X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
Results 1 to 14 of 14
Thread: RAM H20 Cooling?
    I am Xtreme
    Mar 2007
    Sugar Land, TX
    RAM H20 Cooling?
    I have only cooled my RAM once, and that was just for appearances.
    My question; does it really make any difference? I am guessing that it does not.
    TIA
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    Mostly for aesthetics.
    May 2009
    UK
    Really depends on your goals, it is mostly done for appearance as you say or to complete the look of the mod.
    In some highly overclocked systems you could argue that the modules do reach a significant temperature to justify extra cooling but not when priced up against the cost of the block etc.
    [SIGPIC][/SIGPIC]
    I am Xtreme
    Mar 2007
    Sugar Land, TX
    Quote Originally Posted by lowfat View Post
    Quote Originally Posted by Aquatuning View Post
    Thanks for the replies. I was tempted for a brief moment, but I could not pull the trigger.
    Nov 2010
    Good choice most of the time you dont gain any extra performance, and they are typically extremely restrictive
    It will lower the ambient case temperature. If you have a radiator sucking air by the ram than it might help, but not by much.
    Uber Raid King
    Aug 2009
    Wichita, Ks
    the EK blocks are not restrictive. you would have to find the right block/.
    "Lurking" Since 1977
    Jesus Saves, God Backs-Up
    *I come to the news section to ban people, not read complaints.*-[XC]Gomeler
    Don't believe Squish, his hardware does control him!
    Nov 2010
    You don't even need a fan on them when running at 2000Mhz and 1.67V You sure don't need to water cool them
    Never go full retard
    Feb 2008
    Quote Originally Posted by Computurd View Post
    I'm gonna have to get a MIPS and EK to run pressure drop on them, I can already tell.
    Apr 2008
    France
    They dont *need* the extra cooling but *you* would like the extra silence, if the fans on RAM are like the only thing that still produces noise (and they are indeed noisy these little things).
    24/7 running quiet and nice
    Dec 2008
    EU
    +1
    Quote Originally Posted by skinnee View Post
    Go Skinee
    Quote Originally Posted by gmat View Post
    i couldn't put it better there.
    Cmndt. Eric Lassard: What is the most frustrating thing about police work?
    Tackleberry: Not being able to carry hand grenades, sir.
    Dec 2004
    Flying through Space, with armoire, Armoire of INVINCIBILATAAAAY!
    My ram has no fans. Also no heatsinks. This whole cooling thing? Overrated.
    I can't really take it past 1.65v, (or I'll have to keep buying new CPUs), and it doesn't heat much at all at that voltage. So... meh.
    Sigs are obnoxious.
    Xtreme Guru
    Aug 2003
    Athens, Greece
    As you already understood, it's mostly for bling...
    Project ZEUS II
    Asus Rampage II Extreme
    Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
    3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
    2 x Asus HD 6870 CrossFire @ 1000/1100MHz
    OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
    Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
    Watercooling setup:
    1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
    2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
    Assembled in Mountain Mods Ascension Trinity
    Powered by Corsair Professional Series Gold AX1200
    Aug 2004
    Minneapolis, MN
    Quote Originally Posted by JoeBar View Post
    Good enough for me, I'll buy 2.
