X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 12 of 12
Thread: G.Skill Ripjaws X F3-10666CL7D-8GBXH gets tested
    Apr 2010
    Acer Aspire 4738Z
    My friend is in process of building his system. He's so nice to let me take this kit few days for testing
    Test system:
    Intel Core i5 2500K @ 4.6GHz 1.300V
    Cogage TRUE Spirit with dual fan configuration
    Asus P8P67 BIOS 1204
    G.Skill Ripjaws X DDR3-1333 7-7-7-21 1.5V 2x4GB
    Few pics of the memory
    DDR3-1333 6-7-6-21 1.5V
    DDR3-1600 7-8-7-24 1.675V
    Yes, it's not good at DDR-1600, needs 1.675V
    DDR3-1866 8-10-8-27 1.65V
    No clue why CPU-Z showed 8-10-9-27, MaxxMEM showed correct info
    DDR3-2133 9-11-9-27 1.65V
    DDR3-2200 9-11-10-27 1.65V
    DDR3-2250 9-12-10-27 1.675V
    Final result because BCLK almost reaches the limitation
    My verdict: this kit clocks very well, considering it's 8GB kit and low rated speed
    Intel Core i7-930 | High-End Water Cooler | Asus P6T6 WS Revolution | G.Skill Ripjaws X DDR3-1600 6-8-6-24 1.50V 2 x 2GB | Sea Sonic SS-750-JS
    Apr 2004
    Very impressive. I have 3 kits on my X58 rig and they can run 8-8-8-24 1T with 1600MHz and 1.5V.
    I think they are the same sticks as the Gskill 8-8-8 1600 1.5V (F3-12800CL8D-8GBXM) and the 7-8-7 1600 1.6V (F3-12800CL7D-8GBXH)
    Jul 2006
    how high do you need to set VTT to reach such speeds?
    Do you know which chips are under the hood? Hynix?
    THe results are very impressive
    Apr 2004
    Well I spoke a little too fast. Memtest ended failing up with 1600MHz 8-8-8-24 1T at 1.5V. I manage to get it to work with 1866MHz 9-11-9-27 at 1.65V so far but trying at 1920 failed. The chips are Hynix. VTT set at 1.325V
    Attached Images Attached Images
    Jun 2009
    good job :p
    great result for a 8gb kit
    Nov 2005
    Portugal
    Hi. i got some of those G-skillzzz.
    But they are not that good.
    2133Mhz 9-11-10-27 1T 1.65v
    |Asus Maximus 4 Extreme B3_ Bios 1904 / 3202
    |Intel i7 2600K / 3770K Corsair H80
    |G-Skill F3-18400CL8D-4GB PIS @ 2133mhz 6-9-6-24- 1T 1,71v
    |MSI Lightning 580GTX 1,5GB
    |OCZ vertex_60Gb FW_1.6
    |Corsair 750W AX
    [testing...] "Dude, BSOD is something that... doesn't suit me!"
    Jan 2010
    Killafornia
    better than my Ripjaws x 1600 CL9. cant even OC them to 1630.... shouldn't I be able to at least run them at 1700 with a small voltage bump without messing with the timings??
    DJ Falcone 2x Technics SL1200 MK5, Behringer DJX750 Mixer, Alienware m17 laptop.
    R.I.P computer
    Jul 2011
    chicago
    OP... you got very good IC
    i don't think everyone's modules will be as good as yours
    Nov 2005
    Portugal
    What´s "OP" ?
    Mine dont do 9-11-9-27 , to get 2240 i need to give more volts, 1,7v, with 9-12-11-27.
    :P need to try some sub timings .
    |Corsair 750W AX
    Xtreme Enthusiast TJ TRICHEESE's Avatar
    May 2009
    Quote Originally Posted by Counter CS View Post
    What´s "OP" ?
    The guy who started the thread.
    R.I.P computer
    Jul 2011
    chicago
    What´s "OP" ?
    "original post, original poster"
    9-11-10 with 1.65v@ 2200MHz is impressive for a 1333 rated kit... his are probably one of the better kits floating around... i had 1333 gskill before.. they were cas 8 though... didn't even do 2133 stably
    Oct 2004
    italy
    Stick product in sep. ag. 2011 not run over 1750Mhz.... have Elpida UTT...
    bad choice.
