TJ-09 modding and guides?
Been searching vigorously to some good water cooling guides for this case but I haven't been able to come up with great results. I could just suck at looking, so that's why I came here I plan on re-doing my entire loop this week because it currently looks like this:
http://img411.imageshack.us/img411/9...0108144511.jpg
Pretty crappy, I know. I have an XSPC Dual Bay res I'm going to install, and a tri-radiator. I want to be able to install the tri-rad up top (where the dual is), but I want to know what kind of mods I need to do.
Also, I want to take the single 120mm I have there, and move it to the back of the case (where the fan is now). That was my initial goal but I wasn't able to mount the radiator the first time I tried. My radiator is a Black Ice Pro 120mm. I've seen some pictures of cases that have a radiator there, but I'm not sure what kind of radiator was used, or if the case had to be modded in order for the radiator to fit.
http://i165.photobucket.com/albums/u...C/DPP_0001.jpg
Any who, if any one has any tips or advice I would be forever thankful!
- You may not post replies
- You may not edit your posts
Forum Rules
