying to point out. RIGHT NOW he can get the better price / performance. 3x120 and a mcp 35x? yes that is cheap in comparison.
Then it is a good deal isn't it? The conversation was on pumps earlier, not the full kits hence I was talking about pumps.
