Hey internet, I'm indecisive again, please tell me what to do!
I have a relatively simple loop built around a vertical floor-mounted Laing D5 with a res-top on it. To make my build easy to understand, I've made a few diagrams.
So, here's what it looks like currently:
(different tubing color isn't significant in any way, just made it easier to see where the tubing crosses)
I've two options I'm thinking about with a drain port:
V1
or:
V2
The physical layout of the components is actually similar to the diagram too, although the radiator can easily be flipped upside-down, so that the barbs are close to the bottom and could provide another spot where I can easily put a drain port. The main difference between V1 and V2 is that in the first one (same as it is currently), the reservoir acts as a giant T-line, while in V2 it would actually act as a return point for the water.
Anyway, which one do you think is better, V1 or V2? Or something else entirely? Also, reason(s) why?
