AMD under 2300mhz, Xabre200 air cooled
gpu cooling: Stock cooling with AS2 on refitted HSF
highest gpu oc so far: 274
memory cooling: Nil
temp of water/gas: n/a
highest memory oc so far (w/wo artifacts): 274w 260w/o
vgpu: std
vddr: std
vref: std
mods(describe the mods you did): Nil
highest score(madmark link):
highest score(futuremark link): 9150 http://service.futuremark.com/compare?2k1=7441611
cpu: AXP 1800+ DLT3C
cpu oc: 2293mhz
cpu cooling: Prom Mach2
vcore: 1.7v
mainboard: Abit NF7-S V2.0
fsb oc: 218mhz
chipset timings: cpu interface enabled
nb cooling: Zalman ZM-NB32 with Sunon KD1204PKB2
sb cooling: Globalwin FA420
mosfet cooling: Nil
chipset voltage: 1.7v
memory: Corsair Twinx 3200LL 512
memory oc: 218mhz
memory timings: 2-2-2-11
memory cooling: std
memory voltage: 2.9v
psu: PC Power & Cooling - Turbocool 510w
12v: std
5v: std
3.3v: std
operating system: Win2000
sp: SP2
driver: Xabre3.08
ocing utility: 3d Wizard
roomtemp: 30 - 35c
casetemp: 35c +
cpu temp: -8c
