Hi guys!
Decided to share the info about my first SS build here -) I'm quite new to phase-change though I've read much info about it. Decided to 'get rid' of some unused components and make a system which would cool down the SB below zero (that would be a good opportunity concerning that recently LN2 became very expensive in Kiev).
Planned to spend as little money as possible for this system (not calculating the stuff I already have).
Components:
- Aspera NE2125E compressor;
- LuVe STFT 14 1 21 condenser with quite noisy native fan;
- 2 Shradders; simple dryer filter;
- copper tube of variable diameters; captube 0.8 mm;
- some R22;
- previously used evap built years ago by my friend
List of main instruments: propane-oxygene burner, pipe-cutter, tube-expander, some solder and flux.
I wanted to create a small and cute system, shiny one, not ghetto like this:
Evap:
Compressor has been used earlier by another noobish SS builder who used lead to solder tubes
It should be pretty small, yepp?
Some tubes, handbended -)
Used an old filter to make the desuperheater:
Soldering was not a problem (except 'fighting' with that ghetto evap).
Black and white should be stylish, I suppose:
There is a thermoprobe wire under the sleeve:
Some insulation (K-flex only):
That handle present on the pic should make the system carriage much more convenient.
First tests on SB clocked to 5500 MHz showed that evap's temp is approx. -40 C idle, -25-30 loaded with single-thread applications. Full load caused the temp to increase to -5 C.
Good enough still
Some technical data:
- idle pressure ~4,6 bar;
- high-pressure line when working ~10-11 bar;
- suction 1(+/-0,5) bar;
Unfortunately this is not the end, and later I will explain why. Have to clear out everything at first
P.S. Sorry for the technical terms, it is still hard for me to operate with them correctly in English, so some help and fixed would be fine
Regards, cyclone
