Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: Dimastech Benches
    Feb 2010
    Wisconsin
    Dimastech Benches
    I've looked at a lot of builds with this bench and I absolutely adore it, almost every single flavor too. However, when I try to find a place to buy it, all I can find is the direct retailer (ITALY!!) that sells it for close to 300 USD! Is there a place in the US that sells this bench for cheaper? Otherwise, is there another bench that holds a 360 rad and can hold up some pots for DICE?
    Signatures make my posts look huge... but I'm not humble enough to completely remove my signature, so I kept this note explaining it.
    Jan 2008
    Chicago, IL USA
    Just look at it as an investment. I bought one from Dimas in late August 2010 and absolutely luv it. Best $350 i ever spent. Purchased quite a few extra accessories too, and those flex fans are great.
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    Danger den torture rack is what I use on my bench and can easilymhold my dual 480s .. 360s no issue..
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
    Feb 2010
    Wisconsin
    Johnny, could you link the DD Rack you're using? The ones that I find only support 240s and don't look like they could ever support a subzero pot.
    Apr 2010
    Palo Alto, CA
    Aquatunig us sells the easy for about a hundred iirc
    Feb 2008
    Quote Originally Posted by ScottALot View Post
    Microcool Banchetto 101
    http://www.performance-pcs.com/catal...ducts_id=25498
    CPU : AMD X2 5200+ @ 3Ghz
    Motherboard : EPOX EP-AF590 SLI2 with Thermalright HR-05 IFX SLI
    CPU Cooler : Thermalright Ultra 120 Extreme with Noctua NF-P12
    Videocard : XFX 8600GT Fatal1ty Edition @ 700/1800Mhz
    DDR : Teem Xtreem PC-6400 2X1GB @ 4-4-4-8 / 500Mhz
    HDD : Sata II - 2 X Seagate 250GB ST3250410AS 16MB cach in RAID 0 ; IDE - Seagate 160GB, WD 80GB
    PSU : Chieftec 600 Watt, +12V Combined 48A - CTF-600-14CS
    CASE : Chieftec AEGIS CX-05B-B with 4 X Scythe SLIP STREAM SY1225SL12M controled by
    Scythe Kaze Master 5.25 @ 1000RPM; 3 X Noctua NF-B9 @ 1000RPM
    Monitor : HP L1740
    speacker : Logitech X-230
    Aug 2004
    Minneapolis, MN
    Build your own out of wood.
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    Performance-PC's sells a Tecnofront HWD. It isn't all that bad for the price. I've used 2 3x120mm radiators on the bottom without any real issues.
    Aug 2004
    Minneapolis, MN
    I built two different benches out of wood and they worked great. The most solid test bench I've seen to date.
    Feb 2010
    Wisconsin
    Quote Originally Posted by bobisgod View Post
    ooh! That I will have to really consider!
    Quote Originally Posted by OgaiB View Post
    Does that support a 360 rad? It looks like some stuff would be in the way...
    Quote Originally Posted by BlueAqua View Post
    :P If I had the proper tools, I wouldn't have this thread haha
    Quote Originally Posted by spotswood View Post
    Even I wouldn't build one out of wood.
    But it would be a big one.
    Yeah that's a bit too big for my taste... it's nice, but I'm not exactly SR-2 ready financially haha
    Feb 2010
    Wisconsin
    Quote Originally Posted by lowfat View Post
    I like the Bancetto a little more than that one, I can't really pick out why.
    Yeah I wasn't really doubting that, I just don't have the proper equipment to make something like that.
    I am Xtreme
    Oct 2005
    The Microcool definitetely looks better but I don't think you would be able to fit 2 radiators + everything else.
    Feb 2010
    Wisconsin
    That's true, but while the Technofront has the room for all of that, it doesn't look very modular... also I want to keep it a little shorter for the subzero stuff... don't want any heavy pots stressing the multiple levels.
    Feb 2010
    Wisconsin
    I think I can sum up what I want... it doesn't necessarily have to be a bench.
    I want the space so I don't have to worry about adding, for example, a second loop. (MAJOR)
    I want it to look good by itself.
    I want it to be able to maintain its looks with hardware installed.
    I want the hardware to be able to be put in and taken out easily so I can do benching.
    I have a HAF 932 that, while it does look great with and without hardware, is not big enough for my ideas and hardware is pretty hard to get out of there.
    Xtreme Guru
    Jun 2010
    Just get a radiator bracket and mod a tortue rack and wolla your set.. not all that hard mate..
    Feb 2010
    Wisconsin
    I dunno, I kinda like the DD Box, but its size is small for my taste.
    But my feeling right now is ...
    Gaaah I'm so confused right now, I don't know what I want!
    What I do know is that the Banchetto and Dimastech Easy are both major contenders, but I just wish there was some case (not bench) that was big enough and slick enough so that I could do the things I want to do easily.
    It's like I want the Lian Li PC-P80's look of the case, Corsair 800D's water-cooling friendly design, Cooler Master ATCS 840's look with hardware, and Mountain Mods Pinnacle's size.
    *awaits master sketch-up artist to fly in*
    May 2009
    Hull, England
  18. #18
    Xtreme Guru
    Jun 2010
    Bench is a bench dude, if he wants it for aesthetics get a full case
  19. #19
    Feb 2010
    Wisconsin
    Honestly, I'd rather get the Easy because it's cheap and then save up for a custom case... I'm somewhat disappointed that Mountain Mods can't make anything better than a case with 90 degree angles galore. Imagine a PC-P80 that is a tad bigger, bottom-mounted PSU, black (anodized/powder coated) interior, and more water-cooling friendly.
  20. #20
    Feb 2010
    Wisconsin
    I think I know what I'm going to do. I'm going to get a Dimastech bench and turn my HAF 932 into a radbox... that is, if the side panel can hold one of these puppies: http://www.frozencpu.com/products/11...?tl=g30c95s570
    It'll probably end up being a dual-loop box, with some light mods here and there.
  21. #21
    Sep 2002
    Italy
    what version you have been looking for ? Easy or EasyHard?
    we're taking other 2 months of low ship cost to USA/CANADA until the distributor get some pieces...
    send me a PM for getting a detailed quote, we've also special offers on custom colors..remained stock..
  22. #22
    Feb 2010
    Wisconsin
    I wish I could see an outline on exactly what the differences are between each one, but I think I want the EasyHard. I'll shoot you a PM.
  23. #23
    Administrator
    Nov 2007
    Stockton, CA
    Didn't quote image... I remember that SS Phase unit
    Still have it, need to try it on SB still.
  24. #24
    Dec 2006
    Yeah I haven't had enough courage to place an order yet because it's so hard to make up my mind with all the choices.
    /_/_/_ | Intel Core i7 920 @ 4.2GHz | Swiftech Apogee GTZ | Gigabyte EX58-UD5 | CORSAIR DOMINATOR 6GB DDR3 1600 | 2 x ATI 4850 Crossfire Enabled | WD Velociraptor 300GB | Creative Sound Blaster X-Fi Titanium Fatal1ty Pro | Corsair HX1000W | Antec P182 | _\_\_\
  25. #25
    Apr 2005
    Calgary, AB
    The thread linked in his sig shows both easy and hard with many pics.
    MB Reviewer for HWC
    Team OCX Bench Team
